SMS6PH4D28
SMS6PH4D28
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    CONN HEADER VERT 6POS 5.08MM
SMS6PH4D28 数据手册
SMS SERIES Quick Mating Overview SMS Series | Overview Similar product range Typical applications............................................ 06 Features & Benefits............................................ 07 UTS Series.......................................................... 34 UTO Series......................................................... 34 VGE1 / FER1 Series............................................ 35 838 Series........................................................... 35 MSG 3U Series................................................... 36 MSM & MSO Series............................................ 36 MB Series........................................................... 37 Connector Quick mating...................................................... 10 Quick mating board mount................................ 17 Quick mating pin header.................................... 23 Discrimination keys............................................. 27 Connector Contents Contacts Similar product range Contacts Contact selector guide ...................................... 30 Packaging .......................................................... 30 Crimp contacts .................................................. 31 Tooling ............................................................... 31 3 SMS SERIES © 2018 SOURIAU - SOURIAU is a registered trademark SMS Series Overview Typical applications ................................................................................................. 06 Features & Benefits ................................................................................................. 07 5 © ALSTOM Transport / P. de Salabert © ALSTOM Transport / ABACA – S. Lee Robotics Railway Signaling 6 Machinery Railway - Closed from electrical operating areas © ALSTOM Transport / M.Spera/ TOMA – C. Sasso © Romaset / Shutterstock © Rainer Plendl / Fotolia SMS Series | Overview Typical applications Railway - Interior & Cabin SMS Series | Overview Features & Benefits Quick Mating / Unmating Mechanism EASY TO USE Push to mate - Press and release to unmate. A simple operation with only two fingers. High Flammability Rating Overview The SMS series offers a flame retardant version (UL94 V0 & HL3/R22 QUALIFIED following the EN 45545-2) to guarantee secure and safe equipment. Reliable Solution Pin protection skirts , positive polarization keys and retention locks SAFE USE will ensure correct mating between the plug and the receptacle. High Density Solution SPACE SAVING With a pitch of 5.08mm and a low profile version availability, SMS series is ideal for tight space integration and high density applications (3 to 36 positions). Two In One COST SAVING Integrated strain relief hood versions are available to offer a highly cost-effective solution. 7 SMS SERIES © 2018 SOURIAU - SOURIAU is a registered trademark SMS Series Connector SMS Quick Mating.......................................................................................................... 10 SMS Board mount Quick Mating.................................................................................... 17 SMS Quick Mating Pin Header....................................................................................... 23 Discrimination keys......................................................................................................... 27 9 SMS Series | Quick Mating Quick Mating panel and cable connectors Description The versatile and easy to use “SMS” Quick Mating panel and cable connectors are a highly cost-effective system approach to solving the constant demand for more interconnection solutions and techniques. A full plastic solution offered in either Wire attachment or PCB mounting options to provide rapid assembly/installation without requiring additional mounting hardware. Panel receptacle connectors simply snap and lock into panel cut-outs and cable plugs quickly connect and disconnect with positive retention locks. Just push to mate then press and release to un-mate. In addition, cable plug connectors also feature pin-protection skirts, positive polarization and are offered with or without integrated strain relief hoods. Cable receptacle connectors (with integrated strain relief hoods) are available to mate with the cable plug connectors for cableto-cable solutions when needed. These multi-way connectors accept the Size 16 TRIM TRIO (1.6mm) diameter