Circular Connectors Supporting TÜV and MIL spec.
H/MS Series
Features
1. Compatible with MIL spec. standard
products
2. A ground circuit is provided in the
TÜV approved connectors
The mated plug/receptacle combinations and
un-mated receptacles are compliant to IP67F and
IP68F ratings.
IP67 : Left in water at a depth of 1 m for 30 minutes
IP68 : Left in water at a depth of 2 m for 14 days
Product Specifications
d
e
u
Ratings
Standard products
Shell size
Contact arrangement
Number of contacts
Rated current (A)/contact
The figure in [ ] indicates the total
capacity of the connector.
Rated voltage
4
2
10SL
3
3
18
10
4
15
7
13
[24.5]
13
[34.5]
23
[76.2]
23
[105.7]
Storage temperature range
b
o
TÜV approved products
Shell size
Contact arrangement
Number of contacts
Wire size (mm2)
d
e
h
c
S
Items
1. Contact resistance
2. Insulation resistance
3. Withstanding voltage
4. Vibration Resistance
5. Shock resistance
6. Mating Cycles
7. Temperature cycle
8. Moisture resistance
9. Waterproof
t
d
e
l
u
Rated voltage (V)
Degree of pollution
Conducting voltage category
Operation temperature range
10SL
3
3
10 13
0.5 0.75 1.25
200
3
Ⅲ
d
e
17
2
18
10
4
46
[152.5]
23
[100.4]
17
3.5
500
2
2
22
22
4
24
10
7
23
23
35
46
23
35
46
23
3.5
250
3
3.5
5.5
500
2
8
3.5
5.5
250
3
8
3.5 5.5
250
2
Ⅲ
Ⅱ
-40 to +125℃
-10 to +60℃
Specifications
10SL, 20-29, 22-14 : 5mø max.
18-10, 20-15, 22-23 : 3mø max.
22-22, 24-10 : 1mø max.
5000Mø min.
13A
[49.4]
-10 to +60℃
23
Ⅱ
23
8
14
19
o
c
is
13
[44.2]
22
22
4
n
i
t
n
29
17
AC500V, DC700V
-40 to +125℃
Ratings
Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
3. Waterproof
Ⅲ
35
Ⅱ
Conditions
Measured at DC 1A
Measured at DC 500V
TÜV approved products : AC 2250V for 1 minute.
No flashover or dielectric breakdown
Standard products : See the table of contact
arrangement and electrical performance.
10 to 500Hz/cycle, full amplitude : 0.75mm, with
98 m/s2, 3 directions, 3 hours each
No electrical discontinuity for 10µs min.
98 m/s2, 3 axis directions, 3 hours each
Acceleration : 490 m/s2, duration : 11 ms,
3 axis directions, 3 cycles each
Contact resistance : Initial value x for 1.5mø max. 500 times
-55ç : 30 minutes ➝ Normal temperature : 10
to 15 minutes ➝ 125ç : 30 minutes ➝ Normal
Insulation resistance: a minimum of 500Mø
temperature : 10 to 15 minutes, left for 5 cycles
Insulation resistance :
Temperature : 71ç, relative humidity : 95%, left for
a minimum of 50Mø (at high humidity) min.
336 hours
500Mø (when dry) min.
Left in water at a depth of 1m for 0.5 hours in the
No water penetration into the connector.
mated state.
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2021.10⑤
1
H/MS Series●Circular Connectors Supporting TÜV and MIL spec.
■Materials / Finish
Material
Finish
Remarks
Shell
Aluminum alloy
(Zinc alloy : H/MS3108B plug cord tube)
Black chromate
treatment
Insulator
PPS resin, PBT resin, or silicone rubber
Black
Contact
Copper alloy
Acrylonitrile-butadiene rubber
(Chloroprene rubber : H/MS08A plug)
Bushing
Silver plating
UL94V-0
(Excluding silicone
rubber)
Black
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
● Plug and receptacle
H/MS 3102 A 18 - 10 P X - D - T (01)
❶
❷
❸
❹
❺
❻
❼
❽
❾
n
i
t
n
● Clamp
H/MS 3057 - 4A (01)
❶
qModel name: H/MS Series.
wShape
3102
3106
3108
3057
o
c
is
❷
d
e
b
o
d
e
u
: Indicates the shape of the connector.
