7Q-27.000MBG-T
7Q-27.000MBG-T
    TXC(台晶)
    SMD-4
    有源晶振 27MHz 3.3V SMD-4
7Q-27.000MBG-T 数据手册
come visit our site http://www.txccorp.com SMD TCXO 3.2 X 2.5 X 1.0 mm 7Q Series Oscillators Series Think of Frequency Think of Features .Temperature Stability: ± 0.5 ppm ~ ± 2.0 ppm. .Operating Temperature Range: - 30 ℃ ~ 85 ℃. BT .Supply Voltage: 1.8 V ~ 3.3 V. A .Voltage Control Function Available. 0 P1 2 k0 3 T3 .Frequencies: 16.367667 MHz, 16.368 MHz, 16.369 MHz, 16.8 MHz, 19.2 MHz, 20 MHz, 26 MHz, 33.6 MHz, 38.4 MHz, 40 MHz. .Applications: GPS, WiMAX, Cellular and Wireless Communications. .RoHS Compliant / Pb Free. Electrical Specifications 7Q Clipped Sinewave Output Load 10KΩ // 10 pF Oscillation Mode Fundamental Supply Voltage 1.8 ~ 3.3 V Frequency Range 13 ~ 52 MHz Clipped Sinewave Output Voltage 0.8 Vp-p Min. Vs. Temperature ( - 30 ~ + 85 ℃ ) Frequency Stability ± 0.2 ppm Max. Vs. Supply Voltage ( Vcc = Typical ± 0.1 V ) ± 0.2 ppm Max. Frequency Tolerance at 25 ℃ after 2 Reflows with Typical Applied to Auto Frequency Control Pin Slope of Frequency Drift Storage Temperature Range Auto Frequency Control ( AFC ) Range * Supply Current Start-up Time Harmonics Phase Noise at 1 kHz offset Aging ( at 25 ℃ ) ± 0.5 / ± 2.0 ppm Vs. Load ( Load varies ± 10 % ) ± 2.5 ppm Max. ± 0.1 ppm / ℃ Typical ; ± 0.5 ppm / ℃ Max. - 40 ~ + 85 ℃ ± 7 ~ ± 16 ppm (1.4+/- 1V) 2.0 mA Max. 5 ms Max. - 5 dBc Max. - 130 dBc / Hz ± 1 ppm / year Max. * AFC Range is selective and disable is acceptable. Dimensions Remark : Specification subject to change without prior notice. Please confirm with our sales. http://www.txccorp.com Item / Type Output Type Units: mm 91
7Q-27.000MBG-T
物料型号:7Q系列振荡器
器件简介: - 温度稳定性:±0.5 ppm至±2.0 ppm - 工作温度范围:-30℃至85℃ - 供电电压:1.8 V至3.3 V - 可选的电压控制功能 - 提供多种频率选项,包括16.367667 MHz, 16.368 MHz等
引脚分配: - Pin1: AFCarGHD - Pin2: OND - Pin3: OUTPUT - Pin4: VCC
参数特性: - 输出类型:削波正弦波 - 输出负载:10kΩ//10pF - 振荡模式:基波 - 频率范围:13-52MHz - 削波正弦波输出电压:最小0.8Vp-p - 频率稳定性:温度变化时±0.5/±2.0ppm,负载变化时±0.2ppm最大,供电电压变化时±0.2ppm最大 - 频率容差:在25°C下,典型值应用于自动频率控制引脚后±2.5ppm最大 - 频率漂移斜率:±0.1 ppm/C典型值;±0.5ppm/C最大值 - 存储温度范围:-40℃至+85℃ - 自动频率控制(AFC)范围:±7至±16ppm(1.4±1V) - 供电电流:最大2.0mA - 启动时间:最大5ms - 谐波:-5 dBc最大值 - 1kHz偏移处的相位噪声:-130 dBc/Hz - 老化(在25°C):±1 ppm/年最大值
功能详解: - AFC范围是可选择的,也可以禁用。
应用信息: - 适用于GPS、WiMAX、蜂窝和无线通信。
封装信息: - 封装尺寸为3.2 x 2.5 x 1.0 mm,文档还提供了顶视图和底视图以及推荐的焊盘图案。
7Q-27.000MBG-T 价格&库存
很抱歉,暂时无法提供与“7Q-27.000MBG-T”相匹配的价格&库存,您可以联系我们找货
