FGG.1B.305.CLAZ
www.lemo.com
SUMMARY
# Wires
Low
5
High
Coax
Triax
Quad
Fiber
Fluidic
Series
1B
Termination type
Male solder
IP rating
50
Cable Ø
0.00 - 0.00 mm
Status
active
Image is for illustrative purpose only
Download
Request a quote
Catalog
See video assembly instructions
Alternative part
Matching parts
EGG.1B.305.CLL
PHG.1B.305.CLLZ
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FG*: Straight plug, cable collet
Keying
1 key (alpha=0, plug: male contacts, receptacle: female contacts)
Housing Material
Brass (chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces
Variant
Weight
13.96 g
Performance
Configuration
1B.305 : 5 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/3.2, depends on material thickness)
Rated Current
9 Amps
Specifications
Contact Type: Solder
Contact Dia.: 0.9 mm (0.035in)
Bucket Dia.: 0.8 mm (0.031in)
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Max. Solid Conductor: 0.34 mm^2 (AWG 22)
Max. Stranded Conductor: 0.34 mm^2 (AWG 22)
R (max): 4.8 mOhm
Vtest (contact-shell): 1150 V (AC), 1630 V (DC)
Vtest (contact-contact): 1250 V (AC), 1770 V (DC)
Others
Endurance (Shell): 5000
Temp (min / max): -55°C / +250°C
Humidity (max): 1000 hr
IP Rating: 50
DRAWINGS
Draws
Dimensions
A
L
M
S1
S2
mm.
12
43
32
10
9
in.
0,47
1,69
1,26
0,39
0,35
2/3
RECOMMENDED BY LEMO
Tools
Spanner wrench: DCD.1B.015.PA090
Caps: BFG.1B.100.PCSG
Cables
3/3
很抱歉,暂时无法提供与“FGG.1B.305.CLAZ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+320.586631+39.77705
- 10+280.7664910+34.83633
- 25+268.6370025+33.33136
- 50+259.9715750+32.25619
- 100+251.30511100+31.18089
- 250+237.43996250+29.46056