: Receptacle
: Straight plug
: Right angle shaped plug 08 : Low-profile, right angle shaped plug
: Cord clamp
t
d
e
l
u
eStructure : Indicates the structure of the connector.
A : Integrated shell
B : Separated shell
d
e
h
c
S
rShell size : This is the diameter of the screw (inches) at the termination end multiplied by the constant of 16. (Example : The
shell size of 18 is calculated by 1 1/8” x 16 = 18.)
tContact arrangement : See pages 10 and 11 for details on contact arrangement.
yContact form : Indicates the termination style.
P : Soldered, male contact
S : Soldered, female contact
PC : Crimped, male contact
SC : Crimped, female contact
uVariations of insert position : The letters W, X, Y, or Z are used for any changes in the insert position from that of the
standard type.
iGround contact number : Notes the grounded contact for TÜV approved products. The ground contact position corresponds
to contacts C, D, or G, and varies depending on shell size. Part numbers without this symbol
indicate that the part does not include a ground contact.
oTÜV approved product : TÜV approved products that are compliant with DIN VDE 0627.
!0Clamp size : Indicates both clamp size and structure.
!1Other specifications : A two-digit number such as (01) or (02) is added to indicate other specifications.
2
Straight plug
Spanner/wrench flat width (mm) E
D
A
ØA
D
B
18−10S
C
X
Y
C
H/MS3106A18-10S-D-T(73)
B
(Representative example)
HRS No.
120-0601-3 73
120-0603-9 73
120-0605-4 73
120-0611-7 73
120-0611-7 77
120-0613-2 73
120-0615-8 73
No. of contacts
2
3
4
HRS No.
120-0326-0 73
120-0323-2 73
120-0324-5 73
120-0325-8 73
No. of contacts
3
ØA
B
22
36.8
33.5
50
C
D
E
5/8-24UNEF-2A
1-20UNEF-2A
27
10
17
37
19
4
39.5
54.5
4
t
d
e
l
u
n
o
sc
B
36.8
50
54.5
57.7
i
d
e
b
o
7
Right-angled plug
d
e
h
c
S
ØA
22
33.5
39.5
43
C
tin
D
5/8-24UNEF-2A
1-20UNEF-2A
1 3/16-18UNEF-2A
1 7/16-18UNEF-2A
10
32
E
---27
32
37
B
E
D
Part No.
H/MS3106A10SL-3S-C-T(73)
H/MS3106A22-22S-D-T(73)
H/MS3106A24-10S-G-T(73)
d
e
u
1 3/16-18UNEF-2A
18
C
Part No.
H/MS3106A10SL-4S(73)
H/MS3106A10SL-3S(73)
H/MS3106A18-10S(73)
H/MS3106A20-29S(73)
H/MS3106A20-29SW(77)
H/MS3106A22-14S(73)
H/MS3106A22-22S(73)
ØA
Standard products
Spanner/wrench flat width (mm) F
H/MS3108B18-10S-D-T(31)
Standard products
Part No.
H/MS3108B10SL-4S(73)
H/MS3108B10SL-3S(73)
H/MS3108B18-10S(31)
H/MS3108B20-29S(31)
H/MS3108B20-29SW(34)
H/MS3108B22-14S(73)
H/MS3108B22-22S(73)
HRS No.
120-0701-8 73
120-0703-3 73
120-0705-9 31
120-0711-1 31
120-0711-1 34
120-0713-7 73
120-0715-2 73
No. of contacts
2
3
4
ØA
B
C
22
37.3
24.5
33.5
54.5
32
17
E
F
5/8-24UNEF-2A
1-20UNEF-2A
32
11.6
37
60.7
19
4
D
34
35
1 3/16-18UNEF-2A
39.5
38
Part No.
H/MS3108B10SL-3S-C-T(73)
H/MS3108B22-22S-D-T(31)
H/MS3108B24-10S-G-T(73)
HRS No.
120-0421-1 73
120-0422-4 31
120-0423-7 31
120-0424-0 73
No. of contacts
3
4
7
ØA
22
33.5
39.5
43
B
37.3
54.5
60.7
67.1
C
24.5
32
34
39.6
D
11.6
E
5/8-24UNEF-2A
1-20UNEF-2A
1 3/16-18UNEF-2A
1 7/16-18UNEF-2A
F
38
41
(Note) With some models it may be difficult to push the cable through the connector, even when the cable is within the applicable range.
