Crimp
EH CONNECTOR
Radial Tape
Disconnectable Crimp style connectors
2.5mm
(.098") pitch
Features ––––––––––––––––––––––––
• Compact and slim
This connector is designed to be compact and unusually thin.
It measures only 8.1mm (.319") high after mounting and is just
3.8mm (.150") wide.
• Highly reliable contact
The contact has long dimples near the center that ensure
continuity of low voltage and low current circuits at all times,
even under conditions of vibration and abusive prying.
• Polarizing guides
The header and housing have guides to prevent improper
mating.
• Whisker prevention
The contact material is treated with a reflow process, and the
square post is copper-undercoated and tin/lead-plated for
This, the thinnest, 2.5mm (.098") pitch
connector, is 8.1mm (.319") in height after
mounting and 3.8mm (.150") in width. It is
designed to meet the demand for the highdensity connection of internal wires to
printed circuit boards. It is compact, highly
reliable and low in cost.
whisker prevention.
• Easy and effective crimping
Although the contact is compact, it has a long wire strip length,
2.6±0.4mm (.102"±.016"). This long length is very useful for
automatic crimping and when crimping shielded wires.
2
3
4
5
B
JST
Specifications –––––––––––––––––––
• Current rating: 3A AC, DC (AWG#22)
• Voltage rating: 250V AC, DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/10m Ω max.
After environmental testing/20m Ω max.
• Insulation resistance:
1,000M Ω min.
• Withstanding voltage: 800V AC/minute
• Applicable wire: AWG #32 to #22
• Applicable PC board thickness: 0.8 to 1.6mm(.031" to .063")
* Contact JST for details.
Standards ––––––––––––––––––––––
2
Recognized E60389
Certified LR20812
R75089
51
EH
CONNECTOR
Contact –––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
Model No.
5.7(.224)
2.85(.112)
2.05(.081)
1.1(.039)
Applicable wire
Q'ty /
AWG # Insulation O.D. mm(in.) reel
mm2
SEH-001T-P0.6
0.05 to 0.3
30 to 22
1.0 to 1.9(.039 to .075)
SEH-003T-P0.6L
0.032 to 0.08
32 to 28
0.5 to 1.1(.020 to .043)
10,000
2.0(.079)
Material and Finish
Phosphor bronze, tin-plated
Note: 1. Contact JST for gold-plated contacts.
¨ V approved.
2. SEH-003T-P0.6L is not TU
1.6(.063)
Housing –––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
Circuits
3
6
3.8(.150)
7
6.5(.256)
2
JST
1
0.6
(.024)
2.25
(.089) 2.5(.098)
B
A
Circuit No.1
0.7
(.028)
Model No.
Dimensions mm(in.)
A
B
Q'ty /
bag
2
EHR- 2
2.5( .098)
7.0( .276)
1,000
3
EHR- 3
5.0( .197)
9.5( .374)
1,000
4
EHR- 4
7.5( .295)
12.0( .472)
1,000
5
EHR- 5
10.0( .394)
14.5( .571)
1,000
6
EHR- 6
12.5( .492)
17.0( .669)
1,000
7
EHR- 7
15.0( .591)
19.5( .768)
1,000
8
EHR- 8
17.5( .689)
22.0( .866)
1,000
9
EHR- 9
20.0( .787)
24.5( .965)
1,000
10
EHR-10
22.5( .866)
27.0(1.063)
1,000
11
EHR-11
25.0( .984)
29.5(1.161)
1,000
12
EHR-12
27.5(1.083)
32.0(1.260)
1,000
13
EHR-13
30.0(1.181)
34.5(1.358)
1,000
14
EHR-14
32.5(1.280)
37.0(1.457)
1,000
15
EHR-15
35.0(1.378)
39.5(1.555)
1,000
Material
Nylon 66, UL94V-0, natural (white)
As the color identification,
the following alphabet shall be put in the underlined part.
For availability, delivery and minimum order quantity, contact JST.
ex.