contacts and are available with 10 contact arrangements from 2 to 36 positions. Features and benefits • Available in 10 contact arrangements • Self mountable panel receptacle with positive housing retention • Cable plugs with retaining latches for positive locking • Cable plug has pin protection skirt to prevent damage of male contacts • Positive polarization keys prevent mismating • Cable plug and receptacle have integrated strain relief hood which can accept a wide range of cables • Cable plug and receptacle have discrimination cavities in between contact cavities, thus offering discrimination without contact loss. See instruction page 27. • UL recognized File Nr.: E238675 • CSA certififed File Nr.: LR44961-21 Environmental • Operating temperature: -55°C to +105°C • Insulation resistance: 5000 MΩ min. • Test potential: 2000 VAC • Durability: 500 matings and unmatings • Sealing performances: IP40 • Electrical performances: UL: 250V - 10A CSA: 250V - 15A Wire insulation acceptance • SMS PDH1, RDH1, PD3, PDH3, RD3, RDH3 max: 3.2mm • SMS R1, P1, R3 max: 4.19mm Material • Connector: Polyamide 6.6 • Flammability rating: - Black versions : UL94 V2 - White versions : UL 94 V0 and HL3/R22 - HL3/R23 following EN 45 545-2 Contact • “SMS” Quick Mating connectors accept TRIM TRIO size 16 removable snap-lock contacts (see contact section) • Contacts to be ordered seperately. Ordering information Connector family Layout: see page 12 Body variation: R1: (UL94 V2) Panel mount receptacle - Black R3: (UL94 V0 & HL3/R22 - HL3/R23) Panel mount receptacle - White P1: (UL94 V2) Cable plug without strain relief hood - Black PD3: (UL94 V0 & HL3/R22 - HL3/R23) Cable plug without strain relief hood - White PDH1: (UL94 V2) Cable plug with integrated strain relief hood - Black PDH3: (UL94 V0 & HL3/R22 - HL3/R23) Cable plug with integrated strain relief hood - White RD3: (UL94 V0 & HL3/R22 - HL3/R23) Cable receptacle without integrated strain relief hood - White RDH1: (UL94 V2) Cable receptacle with integrated strain relief hood - Black RDH3: (UL94 V0 & HL3/R22 - HL3/R23) Cable receptacle with integrated strain relief hood - White 10 SMS 12 PDH3 SMS Series | Quick Mating Range overview - Quick mating & board mount connectors SMS...R1/ SMS...R3 Panel mount receptacle SMS...PDH1/SMS...PDH3 Cable plug with strain relief hood SMS...RDH1/SMS...RDH3 Cable receptacle with strain relief hood SMS...RD3 Cable receptacle without strain relief hood Connector SMS...P1/SMS...PD3 Cable plug without strain relief hood SMS...GE3-SE3/SMS...GE30-RE30 SMS...GE33/SMS...GE4-SE4/ SMS...GE40-RE40/SMS...GE43 Straight board mount SMS...GE5-SE5/ SMS...GE53 SMS...GE6-SE6/SMS...GE63 Right angle board mount 11 SMS Series | Quick Mating Contacts layout SMS 2 SMS 3 SMS 6 SMS 4 SMS 9 SMS 15 SMS 24 SMS 12 SMS 18 SMS 36 Contact identifications shown are for mating face. Contact identifications of wiring face are identical as shown on the receptacle arrangements 12 SMS Series | Quick Mating Connectors Panel mount receptacle without discrimination cavities A J 0.75 2.3 K B 25.0 (wire acceptance: 4.19mm) 13.2 Part number Nbr. of contact* A SMS2R3 2 11.0 SMS3R1 SMS3R3 3 16.2 SMS4R1 SMS4R3 4 21.1 Black UL94 V2 White UL94 V0 SMS2R1 B C max. 5.8 15.2 SMS6R3 6 10.9 20.3 SMS9R3 9 16.0 25.4 21.1 26.2 30.5 31.2 40.6 21.1 30.5 16.2 12 SMS15R1 SMS15R3 15 SMS18R1 SMS18R3 18 SMS24R1 SMS24R3 24 21.2 SMS36R1 SMS36R3 36 46.6 16.5 11.6 21.7 SMS6R1 SMS12R3 K 11.4 SMS9R1 SMS12R1 J 16.7 16.5 21.6 26.7 35.6 16.7 31.8 36.9 21.7 47.1 26.7 *Contacts supplied separately (wire acceptance: 4.19mm) A B max. 32.9 Connector Cable plug without strain relief hood & without discrimination cavities 25.0 Part number Nbr. of contact* A SMS2P1 2 15.0 SMS3P1 3 18.6 SMS4P1 4 23.7 SMS6P1 6 SMS9P1 9 SMS12P1 12 SMS15P1 15 SMS18P1 18 SMS24P1 24 23.7 SMS36P1 36 49.1 Black UL94 V2 *Contacts supplied separately C max. 17.8 22.9 18.6 27.9 33.0 38.1 43.2 33.0 Note: all dimensions are in mm 13 SMS Series | Quick Mating Cable receptacle without strain relief hood & with discrimination cavities Contact cavity E Discrimation cavity C B max. 25.0 D Part number Nbr. of contact* Nbr. of discrimination cavities SMS2RD3 2 0 SMS3RD3 3 0 SMS4RD3 4 0 SMS6RD3 6 2 SMS9RD3 9 4 20.0 18.5 12 6 25.1 23.6 30.2 28.7 35.3 33.8 25.1 23.6 White UL94 V0 SMS12RD3 B max C 9.9 8.4 15.0 SMS15RD3 15 8 SMS18RD3 10 SMS24RD3 18 24 15 SMS36RD3 36 24 D E 11.1 14.1 16.2 18.6 21.2 23.7 16.2 18.6 13.4 21.2 23.7 46.6 49.1 *Contacts supplied separately Cable plug without strain relief hood & with discrimination cavities Contact cavity Discrimation cavity C B max. 32.7 D Part number White UL94 V0 SMS2PD3 Nbr. of contact* Nbr. of discrimination cavities 2 0 SMS3PD3 3 0 SMS4PD3 4 0 B max. C 14.1 16.4 8.4 SMS6PD3 6 2 21.5 13.4 9 4 26.7 18.5 SMS12PD3 12 6 31.7 23.6 36.7 28.7 41.8 33.8 31.7 23.6 SMS15PD3 15 8 10 SMS24PD3 18 24 15 SMS36PD3 36 24 18.6 23.7 SMS9PD3 SMS18PD3 D 18.6 23.7 49.1 *Contacts supplied separately Note: all dimensions are in mm 14 SMS Series | Quick Mating Connectors (Continued) Cable receptacle with integrated strain relief hood Contact cavity Cable range Discrimation cavity B H A C D Part number Nbr. of Nbr. of discrimicontact* nation cavities A B C D 11.1 0.5 69.0 16.2 74.4 21.2 H Cable range (mm) Black UL94 V2 White UL94 V0 SMS2RDH1 SMS2RDH3 2 0 31.6 SMS3RDH1 SMS3RDH3 3 0 35.1 SMS4RDH1 SMS4RDH3 4 0 38.2 SMS6RDH1 SMS6RDH3 6 2 34.6 15.0 72.6 50.9 1.7-9.2 SMS9RDH1 SMS9RDH3 9 4 35.8 20.0 75.3 52.2 3.9-14.2 SMS12RDH1 SMS12RDH3 12 6 38.1 25.1 72.0 52.7 4.0-15.0 SMS15RDH1 SMS15RDH3 15 8 35.9 30.2 SMS18RDH1 SMS18RDH3 18 10 36.1 SMS24RDH1 SMS24RDH3 24 15 39.7 SMS36RDH1 SMS36RDH3 36 24 54.6 *Contacts supplied separately 9.9 81.3 35.3 25.1 16.2 Cable tie (1) 0.5-8.4 49.2 0.8-7.3 1.5-10 55.2 5.0-16.2 5.8-20.3 90.4 21.2 57.2 7.1-20.4 128.0 46.6 63.3 8.8-24.5 TF4D TF5D (1) Cable tie not included Contact cavity Cable range Discrimation cavity H B A Connector Cable plug with integrated strain relief hood D C Part number Nbr. of Nbr. of discrimicontact* nation cavities A B C D 64.8 14.1 69.0 18.6 74.4 23.7 H Cable range (mm) Black UL94 V2 White UL94 V0 (2) SMS2PDH1 SMS2PDH3 2 0 39.5 SMS3PDH1 SMS3PDH3 3 0 43.0 SMS4PDH1 SMS4PDH3 4 0 46.1 SMS6PDH1 SMS6PDH3 6 2 42.5 21.5 72.6 58.8 1.7-9.2 SMS9PDH1 SMS9PDH3 9 4 43.7 26.7 75.3 60.1 3.9-14.2 SMS12PDH1 SMS12PDH3 12 6 46.0 31.7 72.0 60.6 4.0-15.0 SMS15PRDH1 SMS15PDH3 15 8 43.8 36.7 SMS18PDH1 SMS18PDH3 18 10 44.0 SMS24PDH1 SMS24PDH3 24 15 47.6 SMS36PDH1 SMS36PDH3 36 24 62.5 *Contacts supplied separately (1) Cable tie not included 16.4 41.8 31.7 18.6 81.3 Cable tie (1) 0.5-8.4 57.1 0.8-7.3 1.5-10 63.1 5.0-16.2 5.8-20.3 90.4 23.7 65.1 7.1-20.4 128.0 49.1 71.2 8.8-24.5 TF4D TF5D (2) White UL94 V0 & HL3/R22 - HL3/R23 Note: all dimensions are in mm 15 SMS Series | Quick Mating Accessories for standard Quick Mating connectors Pin protection shroud for panel mount receptacle 23.5 B A When pins are inserted into the panel mount receptacle half (SMS...R1) of the Quick Mating connector, an optional pin protection shroud can be installed. The shroud is mounted at the same time as the receptacle by holding the shroud against the mating side of the panel with both cutouts lined up. The receptacle is then inserted in place, trapping the shroud between the receptacle and panel. The use of the pin protection shroud reduces the allowable thickness of the panel from 2.3 to 1.6 mm max. Part number Nbr. of contact position A SMS2CSB1 2 19.8 SMS3CSB1 3 23.4 SMS4CSB1 4 28.4 SMS6CSB1 6 SMS9CSB1 9 SMS12CSB1 12 SMS15CSB1 15 SMS18CSB1 18 SMS24CSB1 24 28.4 SMS36CSB1 36 54.1 Black UL94 V2 B 18.8 23.9 29.0 34.0 23.4 39.1 44.2 34.0 Strain relief hoods Part number For SMS2H1, SMS3H1, SMS4H1 & SMS6H1 2 pieces are needed for a complete hool for SMS9H1 to SMS36H1 Separate strain relief hoods are available for all standard plugs SMS...P1. The hoods consist of identical halves that snap into position on the plug and are secured in place with the cable tie drawn tightly around the cable entry collar. The cable tie is not included (TF4D – TF5D). Two, three and four position hoods are single piece units. Black UL94 V2 Nbr. of contact position SMS2H1 2 SMS3H1 3 SMS4H1 4 SMS6H1 6 SMS9H1 9 SMS12H1 12 SMS15H1 15 SMS18H1 18 SMS24H1 24 SMS36H1 36 Discrimination pins For discrimination pins on both standard Quick Mating and Quick Mating Pin Headers cable and board mount: See page 27. Note: all dimensions are in mm 16 SMS Series | Board mount Quick Mating (Pitch: 5.08mm) Quick Mating PC board mount connectors Description • Test potential: 2000 VAC • Current rating for SMS PCB version: - 5 Amp for stamped and formed contacts - 7.5 Amp for machined contacts • Electrical performances for crimped versions: UL: 250V - 15A CSA: 250V - 15A • Durability: 500 matings and unmatings • Sealing performances: IP40 Features and benefits • Straight versions available in 10 contact arrangements from 2 to 36 positions • Right angled versions available in 3, 6, 12 and 18 positions. • All versions are available with: - Pin or socket contacts - Stamped and