Waterproof performance and cable clamp capability may differ depending on the cable specification. Please make sure
all specifications are met before actual use.
3
Low-profile, right-angled plug (with cord clamp)
18 size : Ø33.5
18
18 size : 45.5
(22 size : 67.5)
A
Y
B18−10S
D
C
X
3057−10
H/MS08A18-10S-DT10D(73)
(22 size : Ø39.5)
18 size : 41
(22 size : 45.8)
18 size : 31
(22 size : 36)
Part No.
No. of
contacts
HRS No.
120-0476-3 73
H/MS08A18-10S-DT10D1(73)
120-0481-3 73
H/MS08A22-22S-DT12D(73)
120-0477-6 73
4
Weight
89g
127g
Applicable cable
diameter
Ø12 ∼ 14.3mm
n
i
t
n
Ø10 ∼ 12.5mm
Ø13 ∼ 15.9mm
o
c
is
d
e
h
c
S
4
e
l
u
t
d
d
e
b
o
d
e
u
Solder pot diameter
Ø2.5
Ø4.5
Single block (waterproof)
This connector is designed for use with flexible conduit or cabtire
cable connectors.(See page 8 for the table of compatibilities for
H/MS connectors and other connectors.)
D
A
ØA
D
X
Y
B
C
18−10S
C
H/MS3106A-18-10S-D-T(76)
B
Part No.
H/MS3106A10SL-3S(76)
HRS No.
120-0603-9 76
No. of contacts
3
ØA
22
B
24
C
6.5
H/MS3106A18-10S(76)
120-0605-4 76
4
33.5
31.2
8
1-20UNEF-2A
D
9/16-24UNEF-2A
Part No.
H/MS3106A18-10S-D-T(76)
HRS No.
120-0323-2 76
No. of contacts
ØA
33.5
B
31.2
C
8
D
1-20UNEF-2A
H/MS3106A22-22S-D-T(76)
120-0324-5 76
39.5
33.2
10
1 1/4-18UNEF-2A
4
d
e
b
o
B
A
d
e
h
c
S
e
l
u
D
C
X
ØC
A
B
Y
18−10
D
I
Part No.
H/MS3102A10SL-4P(73)
H/MS3102A10SL-3P(73)
H/MS3102A18-10P(73)
H/MS3102A20-15P(73)
H/MS3102A20-29P(73)
H/MS3102A20-29PW(74)
H/MS3102A22-22P(73)
HRS No.
No. of contacts
120-0111-4 73
2
120-0113-0 73
3
120-0101-0 73
4
120-0115-5 73
7
120-0103-6 73
17
120-0103-6 74
120-0107-7 73
4
E
F
H/MS3102A18-10P-D-T1(73)
Standard products
d
e
u
ØH
t
d
n
i
t
n
o
c
is
Receptacle (solder type)
B
A
Standard products
G
A
B
ØC
18.26 25.4
D
E
F
ØH
I
14.5 2.2 23.6 28.3 15.6 5/8-24UNEF-2A
26.97 34.92
30
3.3
29.36 38.1
G
19.3 2.8
35
29.4 33
31.75 41.28
26.6 1 1/8-18UNEF-2A
29.6 1 1/4-18UNEF-2A
38 32.6 1 3/8-18UNEF-2A
Part No.
H/MS3102A10SL-3P-C-T(73)
H/MS3102A22-22P-D-T(73)
H/MS3102A24-10P-G-T(73)
HRS No.
No. of contacts
120-0231-6 73
3
120-0259-5 73
4
120-0227-9 73
120-0228-1 73
7
A
18.26
26.97
31.75
34.92
B
ØC D
E
F
25.4
14.5 2.2 23.6
34.92 3.3
30
19.3
41.28
2.8 29.4
44.45 3.75 21
31.6
G
28.3
35
38
41
ØH
15.6
26.6
32.6
36
I
5/8-24UNEF-2A
1 1/8-18UNEF-2A
1 3/8-18UNEF-2A
1 1/2-18UNEF-2A
5
Receptacle (crimp type)
B
A
ØC
A
M
B
N
T
C
Z
P
B
A
W
K
S
J
D
R
20−29P
H
G
ØH
L
E
F
D
I
E
F
G
H/MS3102A20-29PC(73)
Standard products
HRS No.
No. of
contacts
120-0501-9 73
17
29.36 38.1
H/MS3102A22-14PC(73)
120-0502-1 73
19
31.75 41.28
Part No.
