BH010-02-C-0850-0840-0573-G 数据手册
Number of
Contacts
H
1.80
6.35
D+1.0
3.96
G
The cap used above 3pins
F
Pin 1
Pin 1
Recommended PCB Layout
General Tolerance ±0.05
2° max. Toe
C±0.25
E±0.25
3.18
D
XX
C
XXXX
XXXX
XXXX
(Available from 3 contacts and above)
D = Tube (Available from 3 contacts and above)
G = Box
Contact Plating
C=Tin All Over
Dimension E (1/100mm) (PCB to Top of Insulator)
0573 = 5.73mm (Standard)
Or specify custom dimension
(Minimum 0482=4.82mm)
Dimension C (1/100mm) (Post Height)
0850 = 8.50mm (Standard)
Or specify Custom Post Height
(Maximum 1500=15.00mm)
(Minimum 0050=0.50mm)
1
Request Samples
and Quotation
Packing Options
E = Tube with Cap (Standard)
No. of Contacts
02 to 18
A
X
Dimension D (1/100mm) (Footprint Width)
0840 = 8.40mm (Standard)
Or specify Custom Footprint Width (Tooling charge may apply)
2
3
4
7.92
3
7.92 11.88
4
11.88 15.84
5
15.84 19.80
6
19.80 23.76
7
23.76 27.72
8
27.72 31.68
11
39.60 43.56
12
43.56 47.52
Material
Insulator: LCP, UL94V-0
Contact:Brass
13
47.52 51.48
14
51.48 55.44
15
55.44 59.40
Plating
Contact:Tin All Over
Underplating: Nickel all over
16
59.40 63.36
17
63.36 67.32
18
67.32 71.28
Mechanical & Environmental
Operating Temperature: -40°C to +105°C
Soldering Process
IR Reflow: 260°C for 10 sec.
Manual Solder: 350°C for 3-5 sec
Ordering Grid
BH010
B
0.15
3.96
31.68 35.64
Electrical
Current Rating: 7.9 Amp Per Pin
Contact Resistance: 30 mΩ max.
Insulation Resistance: 1000 MΩ min.
Dielectric Withstand Voltage: 1000 V AC
D±0.30
1.14 sq. Pin
C
5.00
Either Direction
E
20mm Maximum
12.00
Either Direction
2
35.64 39.60
Specifications
5.00
2° max. Sway
B
9
A±0.25
3.96±0.15
A
10
Solder Area
B±0.38
Dimensions
Mates with (Subject to Pin Length)
BH015
Part Number
Product Description
BH010
3.96mm Pitch Pin Header, Single Row,
Surface Mount, Vertical
Drawing Date
10th August 2017
By
Detail
Revision
Date
5
CC
Tolerances (Except as Noted)
Drawing
Release
A1
14/07/21
X. ± 0.30
X.° ± 5°
X.X° ± 3°
X.X ± 0.25
X.XX ± 0.15 X.XX° ± 2°
X.XXX ± 0.10 X.XXX° ± 1°
Length
Angle
6
Units:
Metric (mm)
C
3rd Angle Projection
7
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CC
8
Sheet No.
1/1
BH010-02-C-0850-0840-0573-G 价格&库存
很抱歉,暂时无法提供与“BH010-02-C-0850-0840-0573-G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+5.306911+0.68693
- 10+4.5215810+0.58527
- 150+3.73332150+0.48324
- 600+3.38485600+0.43814
- 1050+3.253671050+0.42116
- 5100+2.910285100+0.37671
- 10050+2.7743210050+0.35911
