934935008
934935008
    BELDEN
    CONN PLUG FMALE 4POS GOLD SCREW
934935008 数据手册
Product: RKCS 4S/11 M12 Power Field Attachable Connector: Female, straight, 4-pin(3+PE), S-coded, shielded, silver housing, screw type, 600 V AC/DC Product Description M12 Power Field Attachable Connector: Female, straight, 4-pin(3+PE), S-coded, shielded, silver housing, screw type, 600 V AC/DC Technical Drawing Technical Specifications Technical Data Product Family: Power Connector Product Sub Family: M12 Power Brand: Lumberg Automation Connector Type: Field attachable Type of Contact / Gender: female Connector Design: straight Number of Pins: 4(3+PE) Coding: S Shielding: Shielded Attachment Type: Coupling Nut Rated Voltage: 630 V Rated Impulse Voltage: 6.0 kV Operating Voltage: 600 V AC/DC Contact Resistance: ≤ 10 mOhm Insulation Resistance: ˃ 10^9 Ohm Mating Cycles: ≤ 100 Type of Connection: Screw Cable Gland: PG 11 Maximum Wire Isolation Diameter: max. Ø2,9 mm Strain-Relief: clamping cage Suitable Cables: 3 gaskets enclosed (Ø3 - Ø6 mm, Ø5 - Ø9 mm, Ø8 - Ø11 mm) Ambient Temperature (Operation)*: -40 °C to +125 °C, notice derating Protection Degree / IP Rating**: IP65, IP67 Design Standard: IEC 61076-2-111 Pollution Degree: 3 acc. to DIN EN 60664-1 (VDE 0110-1) Clearance / Creepage Distance: DIN EN 60664-1 (2008/01); VDE 0110-1 Overvoltage Category: III acc. to DIN EN 60664-1 (VDE 0110-1) Materials Contact Base Material: CuZn Contact Plating: Cu/Au Contact Bearer Material: PBT GF Contact Bearer Color: black Flammability Class (Contact Bearer): UL 94 V-2 Housing Material: CuZn Housing Plating: Ni Housing Color: silver Cable Gland Material: CuZn Cable Gland Plating: Ni Cable Gland Gasket: NBR Strain-Relief Material: PBT GF Flammability Class (Strain Relief): UL 94 V-2 Attachment Material: CuZn Attachment Plating: Cu/Ni Shielding Material: CuZn, plating: Ni O-Ring Material: FKM Safety & Environmental Compliance RoHS Compliant: yes Notes Note Derating: * Notice derating Protection Degree / IP Rating Note: ** only if mounted and locked in combination with Hirschmann / Lumberg Automation connector. Variants Item # Item Description Conductor Cross Section Rated Current 934935008 RKCS 4S/11 max 1.5 mm² 16 A © 2021 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
934935008
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款带有正逻辑输出的光电耦合器,使用AlGaAs发光二极管和集成的高速光敏晶体管。
它适用于TTL和CMOS接口。
3. 引脚分配:EL817有2个引脚,分别是发光二极管的阳极和阴极。
4. 参数特性:包括电流传输比(CTR)为5%至20%,正向电压V(F)为1.0至1.5V,集电极-发射极电压V(CE)为5V至30V等。
5. 功能详解:EL817能实现电隔离和高速信号传输,常用于开关电源、测量设备等。
6. 应用信息:适用于工业控制系统、计算机外部设备、通讯设备等。
7. 封装信息:EL817采用DIP-8封装。
934935008 价格&库存
很抱歉,暂时无法提供与“934935008”相匹配的价格&库存,您可以联系我们找货