formed or solid machined contacts. • Board mount connectors have discrimination cavities in between contact cavities, unless other wise noted.See instruction page 27. • UL recognized File Nr.: E238675 • CSA certififed File Nr.: LR44961-21 Environmental • Operating temperature: -55°C to +105°C • Insulation resistance: 5000 MΩ min. Material • Connector body: Glass filled thermoplast UL94 V0 • Railway version : HL2/R22 - HL2/R23 following EN 45 545-2 • Contacts: High conductive copper alloy • Soldering information: compatible with wave soldering up to 245°C. Not compatible with reflow soldering. Plating table • Plating for solid machined contacts: - Made for 2.4mm or 3.2mm PCB thickness (straight contacts) and for 3.2mm PCB thickness (right contacts) K9 (std) = Min. 0.4µ Gold in contact area, Tin on solder tail, over Nickel J9 = Gold flash in contact area, Tin on solder tail, over Nickel T = 3 - 5µ Tin all over • Plating for Stamped and formed contacts: - Made for 2.4mm PCB thickness (straight contacts) and for 3.2mm PCB thickness (right contacts) K9 = Min. 0.4µ Gold in contact area, 3- 5µ Tin on solder tail, over Nickel T = 3 - 5µ Tin all over - Made for 3.2mm PCB thickness (straight contacts) S6 = Min. 0.75µ Gold in contact area Gold flash on solder tail, over Nickel D70 = G  old flash all over TR29 = 3 - 5µ Tin all over Intermateability • “SMS” Quick Mating board mount connectors with preassembled TRIM TRIO size 16 board mount contacts are intermateable only with the “SMS” Quick Mating cable plug connectors equipped with TRIM TRIO crimp type removable snap-lock contacts (see contact section). Connector These PC board mount connectors enable Quick Mating and preassembled TRIM TRIO contacts to be PC board mounted, using conventional solder production techniques. They will then mate and latch with the standard Quick Mating plugs. Straight board mount connectors is available in 10 insert arrangements from 2 to 36 positions. Right angled board mount Quick Mating is available in 3, 6, 12 and 18 positions. All board mount connectors are supplied fully loaded with pin or socket contacts, either in solid machined or stamped and formed contacts. Stamped and formed contact have selective tin plating on the solder tails, thus eliminating flux operations. Ordering information Connector family Layout: see page 12 SMS 12 GE 3 0 K9 Body variation: GE: Solid machined contacts (2.4mm or 3.2mm, see option below) SE: Stamped and formed contacts for 2.4mm PCB RE: Stamped and formed contacts for 3.2mm PCB Design variation: 3: Straight board mount with female contact 4: Straight board mount with male contacts 5: Right angle board mount with female contacts 6: Right angle board mount with male contacts Option: -: 2.4mm for GE3, GE4 and SE variation 0: 3.2mm for GE variation 3: Railway version: HL2/R22 - HL2/R23 following EN 45 545-2 Plating indication 17 SMS Series | Board mount Quick Mating (Pitch: 5.08mm) Connectors Straight board mount with female contacts PCB tail length E Ø0.8 7.0 A 5.9 5.08 5.08 Ø3.5 2.4 B D Dimensions Nbr. of contact Nbr. of discrimination cavities A B C 2 0 11.0 - 19.1 3 0 16.2 4 0 21.3 6 0 19.2 9 4 24.2 12 0 15 8 18 10 24 0 21.2 36 0 46.5 14.0 16.2 29.2 D E 10.2 5.9 15.2 10.9 10.2 16.0 13.4 21.1 34.3 39.4 15.2 26.1 31.2 15.2 54.6 20.9 Contacts type Part number Standard version Solid machined contacts Stamped & formed contacts Solid machined contacts PCB thickness 2.4mm PCB tail length 3.4mm PCB thickness 3.2mm PCB tail length 4.2mm PCB thickness 2.4mm PCB tail length 3.4mm PCB thickness 3.2mm PCB tail length 4.4mm PCB thickness 2.4mm PCB tail length 3.4mm SMS2GE3* SMS2GE30* SMS2SE3* SMS2RE3* - SMS3GE3* SMS3GE30* SMS3SE3* SMS3RE3* SMS3GE33* SMS4GE3* SMS4GE30* SMS4SE3* SMS4RE3* - SMS6GE3* SMS6GE30* SMS6SE3* SMS6RE3* SMS6GE33* SMS9GE3* SMS9GE30* SMS9SE3* SMS9RE3* SMS9GE33* SMS12GE3* SMS12GE30* SMS12SE3* SMS12RE3* SMS12GE33* SMS15GE3* SMS15GE30* SMS15SE3* SMS15RE3* SMS15GE33* SMS18GE3* SMS18GE30* SMS18SE3* SMS18RE3* SMS18GE33* SMS24GE3* SMS24GE30* SMS24SE3* SMS24RE3* SMS24GE33* SMS36GE3* SMS36GE30* SMS36SE3* SMS36RE3* SMS36GE33* * for coding see page 30 Example: SMS12GE3J9 - SMS with 12 solid machined contacts, plating J9 Note: all dimensions are in mm 18 NFF certified version SMS Series | Board mount Quick Mating (Pitch: 5.08mm) Straight board mount with male contacts PCB tail length E Ø0.8 7.0 5.9 A 5.08 C 2.4 5.08 Ø3.5 7.0 D B Dimensions Nbr. of contact Nbr. of discrimination cavities A B C 2 0 11.1 - 19.1 3 0 16.2 4 0 21.3 6 0 19.2 9 4 24.2 12 