0.4 mm Pitch, Space-saving Interface Connectors
GX Series
Small size
5
2.4
Receptacle
(18 conductors)
Receptacle
* Overmold
GX60-18P
* Shown for reference only - not supplied
Fig.1
Overview
Developed as input/output connectors for use in
portable devices requiring reliable high durability
connection.
*Overmold
Features
1. Small size
With a width of 5 mm and 2.4 mm height above the
mounting surface the connectors may be used in
applications where board and volume space is
restricted.(Fig.1)
2. Strong construction
Locks
Single piece shell increases the board retention and
resists rotational forces encountered in demanding
consumer environment
Plug
GX40-18S
* Shown for reference only - not supplied.
3. High durability
Unique lock latches will maintain high retention force
(plug with corresponding receptacle) up to 10,000
cycles, confir ming fully mated condition with a
distinctive tactile “click” sensation.(Fig.2)
Fig.2
ESD protection
4. ESD protection
Increased distance from the edge of the metal shell to
the front of the contacts offers circuit protection from
electrostatic discharge.(Fig.3)
5. RoHS compliant
Despite its miniature size the long
distance from the metal shell edge to
the front of the contacts provides
protection from electrostatic discharge.
All materials and substances used to produce this
product comply with RoHS standards.
Receptacle
Applications
DSC, PDA, notebook computers, mobile phones and
other por table devices requiring high durability
interface connectors.
1.4mm
Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Plug
Front of the contacts
Edge of the metal shell
Fig.3
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2014.8
1
GX Series●0.4 mm Pitch, Space-saving Interface Connectors
Specifications
Current rating
Voltage rating
Ratings
Item
1. Contact resistance
2. Insulation resistance
3. Withstanding voltage
4. Durability
5. Shock
6. Vibration
0.5 A (1 A / contact, each contact at the end, 2 contacts only) Operating temperature range -30ç to +80ç
30 V AC
Storage temperature range -40ç to +85ç
Specification
60 mø max.
100 Mø min.
No flashover or insulation breakdown
Contact resistance: 100 mø max.
No damage cracks or parts dislocation.
No electrical discontinuity of 1 µs or longer.
No damage, cracks or parts dislocation.
7. Temperature cycle
8. Humidity
Insulation resistance: 100 mø min.
Insulation resistance: 10 Mø min.
9. Heat resistance
10. Cold resistance
11. Salt spray test
Conditions
100 mA DC
100 V DC
100 V AC / 1 minute
10,000 cycles
2
Acceleration of 490m/s , 11 ms duration, sine halfwave, 3 cycles, 3 axis
Frequency: 10 to 55 Hz, single amplitude of 0.75 mm,
3 directions for 2 hours
Temperature:-55°C➝+15ç to 35ç➝+85ç➝+15ç to 35ç
Time : 30min.➝2min. to 3min.➝30min.➝2min. to 3 min.
5 cycles
96 hours at a 40 ±3ç, RH of 90 to 95%,
then leave for 1 to 2 hours at normal temperature and
humidity
96 ±4 hours at +85 ±2ç
96 ±4 hours at -40 ±3ç
48 hours at a concentration of 5% ±1%, and humidity of
85 ±3ç
Materials
●Receptacle
Part
Material
Finish
Remarks
Insulator
Synthetic resin
Color: Black
UL94V-0
Contacts
Copper alloy
Gold plated
Shell
Stainless steel
Selective gold plated
●Plug
Part
Material
Finish
Remarks
Insulator
Synthetic resin
Color: Black
UL94V-0
Contacts
Copper alloy
Gold plated
Shells
Stainless steel
Nickel plated
Lock
Stainless steel
Ordering information
●Receptacle
GX60 - 18 P
q
w
e
●Plug
GX40 - 18 S
q
2
w
e
q Series name: GX60 (Receptacles)
GX40 (Plugs)
w Number of contacts : 18
e Contacts type
P: Male
S: Female
Receptacle
Part No.
HRS No.
Packaging
GX60-18P
247-0001-3
1,500 pcs/reel
RoHS
6.8
(0.6)
5
0.4
0.15
(13.4)
12.5
No.1
(3.5)
2.4
(0.78)
0.55
0.75
No.18
0.25
(0.6)
12.25
0.9
2.35
4.5
0.5
9
.8
Ø0
All dimensions: mm
Recommended PCB mounting pattern
(H
ol
1(Land)
0.7
0.5
e)
12.25
9
6.8
0.4
0.23 No.18
1.2(Land)
0.6(Through hole)
2.35 1
3.8
Ø1
1.4
No.1
3(Land)
6(Land)
12.5
No conductive traces
1.3(Through hole)
1.9(Land)
3.3(Land)
Note : Order by number of reels.
PCB edge
All dimensions: mm
3
Plug
Part No.
HRS No.
Packaging
GX40-18S
247-0002-6
1
RoHS
10.7
11.5
22.6
No.1
(5.6)
6
5
3
6.6
14.5
(6.9)
(7.7)
No.18
14.7
All dimensions: mm
●Assembly (insulator/ contact/lock)
6
4
9.7
14
A
3.3
6.8
pattern (Thickness=0.6mm)
P=0.4
A
A-A
(0.3)
1.5
0.4
1.5
PCB installed
6.8
Contact Number
Identification
1.5
02 05 08 11 14 17
5.9(MAX)
0.8
All dimensions: mm
03 06 09 12 15 18
P=0.4(Hole pitch)
0.4
1.5
●Assembled components - Supplied non-terminated, without overmold
18-Ø0.55(MIN)
01 04 07 10 13 16
PCB (Thickness=0.6mm)
10.5(MAX)
All dimensions: mm
4
Packaging Specifications
●Embossed carrier tape dimensions
Unreeling direction
12
2
Note : Tape and reel packaging (1,500 pcs/reel).