A
B
ØC
D
Ø2.8
d
e
h
c
S
e
l
u
G
ØH
d
e
u
I
n
i
t
n
37
o
c
is
d
e
b
o
t
d
28.5
F
3.3 19.3 2.8 29.4
Contact
Male contact
E
Type
Part No.
HRS No.
Reel contacts
Loose piece
contacts
H/MS-PC1-212
120-0533-5
H/MS-PC1-112
120-0534-8
Applicable wire
size
AWG#24 ∼ 28
(Note) Reel contacts are packaged 7,000 pcs/reel. Loose piece contacts
are packaged 100 pcs/pack.
Receptacle mounting method
When installing a waterproof receptacle, please insert the appropriate O-ring (to be placed between the receptacle and
panel), as shown in the figure on the right.
Mounting panel
Recommended O-ring dimensions.
ØA
O-ring
Inner diameter Thickness of
of O-ring (Ø)
O-ring (Ø)
H/MS3102A10SL-**
17.5
17.5
H/MS3102A18-**
28.5
28.5
H/MS3102A20-**
31.5
31.5
H/MS3102A22-**
34.5
34.5
H/MS3102A-24 **
37.8
37.5
1.5
ØA
Part No.
2
H/MS connector
6
ØA
ØD
Cord clamp
B
Spanner/wrench
flat width (mm)
E
C
H/MS3057-10A(31)
Waterproof type
Part No.
HRS No.
ØA
B
C
ØD
E
d
e
u
Range of applicable cable
diameters (reference)
Applicable shell
size
10SL
H/MS3057-4A(73)
120-0801-2 73
83.8
5.6
17
Ø3.1∼5.6
H/MS3057-10A(31)
120-0802-5 31
30
28.8
72.8
14.3
27
Ø10.3∼14.3
H/MS3057-12A(31)
120-0803-8 31
34
29.8
70.8
15.9
30
Ø11.4∼15.9
H/MS3057-16A(73)
120-0804-0 73
40
33.8
69.3
19
36
Ø14∼19
n
o
sc
tin
18
20.22
24
(Remarks) For various cable diameters, clamping force and waterproof performance may differ depending on the cable type
selected. Please make sure all specifications are met before assembly.
Applicable tools
Type
Item
Manual
Manual
crimping tool
Auto
Automatic
crimping press
h
c
S
e
l
u
CM-105C
ed
Applicator
Extraction tool
t
d
Part No.
H/MS/CC-HT
i
d
e
b
o
HRS No.
150-0206-0
901-0001-0
AP105-H/MS-PC1-1
901-2027-8
H/MS-TP
150-0076-7
Applicable contact
H/MS-PC1-112
---------------------H/MS-PC1-212
H/MS-PC1-112
H/MS-PC1-212
Applicable wire size
AWG#24∼28
---------------------AWG#24∼28
Manual crimping tool
Extraction tool
Automatic crimping press (CM-105C)
7
Connector combinations
Cord clamp
Right-angled plug
Connector for cabtire cable
Straight plug
o
c
is
Connector for flexible conduit
h
c
S
ed
n
i
t
n
d
e
b
o
e
l
u
t
d
d
e
u
Receptacle
Low-height, right-angled plug
Straight connector for flexible
conduit and cabtire cable
Single block
(Remarks) 1. Illustration represents connectors for flexible conduit and cabtire cable as a reference example.
2. The standard and TÜV approved products are compatible with each other.
When using the TÜV approved products for TÜV applications, make sure to use both TÜV approved plugs and
receptacles together.
8
Table of compatibilities for H/MS connectors and the connectors for conduit and cabtire cable
Connectors for flexible conduit
Part number by Nippon Flex Co., Ltd.
H/MS connector
Part No.
