BG030-06-A-0450-0300-N-G
    GCT
    插件,P=2.54mm
    排针 间距:2.54mm 1x6P 直插
BG030-06-A-0450-0300-N-G 数据手册
Ø1 .02 2.54 2.54 1 2.50 H Number of Contacts Recommended PCB Layout G 2° Max. Sway & Toe B±0.38 (Either Direction At The top) A±0.25 Specifications Pin 0.64 sq. Material Insulator: Standard: Polyamide, Nylon 6T, UL94V-0 Options: Polymer, LCP, UL94V-0 Polyester, PBT, UL94V-0 Contact: Copper Alloy Mechanical & Environmental Operating Temperature: -40°C to +105°C C±0.2 2.50 2.54 D Soldering Process Nylon 6T (Standard) IR Reflow: 260°C for 10 sec. Wave: 230°C for 5-10 sec Manual Solder : 350°C for 3-5 sec LCP (Option) IR Reflow: 260°C for 10 sec. Wave: 250°C for 5-10 sec. Manual Solder: 350°C for 3-5sec PBT (Option ) Manual Solder: 330°C for 3-5sec (not suitable for hi-temp process) Ordering Grid BG030 C B XX X XXXX XXXX No. of Contacts 01 to 40 Contact Plating A = Gold Flash All Over (Standard) B = Selective Gold Flash Contact Area/Tin On Tail C = Tin All Over G = 10µ" Gold Contact Area/Tin On Tail I = 30µ" Gold Contact Area/Tin On Tail L = Matte Tin Request Samples and Quotation Insulator Material N = Nylon 6T (Standard) P = PBT L = LCP Mates with BG090 BG115 BG145 Dimension D (1/100mm) (Tail Length) 0300 = 3.00mm (Standard) Or specify custom Tail Length e.g. 0250 = 2.50mm (Maximum 2000=20.00mm) (Minimum 0050=0.50mm) Or specify custom Post Height e.g. 0250 = 2.50mm (Maximum 2000=20.00mm) (Minimum 0050=0.50mm) 1 X Packing Options G = Plastic Box (Standard) B = Tape & Reel with Cap D = Tube E = Tube with Cap Dimension C (1/100mm) (Post Height) 0400 = 4.00mm (Standard) 0450 = 4.50mm (Standard) 0650 = 6.50mm (Standard) A X (Subject to Pin Length) BG095 BG096 BG100 BG110 BG125 BG126 BG130 BG135 BG205 BG230 BG090 Recommended mating length 4.00mm BG095 Recommended mating length 4.00mm Part Number Product Description BG030 2.54mm pitch Pin Header Single Row, Through-Hole, Vertical Drawing Date 1st November 2006 By Detail 2 3 4 Revision Date 5 CC Tolerances (Except as Noted) BG030 G PCN G5 06/09/17 X.° ± 5° X. ± 0.30 X.X° ± 2° X.X ± 0.20 X.XX ± 0.15 X.XX° ± 1° X.XXX ± 0.10 X.XXX° ± 0.5° Length Angle 6 Units: Metric (mm) C 3rd Angle Projection 7 2.54 5.08 5.08 7.62 4 5 7.62 10.16 10.16 12.70 6 12.70 15.24 7 8 15.24 17.78 17.78 20.32 9 20.32 22.86 10 25.40 27.94 11 22.86 25.40 12 13 27.94 30.48 30.48 33.02 14 15 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 17 18 Electrical Current Rating: 3 Amp Per Pin Contact Resistance: 20 mΩ max. Insulation Resistance : 1000 MΩ min. Dielectric Withstand Voltage: 600 V AC B / 2.54 2 3 16 Plating Contact: See ordering grid D±0.2 E 2.54 30mm Maximum F Dimensions A 19 45.72 48.26 20 48.26 50.80 21 50.80 53.34 22 23 53.34 55.88 55.88 58.42 24 25 58.42 60.96 60.96 63.50 26 63.50 66.04 27 66.04 68.58 28 29 68.58 71.12 73.66 30 71.12 73.66 31 76.20 78.74 76.20 32 78.74 81.28 33 81.28 83.82 34 35 83.82 86.36 86.36 88.90 36 88.90 91.44 37 91.44 93.98 38 93.98 96.52 39 96.52 99.06 40 99.06 101.60 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By LYH 8 Sheet No. 1/1
BG030-06-A-0450-0300-N-G 价格&库存
很抱歉,暂时无法提供与“BG030-06-A-0450-0300-N-G”相匹配的价格&库存,您可以联系我们找货
  • 1+1.760731+0.22880
  • 10+1.4918210+0.19386
  • 100+1.26367100+0.16421
  • 500+1.12776500+0.14655
  • 1000+1.073761000+0.13953
  • 5000+0.958395000+0.12454
  • 10000+0.9126210000+0.11860
库存:3156
    • 1+1.65759
    • 200+0.66140
    • 500+0.63926
    • 1000+0.62835