52
EHR-2-o o(blank)…natural (white)
K…black R…red TR…tomato red E…blue Y…yellow
L…lemon yellow M…green O…orange N…brown PL…purple
PK…pink H…gray LE…light blue FY…vivid yellow
EH
CONNECTOR
Shrouded header –––––––––––––––––––––––––––––––––––––––––––––––––––––––––
The shrouded headers are interchangeable with those of the HR crimp style and insulation displacement connectors.
Model No.
Side entry
type
A
2
B 2B-EH-A
S 2B-EH
2.5( .098)
3
B 3B-EH-A
S 3B-EH
5.0( .197)
4
B 4B-EH-A
S 4B-EH
7.5( .295)
5
B 5B-EH-A
S 5B-EH
6
B 6B-EH-A
7
B
3.8(.150)
0.64
(.025)
2.5(.098)
A
1.6(.063)
Circuit No.1
(3 to 15 circuits)
Top entry
type
Side entry
type
7.5( .295)
1,000
1,000
10.0( .394)
1,000
1,000
12.5( .492)
1,000
1,000
10.0( .394)
15.0( .591)
1,000
1,000
S 6B-EH
12.5( .492)
17.5( .689)
1,000
500
B 7B-EH-A
S 7B-EH
15.0( .591)
20.0( .787)
1,000
500
8
B 8B-EH-A
S 8B-EH
17.5( .689)
22.5( .886)
500
500
9
B 9B-EH-A
S 9B-EH
20.0( .787)
25.0( .984)
500
500
10
B10B-EH-A
S10B-EH
22.5( .866)
27.5(1.083)
500
500
11
B11B-EH-A
S11B-EH
25.0( .984)
30.0(1.181)
500
250
12
B12B-EH-A
S12B-EH
27.5(1.083)
32.5(1.280)
500
250
13
B13B-EH-A
S13B-EH
30.0(1.181)
35.0(1.378)
250
250
14
B14B-EH-A
S14B-EH
32.5(1.280)
37.5(1.476)
250
250
15
B15B-EH-A
S15B-EH
35.0(1.378)
40.0(1.575)
250
250
3.2(.126)
5.1(.201)
6.0(.236)
3.3(.130)
3.8(.150)
Circuit No.1
2.5
2.5 (.098)
(.098)
Q'ty / box
Dimensions mm.(in)
Top entry
type
6.0(.236)
3.3(.130)
Circuits
3.2(.126)
Top entry type
(2 circuits)
B
Material and Finish
Post: Brass, copper-undercoated, tin/lead plated
Wafer: Nylon 66, UL94V-0, natural (white)
0.64
(.025)
1.6(.063)
Note:
1. Also available and identified as model BxxB-EH is a top entry type having a
post extension length of 4.0mm(.157")
¨ V approved.
2. Top entry type headers are not TU
A
B
Side entry type
4.2(.165)
Circuit No.1
2.5
(.098)
2.5
(.098)
0.64
(.025)
6.7(.264)
6.0(.236)
2.2
(.087) 5.2(.205)
4.0(.157)
ex.
B2B-EH-A-o o(blank)…natural (white)
K…black R…red E…blue Y…yellow M…green
3.2
(.126)
A
B
ex.
S2B-EH-o o(blank)…natural (white)
L…lemon yellow M…green O…orange N…brown P…purple
PC board layout (viewed from soldering side) and Assembly layout –––––––––––––––––––
Side entry type
1.9
(.074)min.
6.7
(.264)min.
2.5±0.05
(.098±.002)
0.9 + 00.1
(.035 +.004
0 )dia.
10.3(.406)
8.2(.323)
4.2
(.165)
0.9 + 00.1
(.035 +.004
0 )dia.
3.8
(.150)
7.5(.295)
2.2
(.087)min.
2.5±0.05
2.5
(.098±.002) (.098)min.
0.6(.024)
Top entry type
Note:
1. Tolerances are non-cumulative: ±0.05mm(±.002" ) for all centers.
2. Hole dimension differ according to the kind of PC board and piercing method. If PC boards made of hard material such as FR-4 are used, the hole dimensions
should be larger. The dimensions above should serve as a guideline. Contact JST for details.
53
EH
CONNECTOR
Shrouded header on radial-tape –––––––––––––––––––––––––––––––––––––––––––––
•The shrouded headers are interchangeable with those of the HR crimp style and insulation displacement connectors .