0 15 8 18 10 24 0 21.2 36 0 46.5 14.0 16.2 29.2 D E 10.2 5.9 15.2 10.9 10.2 16.0 13.4 21.1 34.3 39.4 15.2 26.1 31.2 15.2 54.6 20.9 Connector Contacts type Part number Standard version Solid machined contacts NFF certified version Stamped & formed contacts Solid machined contacts PCB thickness 2.4mm PCB tail length 3.4mm PCB thickness 3.2mm PCB tail length 4.2mm PCB thickness 2.4mm PCB tail length 3.4mm PCB thickness 3.2mm PCB tail length 4.4mm PCB thickness 2.4mm PCB tail length 3.4mm SMS2GE4* SMS2GE40* SMS2SE4* SMS2RE4* - SMS3GE4* SMS3GE40* SMS3SE4* SMS3RE4* SMS3GE43* SMS4GE4* SMS4GE40* SMS4SE4* SMS4RE4* - SMS6GE4* SMS6GE40* SMS6SE4* SMS6RE4* SMS6GE43* SMS9GE4* SMS9GE40* SMS9SE4* SMS9RE4* SMS9GE43* SMS12GE4* SMS12GE40* SMS12SE4* SMS12RE4* SMS12GE43* SMS15GE4* SMS15GE40* SMS15SE4* SMS15RE4* SMS15GE43* SMS18GE4* SMS18GE40* SMS18SE4* SMS18RE4* SMS18GE43* SMS24GE4* SMS24GE40* SMS24SE4* SMS24RE4* SMS24GE43* SMS36GE4* SMS36GE40* SMS36SE4* SMS36RE4* SMS36GE43* * for coding see page 30 Example: SMS12GE4J9 - SMS with 12 solid machined contacts, plating J9 Note: all dimensions are in mm 19 SMS Series | Board mount Quick Mating (Pitch: 5.08mm) Connectors (Continued) Right angle board mount with female contacts F 5.08 16.5 4.5 Ø0.8 A G 2.5 B E 3x5.08 Ø3.4 D Dimensions Nbr. of contact Nbr. of discrimination cavities A 3 0 16.5 19.0 6 0 12 6 18 10 B C 20.5 14.4 21.6 24.5 29.5 D E F 30.2 24.2 16.2 35.2 29.2 21.2 45.4 39.4 31.2 Contacts type Part number Standard version Solid machined contacts Stamped & formed contacts Solid machined contacts PCB thickness 3.2mm PCB tail length 4.5mm PCB thickness 3.2mm PCB tail length 4.5mm PCB thickness 3.2mm PCB tail length 4.5mm SMS3GE5* SMS3SE5* SMS3GE53* SMS6GE5* SMS6SE5* SMS6GE53* SMS12GE5* SMS12SE5* SMS12GE53* SMS18GE5* SMS18SE5* SMS18GE53* * for coding see page 30 Example: SMS12GE5J9 - SMS with 12 solid machined contacts, plating J9 Note: all dimensions are in mm 20 NFF certified version G 6.8 11.9 17.2 SMS Series | Board mount Quick Mating (Pitch: 5.08mm) Right angle board mount with male contacts F 5.08 4.5 Ø0.8 A G 2.5 B E 16.5 3x5.08 Dimensions D Ø3.4 Nbr. of contact Nbr. of discrimination cavities A 3 0 16.5 19.0 6 0 12 6 18 10 B C 20.5 14.4 21.6 24.5 29.5 D E F 30.2 24.2 16.2 35.2 29.2 21.2 45.4 39.4 31.2 G 6.8 11.9 17.2 Contacts type Part number NFF certified version Solid machined contacts Stamped & formed contacts Solid machined contacts PCB thickness 3.2mm PCB tail length 4.5mm PCB thickness 3.2mm PCB tail length 4.5mm PCB thickness 3.2mm PCB tail length 4.5mm SMS3GE6* SMS3SE6* SMS3GE63* SMS6GE6* SMS6SE6* SMS6GE63* SMS12GE6* SMS12SE6* SMS12GE63* SMS18GE6* SMS18SE6* SMS18GE63* Connector Standard version * for coding see page 30 Example: SMS12GE6J9 - SMS with 12 solid machined contacts, plating J9 Note: all dimensions are in mm 21 SMS Series | Board mount Quick Mating (Pitch: 5.08mm) Drilling Pattern Dimensions Straight angle board mount 4 contacts 10.2 9 contacts 19.0 14.0 19.0 6 contacts 24.1 3 contacts 14.0 2 contacts 15.2 10.2 10.2 12 contacts 15 contacts 18 contacts 24 contacts 36 contacts Ø3.5 5.08 54.7 39.4 39.4 34.3 29.2 Ø1.2 10.2 10.2 10.2 15.3 5.08 15.3 Right angle board mount 3 contacts 6 contacts 12 contacts 18 contacts 34.9 5.08 29.2 24.1 24.1 Ø3.5 Ø0.12 5.08 Note: all dimensions are in mm 22 Secure connector with screws (not supplied), recommended torque 0.3 N.m SMS Series | Quick Mating Pin Header Quick Mating PC board mount Pin Headers and plugs Description Features and benefits • Available in 3, 4, 6, 9 and 10 positions. • In-line contact design, offering significant PC board space savings. • Board mount connectors available in straight and right angled version preassembled with: - Solid machined or stamped and formed pin contacts. - Coax pin contacts. • UL recognized File Nr.: E238675 • CSA metter certififed File Nr.: LR44961-21 Environmental J = Gold flash over 2µ Ni T = 3 - 5µ Tin all over • Plating for Stamped and formed contacts: D28 = Min. 0.75µ Au over nickel. D70 = A  ctive part: Gold flash over Ni Crimp area: Ni TR29 = 3 - 5µ Tin all over • Plating for coax contacts: Z17 =  Min. 0.75µ Au in contact area, Flash on solder tail (inner) Min 0.75µ Au in contact area, Tin on solder tail (outer) • Operating temperature: -55°C to +125°C • Insulation resistance: 5000 MΩ min. • Test potential: 2000 VAC • Current rating: - 5 Amp for stamped and formed contacts - 7.5 Amps for machined contacts • Durability: 500 matings and unmatings. Material • Connector body: Glass filled thermoplast UL94 V0 