Right angle type
H/MS3106A10SL-□□(73)
RCC10*CA12 (with O-ring)
H/MS3108B10SL-□□(73)
RCC10*CA12
H/MS3106A10SL-□□(76)
RCC10*RL-MS10F
H/MS3106A18-□□(73)
Straight type
RCC10 CA18
H/MS3106A18-□□(76)
RCC10*RL-MS18F
H/MS3106A20-□□(73)
RCC10*CA2022 (with O-ring)
H/MS3106B20-□□(73)
RCC10*CA2022
H/MS3106A20-□□(76)
RCC10*RL-MS20F
H/MS3106A22-□□(73)
H/MS3108B22-□□(73)
RCC10*CA2022
H/MS3106A22-□□(76)
RCC10*RL-MS22F
RCC10 CA2428
H/MS3106A24-□□(76)
RCC10*RL-M524F
H/MS3106A-10SL□□(73)
H/MS3108B-10SL□□(73)
H/MS3106A-10SL□□(76)
H/MS3106A18-□□(73)
H/MS3108B18-□□(73)
H/MS3106A18-□□(76)
H/MS3106B20-□□(73)
H/MS3106A20-□□(76)
H/MS3106A22-□□(73)
H/MS3108B22-□□(73)
H/MS3106A22-□□(76)
H/MS3106A24-□□(73)
H/MS3108B24-□□(73)
H/MS3106A24-□□(76)
e
l
u
ACS**CA18
ACS**RL-MS18F
d
e
h
c
S
H/MS3106A20-□□(73)
t
d
ACS**RL-MS10F
ACS**RL-MS20F
ACA**RL-MS18F
--------ACA**RL-MS20F
ACS**CA2022
ACS**RL-MS22F
--------ACA**RL-MS22F
ACS**CA2428
ACS**RL-MS24F
n
i
t
n
BOS 24**
o
c
is
ACS**CA2022
(with O-ring)
NBDC 24
ACA**RL-MS10F
--------ACA**RL-MS24F
d
e
u
BOL 22**
d
e
b
o
--------BOL 20**
BOS 22**
NBDC 24
BOS 22**
NBDC 20(22)
RCC-30*RL-MS24F
BOL 18**
NBDC 20(22)** (with O-ring)
Right angle type
BOS 18**
NBDC 20(22)**
RCC-30*RL-MS22F
Straight type
RCC-30*RL-MS20F
(with O-ring)
NBDC 18
Connectors for cabtire cable
H/MS connector
Part No.
BOL 10*
BOS 10*
NBDC 18
RCC-30*RL-MS18F
CC10*CA2428 (with O-ring)
NBDC 12S**
H/MS3108B24-□□(73)
NBDC 12S** (with O-ring)
RCC10*CA18 (with O-ring)
Right angle
type
Straight type
RCC-30*RL-MS10F
H/MS3108B18-□□(73)
H/MS3106A24-□□(73)
Part number by Daiwa Dengyo Co., Ltd.
BOL 24**
Straight type
YDC 12S* (with O-ring)
YDC 12S*
YDO 10*
YDC 18**
YDO 18**
YDC 20(22)**
YDC 20**
--------YLO 20*
(with O-ring)
YDC 20(22)
YDO 22**
YDC 24** (with O-ring)
YDO 24**
--------YLO 18*
YDO 20(22)** (with O-ring)
YDC 24**
--------YLO 10*
YDC 18** (with O-ring)
YDC 20(22)
Right angle
type
--------YLO 22*
--------YLO 24*
(Remarks) 1. □□ : Indicates contact arrangement/count.
2. ** : The values differ depending on the cable used.
9
Contact arrangement and electrical performance
Shell size
10SL
18
3
10
15
29
2
3
4
7
17
Contact
arrangement
Number of
contacts
Withstanding
voltage
Current
capacity
Insulation
resistance
Contact
resistance
Inner diameter
of solder pot
Preliminary
soldering
AC 1,000V
for 1minute
13A(24.5A)
13A(34.5A)
23A(76.2A)
23A(105.7A)
5,000Mø min. at 500V DC
5mø max.
3mø max.
Ø1.8
Ø2.9
Needed
22
14
Contact
arrangement
d
e
h
c
S
22
13A(49.4A)
5mø max.
Ø1.8
Not necessary
t
d
e
l
u
19
23
d
e
u
13A(44.2A)
n
i
t
n
o
c
s
i
d
e
b
o
Not necessary
Shell size
Number of
contacts
Withstanding
voltage
Current
capacity
Insulation
resistance
Contact
resistance
Inner diameter
of solder pot
Preliminary
soldering
AC 2,000V
for 1minute
4
8
AC 2,000V
for 1minute
46A(152.5A)
23A(100.4A)
5mø max.
1mø max.
3mø max.
