RSC 4/DUO
RSC 4/DUO
    BELDEN
    CONN RCPT MALE 4P SCREW
RSC 4/DUO 数据手册
M12 Field Attachable Connectors (DUO) Male, 4- and 5-Pole RSC...DUO | RKC...DUO RSC...DUO Field attachable connector, M12 Duo male connector, 4- and 5-pole with threaded joint, for two cable connections, assembling with screw terminals. Female, 4- and 5-Pole RKC...DUO Field attachable connector, M12 Duo female connector, 4- and 5-pole with threaded joint, for two cable connections, assembling with screw terminals. Pin Assignments Face Views / M12, Male / Female 4 pole 316 5 pole 1.800.Belden1 | 1-717-217-2299 www.lumberg-automationusa.com www.lumberg-automationusa.com Field Attachable Connectors Be Certain with Belden M12 Field Attachable Connectors (DUO) RSC...DUO | RKC...DUO Technical Data Environmental Degree of protection Operating temperature range IP 67 / NEMA 6P -25°C (-13°F) / +90°C (+194°F) Mechanical Housing / Molded body Insert Contact Receptacle shell O-ring Mode of connection Connectable conductor PBT PBT CuZn, pre-coppered, CuSnZn CuZn, nickel plated FKM Screw terminals max. 0.75 mm2 Electrical Contact resistance ≤ 5 mΩ Nominal current at 40°C 4A 4 poles 240 V Nominal voltage 5 poles 60 V Rated voltage 4 poles 250 V 5 poles 63 V Test voltage 4 poles 2.0 kV eff. / 60 s 5 poles 1.5 kV eff. / 60 s > 109 Ω Insulation resistance Pollution degree 3 Pins Cable Diameter Range Male Female RSC 4/DUO RKC 4/DUO 4 2 x 3 mm / 2 x 5 mm RSC 5/DUO RKC 5/DUO 5 2 x 3 mm / 2 x 5 mm www.lumberg-automationusa.com 1.800.Belden1 | www.lumberg-automationusa.com 1-717-217-2299 Field Attachable Connectors Part Number Characteristics 317
RSC 4/DUO
物料型号: - RSC...DUO 和 RKC...DUO 系列的M12连接器。
器件简介: - 这些是现场可装配的M12 DUO公头和母头连接器,具有4和5个引脚,带有螺纹连接,用于两根电缆的连接,并通过螺丝端子组装。
引脚分配: - 4极和5极的M12连接器,具体引脚分配未在摘要中提供。
参数特性: - 保护等级:IP 67 / NEMA 6P - 工作温度范围:-25°C 至 +90°C - 机械特性:包括PBT材料的外壳/模塑体,CuZn预镀铜的接触件,CuSnZn的插座壳,CuZn镀镍的接触件,FKM的O形圈。 - 电气特性:接触电阻 ≤ 5 mΩ,4极在40°C时的名义电流为4A,额定电压和测试电压因引脚数量而异,绝缘电阻 > 109 Ω。
功能详解: - 连接器允许现场装配,适用于多种电缆直径范围,最大0.75 mm²。
应用信息: - 适用于需要现场装配和高保护等级的应用场合。
封装信息: - 提供了RSC4/DUO和RKC4/DUO(4极)以及RSC5/DUO和RKC5/DUO(5极)的型号,适用于2x3mm或2x5mm的电缆直径范围。
RSC 4/DUO 价格&库存
很抱歉,暂时无法提供与“RSC 4/DUO”相匹配的价格&库存,您可以联系我们找货
