SWR201-NRTN-S05-RL-WH 数据手册
Wafers
SWR201 Series Single Row Wafer 2.0 mm [.079”] Contact Centers, Straight/Right Angle
SPECIFICATIONS
Insulator Material: Nylon, UL 94V-0 Color: White
Contact Material: Brass
Contact Resistance: 20 milli Ohms Max
Contact Plating: .000020” Min. Nickel Underplate,
Pure Tin, Bright Overall
Current Rating: 1 Amp
Dielectric Withstanding Voltage: 800 VAC
Insulator Resistance: 1000 Megohms Minimum
Operating Temperature: -25°C to +85°C
Voltage Rating: 125 VAC/DC
Mates with SWH201 Series Single Row Housing
PCB LAYOUT
A
2.00 [.079”]
0.80±0.05 [.031” ±.002”]
Wafers
P.C. BOARD THICKNESS: 0.80 [.031”] - 1.60 [.063”]
PART NUMBER OPTIONS
SWR201-NRTN-S16 -SA - WH
TERMINATION TYPE
SA = End Pins Kink Right
RL = Right Angle With Kinked End Pins
NUMBER OF POSITIONS
02 thru 16
See Chart Below
PART NUMBER
POSITIONS/
CONTACTS
SWR201-NRTN-S02-_ _-WH
SWR201-NRTN-S03-_ _-WH
SWR201-NRTN-S04-_ _-WH
SWR201-NRTN-S05-_ _-WH
SWR201-NRTN-S06-_ _-WH
SWR201-NRTN-S07-_ _-WH
SWR201-NRTN-S08-_ _-WH
SWR201-NRTN-S09-_ _-WH
SWR201-NRTN-S10-_ _-WH
SWR201-NRTN-S11-_ _-WH
SWR201-NRTN-S12-_ _-WH
SWR201-NRTN-S13-_ _-WH
SWR201-NRTN-S14-_ _-WH
SWR201-NRTN-S15-_ _-WH
SWR201-NRTN-S16-_ _-WH
02/02
03/03
04/04
05/05
06/06
07/07
08/08
09/09
10/10
11/11
12/12
13/13
14/14
15/15
16/16
A
mm
2.00
4.00
6.00
8.00
10.00
12.00
14.00
16.00
18.00
20.00
22.00
24.00
26.00
28.00
30.00
B
in
0.079
0.157
0.236
0.315
0.394
0.472
0.551
0.630
0.709
0.787
0.866
0.945
1.024
1.102
1.181
mm
5.90
7.90
9.90
11.90
13.90
15.90
17.90
19.90
21.90
23.90
25.90
27.90
29.90
31.90
33.90
in
0.232
0.311
0.390
0.469
0.547
0.626
0.705
0.783
0.862
0.941
1.020
1.098
1.177
1.256
1.335
DIMENSIONS Dimensions in [ ] are in inches, all others are in millimeters.
SWR201-NRTN-S_ _-SA-WH
SWR201-NRTN-S_ _-RL-WH
6.00 [.236]
6.00 [.236]
3.40 [.134]
B
2.00 [.079] TYP
0.50 [.020] SQ.
A ±0.20 [±.008]
B
4.80 [.189]
1.70 ±0.20 [.067 ±.008]
3.40 [.134]
0.50 [.020] SQ.
4.60 [.181]
2.00 [.079] TYP.
A
132
www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com
SWR201-NRTN-S05-RL-WH 价格&库存
很抱歉,暂时无法提供与“SWR201-NRTN-S05-RL-WH”相匹配的价格&库存,您可以联系我们找货