Ø1.8
Ø5.3
Ø2.9
Not necessary
Needed
Remarks
1. Figure shows the receptacle contact arrangement as viewed from the interface mating side (plug's socket insert side).
2. Withstanding voltages are derived from test voltages
3. Current capacities are shown in a value per contact. The number in ( ) indicates the connector's total capacity.
4. Contact resistances are shown in a value when measured at DC 1 A.
5. Please contact us for more information.
10
Major specifications of TÜV approved products
Applicable German standard: DIN VDE0627 (connector)
Shell size
10SL
18
22
24
3
10
22
10
Number of contacts
3
4
4
7
Ground contact No.
AC/DC rated voltage
(V)
Rated current (A)
C
D
D
G
7
10
13
17
23
17
23
23 35 46 23 35 46
Wire size (mm2)
0.5
0.75
1.25
2
3.5
2
3.5
3.5 5.5 8 3.5 5.5 8
Contact arrangement
200
Degree of Pollution
Conducting voltage
category
Inner diameter of
solder pot (mm)
500
250
3
2
3
Ⅲ
Ⅱ
Ⅲ
Ø1.8
500
2
d
e
b
o
Ⅱ
Ⅲ
Ø4.5
d
e
u
250
23
n
i
t
n
3
o
c
is
Ø2.6
Remarks
250
3.5
35
5.5
2
Ⅱ
Plug: Ø3.6
Receptacle: Ø5.3
2. Current capacities are shown in a value per contact.
3. The contact numbers with a mark " ◎ " have contacts that are grounded to the outer shell, except for receptacles that are size
24-10.
4. For the receptacles that are size 24-10, the ground contact (contact No.: G) does not ground with the outer shell. Please use
these connectors after grounding the outer shell of the connector with the corresponding contact No.
5. The degree of pollution and conducting voltage categories refer to the environmental condition in which a DIN VDE0110
(insulation coordination for the electric appliances in a constant voltage facility) electric appliance is used, and to the class of
over voltage in the electric appliance.
6. Performance values for other than those shown above are the same as those of the general H/MS series.
d
e
h
c
S
t
d
e
l
u
Usage Recommendations
(1) The power to the circuit should always be off before mating/unmating a connector.
(2) Always use a female connector for the power side of the circuit; this will prevent the likelihood of electric shocks.
(3) Be sure to fully tighten the lock mechanism of the connectors.
(4) Connector performance features such as cable clamping force, cable rotation force, or waterproof performance may differ
depending on the cable construction. Please make sure all specifications are met before assembly.
(5) This product uses silver-plated contacts. Please be aware that silver easily reacts to sulfur gases, causing discoloration or
degradation when exposed to certain environmental conditions as shown below. These conditions include areas with:
• A large amount of dust and dirt
• High density of sulfur dioxide gas, hydrogen sulfide gas, nitrogen dioxide gas, or other gas (Emission gases from vehicles
and factories, etc.)
• Highly fluctuating temperatures, such as close to a heating apparatus
In addition, it is recommended to store the products in their original packaging or similar state in order to prevent
discoloration.
• Temperature: -10 to +60°C, relative humidity: 80% or lower (An environment where temperature and relative humidity are
constant and there is less temperature difference is recommended.)
• Please use the products within six months after delivery.
(For the products in which the storage period is expired, please confirm the ease of soldering for your application
beforehand.)
11
(6) Please confirm the following information when routing the cable after assembling the crimp contacts into the crimp type
connector.
①Do not apply a force of 20N or greater to the cable. Applying a force of 20N or more may result in breakage of the insulator
inside the connector or contact failure resulting from contact disconnect.
②When routing, bend the cables at a curve in order to prevent a force to the crimped portion.
If the cable is bent directly at the edge of the connector and routed, the cables on the outer side will be pulled more than
those on the inner side.
This may result in breakage of the insulator inside the connector or contact failure resulting from contact disconnect.
①Securing force of crimp contact
Connector
Cable
n
i
t
n
d
e
u
Do not apply a force of 20N or more to the cable.
o
c
is
②Cable routing
Route the cable so that no direct load is applied
to the insulator inside the connector.
t
d
e
l
u
d
e
h
c
S
d
e
b
o
Cable routing direction
The cable cannot be directly bent at the edge of the connector during routing.
The cables on the outer side are pulled more than cables on
the inner side, which may result in contacts disconnecting.
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
https://www.hirose.com/
12
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 10/2021. Contents are subject to change without notice for the purpose of improvements.