Color: Black • Contacts: High conductive copper alloy Intermateability • “SMS” Socket plugs accept TRIM TRIO size 16 removable snap-lock contacts (see contact section) • Contacts to be ordered seperately. Plating table • Plating for solid machined contacts: No digit (std) = Min. 0.4µ Gold all over, over Nickel. Ordering information Connector family Layout: see page 12 SMS 12 PH 3 0 TR29 Body variation: PH: Pin header board mount CH: Coax header board mount P3: Socket cable plug for pin and coax header board mount Design variation: 2: Straight coax header board mount with male contacts 3: Right angle pin header board mount with stamped male contacts 4: Straight pin header board mount with stamped male contacts GE6: Right angle pin header board mount with machined male contacts GE4: Straight pin header board mount with machined male contacts Plating indication 23 Connector Quick Mating Pin Header, available in 3, 4, 6, 9 and 10 positions, provides the additional versatility of straight and right angle board mounting. Offered as an alternative to stacked connectors, the in-line contact design of the pin header provides the user with significant PC board space savings. The board mount receptacle features positive polarization and a moulded on pin protection skirt and is supplied preassembled with straight or right angled: • Solid machined or stamped and formed PC board pin contacts. • Coax PC board pin contacts. The socket cable plug features positive quick connect / disconnect latches and is designed to accept N° 16 TRIM TRIO 1.6mm diameter socket contacts for maximum contact protection. SMS Series | Quick Mating Pin Header Connectors (Continued) Right angle pin header board mount with male contacts Ø3.5 5.08 Ø3.5 Ø08 B C 9.4 4.2 Part number Solid machined contacts 22.9 Nbr. of contact Stamped & formed contacts A B C SMS3PH3* SMS3PHGE6 3 31.2 25.4 19.3 SMS4PH3* SMS4PHGE6 4 36.3 30.4 24.4 SMS6PH3* SMS6PHGE6 6 46.5 40.6 34.5 SMS9PH3* SMS9PHGE6 9 61.7 55.9 49.8 SMS10PH3* SMS10PHGE6 10 66.8 61.0 54.9 * for coding see page 30 Example: SMS9PH3J9 - SMS with 9 solid machined contacts, plating J9 Straight pin header board mount with male contacts 4.0 Ø3.5 B 9.4 Part number Solid machined contacts Stamped & formed contacts 22.9 Nbr. of contact A B C SMS3PH4* SMS3PHGE4 3 31.2 25.4 19.3 SMS4PH4* SMS4PHGE4 4 36.3 30.4 24.4 SMS6PH4* SMS6PHGE4 6 46.5 40.6 34.5 SMS9PH4* SMS9PHGE4 9 61.7 55.9 49.8 SMS10PH4* SMS10PHGE4 10 66.8 61.0 54.9 * for coding see page 30 Example: SMS9PH4J9 - SMS with 9 solid machined contacts, plating J9 Note: all dimensions are in mm 24 C A Ø0.8 5.08 Ø3.5 SMS Series | Quick Mating Pin Header Straight coax header board mount with male contacts 4.2 Ø3.5 9.4 Ø1.0 B C A Ø0.8 5.08 Ø3.5 5.0 22.9 Part number Nbr. of contact A B C SMS3CH2Z17 3 31.2 25.4 19.3 SMS4CH2Z17 4 36.3 30.4 24.4 SMS6CH2Z17 6 46.5 40.6 34.5 SMS9CH2Z17 9 61.7 55.9 49.8 SMS10CH2Z17 10 66.8 61.0 54.9 * for coding see page 30 5.8 Connector Socket cable plug for pin and coax board mount header A 5.9 25.0 Part number Number of contact* A SMS3P3 3 16.0 SMS4P3 4 21.1 SMS6P3 6 31.2 SMS9P3 9 46.5 SMS10P3 10 51.6 *Contacts supplied separately Note: all dimensions are in mm 25 SMS Series | Quick Mating Pin Header Drilling Pattern Dimensions Right angle Pin Header Straight Pin Header Ø1.2 Ø1.2 4.32 5.08 5.08 Ø3.5 7.62 7.62 F F 2.34 5.08 Straight Coax Header 2.54 2.54 Right angle Coax Header E Ø1.4 Ø1.4 E 5.08 Ø3.5 7.62 Ø3.5 7.62 F F Number of contact E F 3 10.18 25.40 4 15.24 30.48 6 25.40 40.64 9 40.64 55.88 10 45.72 60.96 Note: all dimensions are in mm 26 Ø3.5 Secure connector with screws (not supplied), recommended torque 0.3 N.m SMS Series | Accessories Discrimination keys for SMS connectors In applications where similar connectors are used next to each other, mismatching can be a reason for disturbances, system failure or even danger to operator. To eliminate mismatching, all SMS can be equipped with discrimination solutions, which offer unlimited possibilities for a "fool-proof" interconnection system. When one of these discrimination keys is used, the SMS will only mate with a connector which has a vacant contact or discrimination cavity at the corresponding position. This system offers boundless opportunities for all applications. The material used is polyamide 6.6. Both connectors have removable contacts: SMSPKE0 For fixe female contacts and without discrimination cavities: SMSPKE2V1 Male contact Empty cavity Female contact Discrimination key A dummy contact, which can be inserted