●Reel Dimensions
26
2
Ø1
3
Ø380
Unreeling direction
Recommended Solder Reflow Profile
250
220
Temperature(ç)
24
11.5
.5
Ø1
1.75
4
The temperature profiles are based on
the above conditions.
In individual applications the actual
temperature may vary, depending on
solder paste type, volume / thickness
and board size / thickness.
Consult your solder paste and
equipment manufacturer for specific
recommendations.
240ç
230ç min.
190
160
Time(Seconds)
150~180ç
60s
230ç min.
30s
5
USA:
HIROSE ELECTRIC (U.S.A.), INC. Headquarters
2688 Westhills Court, Simi Valley, CA 93065-6235
Phone : +1-805-522-7958
Fax : +1-805-522-3217
http://www.hiroseusa.com
USA:
HIROSE ELECTRIC (U.S.A.), INC. San Jose Office
3255 Scott Boulevard, Building 7, Suite 101
Santa Clara, CA 95054
Phone : +1-408-253-9640
Fax : +1-408-253-9641
USA:
HIROSE ELECTRIC (U.S.A.), INC. Detroit Office (Automotive)
37677 Professional Center Drive, Suite #100C
Livonia, MI 48154
Phone : +1-734-542-9963
Fax : +1-734-542-9964
THE NETHERLANDS:
HIROSE ELECTRIC EUROPE B.V.
Hogehillweg #8 1101 CC Amsterdam Z-O
Phone : +31-20-6557460
Fax : +31-20-6557469
http://www.hiroseeurope.com
GERMANY:
HIROSE ELECTRIC EUROPE B.V. German Branch
Herzog-Carl-Strasse 4 D-73760 Ostfildern
(Scharnhauser Park)
Phone : +49-711-4560-02-1
Fax : +49-711-4560-02-299
http://www.hirose.de
GERMANY:
HIROSE ELECTRIC EUROPE B.V. Nuernberg Office
Muggenhofer Str. 136 90429 Nuernberg
Phone : +49-911 32 68 89 63
Fax : +49-911 32 68 89 69
UNITED KINGDOM:
Hirose Electric Europe BV (UK Branch)
4 Newton Court, Kelvin Drive, Knowlhill,
Milton Keynes, MK5 8NH
Phone : +44-1908 202050
Fax : +44-1908 202058
CHINA:
HIROSE ELECTRIC (SHANGHAI) CO., LTD.
1601, Henderson Metropolitan, NO.300, East Nanjing
Road, Huangpu District, Shanghai, China 200001
Phone : +86-21-6391-3355
Fax : +86-21-6391-3335
http://www.hirose-china.com.cn
CHINA:
HIROSE ELECTRIC (SHANGHAI) CO.,LTD. BEIJING BRANCH
A1001, Ocean International Center, Building 56# East 4th
Ring Middle Road, ChaoYang District, Beijing, 100025
Phone : +86-10-5165-9332
Fax : +86-10-5908-1381
CHINA:
HIROSE ELECTRIC TECHNOLOGIES (SHENZHEN) CO., LTD.
Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre,
5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008
Phone : +86-755-8207-0851
Fax : +86-755-8207-0873
HONG KONG:
HIROSE ELECTRIC HONGKONG TRADING CO., LTD.
Room 1001, West Wing, Tsim Sha Tsui Centre, 66
Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong
Phone : +852-2803-5338
Fax : +852-2591-6560
http://www.hirose-hongkong.com.hk
TAIWAN:
HIROSE ELECTRIC TAIWAN CO., LTD.
103 8F, No.87, Zhengzhou Rd., Taipei
Phone : +886-2-2555-7377
Fax : +886-2-2555-7350
http://www.hirose-taiwan.com.tw
KOREA:
SINGAPORE:
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD Delhi Liaison Office
HIROSE KOREA CO., LTD.
HIROSE ELECTRIC SINGAPORE PTE. LTD.
1261-10, Jeoungwhang-Dong, Shihung-City, 10 Anson Road #26-1, International Plaza Suite No. 606 5th Floor SB Tower 1A/1 Sector
16 A Filmcity Noida 201301 Uttar Pradesh-India
Kyunggi-Do 429-450
079903, Singapore
Phone : +91-120-4804917
Phone : +82-31-496-7000,7124
Phone : +65-6324-6113
Fax : +91-120-4804949
Fax : +82-31-496-7100
Fax : +65-6324-6123
http://www.hirose-singapore.com.sg
http://www.hirose.com/sg/
http://www.hirose.co.kr
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. Bangalore Liaison office
Unit No.03, Ground Floor, Explorer Building International Tech
Park Whitefield Road, Bangalore 560066 Karnataka, India
Phone : +91-80-4120 1907
Fax : +91-80-4120 9908
6
MALAYSIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD (Representative office)
1-10-07, Suntech @ Penang Cybercity (1164),Lintang
Mayang Pasir 3,11950, Bayan Baru, Penang, Malaysia.
Phone : +604-619-2564
Fax : +604-619-2574
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 08/2014. Contents are subject to change without notice for the purpose of improvements.
