BK010-12-C-0850-0864-0508-G 数据手册
H
B±0.30
Dimensions
Number of
Contacts
5.08
2
6.25
D+1.0
5.50
G
F
1.14 sq. Pin
2.10
Pin 1
Pin 1
Recommended PCB Layout
General Tolerance ±0.05
Solder Area
A±0.25
Either Direction
At The Top
Either Direction
At The Top
2.50
D
E±0.25
0.12
Specifications
5.00
2° max. Toe
C±0.25
12.00
5.08±0.15
2° max. Sway
20mm Maximum
E
5.00
XX
XXXX
C
XXXX
XXXX
X
B
10.16
3
10.16 15.24
4
15.24 20.32
5
20.32 25.40
6
25.40 30.48
7
30.48 35.56
8
35.56 40.64
9
40.64 45.72
10
45.72 50.80
11
50.80 55.88
12
55.88 60.96
13
60.96 66.04
14
66.04 71.12
15
71.12 76.20
Material
Insulator: LCP, UL94V-0
Contact:Brass
Plating
Contact:Tin All Over
Underplating: Nickel all over
D±0.30
Electrical
Current Rating: 7.9 Amp Per Pin
Contact Resistance: 30 mΩ max.
Insulation Resistance: 1500 MΩ min.
Dielectric Withstand Voltage: 1500 V AC
Ordering Grid
BK010
A
5.08
Request Samples
and Quotation
C
B
(Available from 3 contacts and above)
D = Tube (Available from 3 contacts and above)
G = Box (Only available in 2 contacts)
Contact Plating
C= Tin All Over
Dimension C (1/100mm) (Post Height)
0850 = 8.50mm (Standard)
Or specify Custom Post Height
(Maximum 1500=15.00mm)
(Minimum 0050=0.50mm)
A
Dimension E (1/100mm) (PCB to Top of Insulator)
0405 = 4.05mm (Standard-Minimum )
Or specify custom dimension
Dimension D (1/100mm) (Footprint Width)
1000 =10.00mm (Standard)
Or specify Custom Footprint Width
(Tooling charge may apply)
Mates with (Subject to Pin Length)
BK015
Part Number
Product Description
BK010
5.08mm Pitch Pin Header, Single Row,
Surface Mount, Vertical
Drawing Date
10th August 2017
By
Detail
1
Mechanical & Environmental
Operating Temperature: -40°C to +105°C
Soldering Process
IR Reflow: 260°C for 10 sec.
Manual Solder: 350°C for 3-5 sec
Packing Options
E = Tube with Cap (Standard)
No. of Contacts
02 to 15
2
3
4
Revision
Date
5
CC
Tolerances (Except as Noted)
Drawing
Release
A
16/08/17
X. ± 0.30
X.° ± 5°
X.X° ± 3°
X.X ± 0.25
X.XX ± 0.15 X.XX° ± 2°
X.XXX ± 0.10 X.XXX° ± 1°
Length
Angle
6
Units:
Metric (mm)
C
3rd Angle Projection
7
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CC
8
Sheet No.
1/1
BK010-12-C-0850-0864-0508-G 价格&库存
很抱歉,暂时无法提供与“BK010-12-C-0850-0864-0508-G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+13.310711+1.72294
- 20+10.7785920+1.39518
- 100+9.61781100+1.24493
- 500+8.58435500+1.11116
- 1000+8.174551000+1.05811
- 5000+7.297395000+0.94457
- 10000+6.9494610000+0.89954