into an empty contact cavity in any of SMS connectors. A pin, which can be inserted into a preassambled female contact in all female boardmount connectors SMS. Specially for connectors without discrimination cavities and without removable pin contact: SMSPKB2 Both connectors have discrimination cavities: SMSPKE3 Discrimination sleeve Female contact Empty cavity A tube, which can be fitted over a preassembled male contact in all industrial male boardmount connectors SMS. Discrimination pins Connector Male contact Empty discrimination cavities A pin, which can be inserted in the discrimination cavities of the SMS Quick mating cable and boardmount connectors. The discrimination cavities are in between of the contact cavities and offer the advantage that no contact cavities are lost due to discrimination. As extraction tool, the RX2025GE1 without the "extraction tool tip" can be used. RX2025GE1 27 SMS SERIES © 2018 SOURIAU - SOURIAU is a registered trademark SMS Series Contacts Contact selector guide .............................................................................................. 30 Packaging .................................................................................................................. 30 Crimp contacts .......................................................................................................... 31 Tooling ....................................................................................................................... 31 29 SMS Series | Quick Mating Contact Selector Guide Contact supplied separately Electrical characteristics: contact resistance #16 Ø1.6mm Machined Stamped & Formed Available platings (contact supplied separately) < 3mΩ < 6mΩ J Gold flash over Nickel 2μm mini K 0.4 μm Gold over 2 μm Nickel mini S31 S18 Active part: Gold flash over Nickel Crimp area: 1.3μm Tin mini over Nickel Other: 1.3μm Tin mini Active part: 0.75μm Gold mini over Nickel Crimp area: 1.3μm Tin mini over Nickel Other: 1.3μm Tin mini TK6 0.5μm - 2.5μm Sn pre-plated D70 Superseded by S31 S6 Superseded by S18 Other platings on request (contact supplied separately) T Tin 3μm (-0/+2) over 1.3μm Nickel mini D28 0.75μm mini Gold over 2μm Nickel mini Packaging Due to the wide variety of applications, contact packaging is offered for small series (bulk package) and high volume production (reeled contacts): Size contacts #16 (Ø1.6mm) • 25 pieces loose package (Stamped & Formed contacts) 30 • 50 pieces bulk package (Machined contacts) • 1,000 pieces bulk package (Machined contacts) • 3,000 pieces reeled (Stamped & Formed contacts) • 2,000 pieces reeled (Machined contacts) Size #16 only SMS Series | Quick Mating Crimp Contacts Standard Version Wire size Contact size #16 Ø1.6 mm Part number Available plating see page 30 AWG mm² Male Female Max insulator Ø Machined 30-28 0.05-0.08 RM28M1- RC28M1- 1.1 K, J Machined 26-24 0.13-0.2 RM24M9- RC24M9- 1.6 K, J SM24M1-(1) SM24ML1-(2) SC24M1-(1) SC24ML1-(2) 0.89-1.58 S31, S18, TK6 RM20M13- RC20M13- 1.8 RM20M12- RC20M12- 2.2 SM20M1-(1) SM20ML1-(2) SC20M1-(1) SC20ML1-(2) 1.17-2.08 S31, S18, TK6 Type Stamped & Formed 26-24 0.13-0.25 Machined 22-20 0.32-0.52 Stamped & Formed 22-20 0.35-0.5 Machined 18-16 0.92-1.5 RM16M23- RC16M23- 3.2 K, J SC16M1-(1) SC16ML1-(2) No insulation grip S31, S18, TK6 K, J Stamped & Formed 18-16 0.8-1.5 SM16M1-(1) SM16ML1-(2) Stamped & Formed 18-16 0.8-1.5 SM16M11-(1) SM16ML11-(2) SC16M11-(1) SC16ML11-(2) 2.08-3 S31, S18, TK6 Machined 16-14 1.5-2.5 RM14M30- RC14M30- 3.2 K, J 2.0-2.5 SM14M1SM14ML1-(2) SC14M1SC14ML1-(2) No insulation grip S31, S18, TK6 Stamped & Formed 14 (1) (1) Note: all dimensions are in mm (1) contact reeled (2) loose contact Exemple: RM20M13K - Size #16, Machined, AWG20 wire. Tooling Crimp Tool Table Contact size Part number #16 Ø1.6 mm RM/RC 28M1* RM/RC 24M9* RM/RC 20M13* RM/RC 20M12* RM/RC 16M23* RM/RC 14M30* SM/SC 24ML1*(1) SM/SC 20ML1*(1) SM/SC 16ML1*(1) SM/SC 14ML1*(1) SM/SC 16ML11*(1) (1) loose contact Head* Handles* Contacts Standard contacts Extraction tools S16RCM20 S16RCM16 S16RCM14 S16SCM20 RX2025GE1 SHANDLES Long endurance tool RX2031J S16SCML1 S16SCML11 * endurance of SHANDLES & Head tools = 50,000 cycles 31 SMS SERIES © 2018 SOURIAU - SOURIAU is a registered trademark SMS Series Similar product range UTS Series...................................................................................................................... 34 UTO Series..................................................................................................................... 