•Shrouded headers on radial-tape are not TU¨V approved.
TS type
(2 circuits)
4.4
(.173)
2.2(.087)
5.4(.213)
[1.0(.039)]
6.5
1.5(.059) (.255)
7.5(.295)
2.5(.098)
0.64(.025) dia.
Dimensions mm(in.)
Circuits
Model No.
2
B2B-EH-TS
1,400
3
B3B-EH-TS
5.0(.197)
10.0(.394)
1,400
4
B4B-EH-TS
7.5(.295)
12.5(.492)
700
5
B5B-EH-TS
10.0(.394)
15.0(.591)
700
6
B6B-EH-TS
12.5(.492)
17.5(.689)
700
7
B7B-EH-TS
15.0(.591)
20.0(.787)
700
8
B8B-EH-TS
17.5(.689)
22.5(.886)
700
A
B
Q'ty /
box
Material and Finish
Pin: Brass, copper-undercoated, tin/lead-plated
ex.
(3 to 8 circuits)
B
A
0.64(.025) dia.
5.6(.220)
4.4
(.173)
2.2(.087)
[1.0(.039)]
1.5(.059)
2.8(.110) 6.5(.256)
2.5(.098)
2.5(.098)
0.64(.025) dia.
TV4 type
B
A
0.64(.025)
54
5.6(.220)
4.4
(.173)
2.2(.087)
2.8(.110) 6.5(.256)
2.5(.098)
2.5(.098)
B2B-EH-TS-o o(blank)…natural (white)
K…black R…red E…blue Y…yellow M…green N…brown
[0.7(.028) dia.]
[0.7(.028) dia.]
Dimensions mm(in.)
Circuits
Model No.
3
B3B-EH-TV4
5.0(.197)
10.0(.394)
1,400
4
B4B-EH-TV4
7.5(.295)
12.5(.492)
700
5
B5B-EH-TV4
10.0(.394)
15.0(.591)
700
6
B6B-EH-TV4
12.5(.492)
17.5(.689)
700
7
B7B-EH-TV4
15.0(.591)
20.0(.787)
700
8
B8B-EH-TV4
17.5(.689)
22.5(.886)
700
A
B
Material and Finish
Post: Brass, copper-undercoated, tin/lead-plated
Q'ty /
box
EH
CONNECTOR
Taping specifications ––––––––––––––––––––––––––––––––––––––––––––––––––––––
2circuits: 5.1(.201)
3 to 8 circuits: 3.85(.152)
6.0
(.236)
18.0(.709)
20.0(.787)
9.0(.354)
2 and 3 circuits: 12.7(.500)
4 to 8 circuits: 25.4(1.000)
4.0
(.157)dia.
2circuits: 2.5(.098)
3 to 8 circuits: 5.0(.197)
12.7(.500)
Note: Conforms to JIS C0825.
Packaging specifications –––––––––––––––––––––––––––––––––––––––––––––––––––
D
Distance between the end of the tape and the first connector's center
line (either end)
Tail tape
H
Lead tape
TERMIN
ALS &
CONN
ECTORS
R
W
Package type
Flat pack (zigzag folded)
Distance between folds
24 indexing holes per fold (304.8mm/12")
Box size
(316x45x330mm)12.4"(W)x1.8"(D) x13.0"(H)
tape and the first connector´s
center line (either end)
19.05mm(.750")
0.9 + 00.1
(.035 +0.004 )dia.
4.4
(.173)
6.5(.256)
8.6(.339)
2.2
(.087)min.
2.5±0.05
2.5
Note:
55
EH
CONNECTOR
Applicator for the semi-automatic press AP-K2N –––––––––––––––––––––––––––––––
Contact
SEH-001T-P0.6
SEH-003T-P0.6L
56
Crimp applicator MKS-L(-10)
with safety cover
without safety cover
Compact crimp applicator MKS-LS
with safety cover
Strip-crimp applicator MKS-SC
with safety cover
APLMK SEH001-06
APLNC SEH001-06
APLMKLS SEH001-06
APLLSNC SEH001-06
APLSC SEH001-06
APLMK SEH003-06
APLNC SEH003-06
APLSC SEH003-06