34 VGE1 & FER1 Series....................................................................................................... 35 838 Series....................................................................................................................... 35 MSG 3U Series............................................................................................................... 36 MSM & MSO Series........................................................................................................ 36 MB Series....................................................................................................................... 37 33 SMS Series | Similar product range UTS Series Plastic waterproof solution with bayonet coupling system. Fire smoke: . HL2/R22 - HL2/R23 according to EN 45545-2. . UL94 V-0. Indoor and outdoor use: . Waterproof: IP68/69K Dynamic Mated & Unmated. . UV resistant: F1 rated per UL 746C. No mechanical detrioration after 5 years of exposure in natural environment. High speed data transmision: . Signal (Trim Trio contacts). . LC and MPO contacts. See «UTS Series» catalog on www.souriau.com UTO Series Metal waterproof solution with bayonet coupling system. Fire smoke: . HL2/R22 - HL2/R23 according to EN 45545-2. . UL94 V-0. Indoor and outdoor use: . High vibration Cat. 2 (Cat 3 for size E) according EN 61373. . Waterproof: IP68/69K Dynamic Mated & Unmated. . EMI shielded: 65 dB at 100 Mhz. . 500 mating cycles. Cost saving: . Trim trio contacts : Machined or stamp contacts for a secure solution with optimized costs. . Mixed Power & Signal contacts layouts. See «UTO Series» catalog on www.souriau.com 34 SMS Series | Similar product range VGE1 & FER1 Series A reverse bayonet coupling system adpated for high vibration applications. Fire smoke: . HL3/R22 - HL3/R23 according to EN 45545-2. . NFPA 130 compliant. . JRMA Class 3. Ruggedized solution: . High vibration Cat 2 according EN 61373. . 500h salt spray. . IP67. . -40°C to 100°C. . Compact solution with the size 14 (32 mm diameter up to 10 contacts). High speed data transmission: . Signal up to 60 contacts (Trim Trio contacts). . Quadrax. . Fiber optic. See «VGE1 & FER1 Series» catalog on www.souriau.com 838 Series Intercoach solution with screw coupling system. Fire smoke: . HL2/R22 - HL3/R23 according to EN 45545-2. Similar product range Ruggedized solution: . High vibration Cat. 2 (Cat 3 for size E) according EN 61373. . IP 67. . -40°C to 100°C. . Current up to 180 A. High speed data transmission: . Signal up to 61 contacts. . Quadrax. . Fiber optic. See «838 Series» www.souriau.com 35 SMS Series | Similar product range MSG 3U Series Easy & Secure Connectors for rack systems. Front I/O solutions. Fire smoke: . HL3/R22 - HL3/R23 according to EN 45545-2. . NFPA 130 compliant. Easy and secure solution: . Quick lever with safe locking system. . 360° metal housing for an improved shielding. . High density solution with 4 layouts: 29 pos / 41 pos / 51 pos / 5 quadrax. Cost saving solution: . Trim trio contacts : machined or stamp contacts for a secure solution with optimized costs. . Full plastic solution. . Integrated strain relief. See «MSG 3U Series» catalog on www.souriau.com MSM & MSO Series High Performance Boardmount Connector. High Performances: . From 9 to 75 positions. . -55°C to +125°C. . Up to 500 mating cycles. . UL 94V0. . Trim Trio contacts. See «MSM & MSO Series» www.souriau.com 36 SMS Series | Similar product range MB Series High Density Rectangular connector. Easy and secure solution: . Quick lever with safe locking system. . 360° metal housing for an improved shielding. . High density solution up to 52 contacts. . -55°C to +125°C. . Trim Trio contacts. Similar product range See «MB Series» www.souriau.com 37 SMS Series | Notes 38 Our contribution to environmental protection: This catalog is printed on PEFC certified paper Advancement of sustainable wood cultivation. www.pefc.org technical.emear@souriau.com (Europe - Asia - Africa) technical.americas@souriau.com (North America) www.souriau.com All information in this document presents only general particulars and shall not form part of any contract. All rights reserved to SOURIAU for changes without prior notification or public announcement. Any duplication is prohibited, unless approved in writing. Your local contact CASMSWUSEN01 © Copyright SOURIAU 2018 - SOURIAU is a registered trademark Reliable People, Reliable Solutions
SMS6PH4D28 价格&库存
很抱歉,暂时无法提供与“SMS6PH4D28”相匹配的价格&库存,您可以联系我们找货
