BK010-10-C-0850-0864-0508-G
    GCT
    CONN HEADER SMD 10POS 5.08MM
BK010-10-C-0850-0864-0508-G 数据手册
H B±0.30 Dimensions Number of Contacts 5.08 2 6.25 D+1.0 5.50 G F 1.14 sq. Pin 2.10 Pin 1 Pin 1 Recommended PCB Layout General Tolerance ±0.05 Solder Area A±0.25 Either Direction At The Top Either Direction At The Top 2.50 D E±0.25 0.12 Specifications 5.00 2° max. Toe C±0.25 12.00 5.08±0.15 2° max. Sway 20mm Maximum E 5.00 XX XXXX C XXXX XXXX X B 10.16 3 10.16 15.24 4 15.24 20.32 5 20.32 25.40 6 25.40 30.48 7 30.48 35.56 8 35.56 40.64 9 40.64 45.72 10 45.72 50.80 11 50.80 55.88 12 55.88 60.96 13 60.96 66.04 14 66.04 71.12 15 71.12 76.20 Material Insulator: LCP, UL94V-0 Contact:Brass Plating Contact:Tin All Over Underplating: Nickel all over D±0.30 Electrical Current Rating: 7.9 Amp Per Pin Contact Resistance: 30 mΩ max. Insulation Resistance: 1500 MΩ min. Dielectric Withstand Voltage: 1500 V AC Ordering Grid BK010 A 5.08 Request Samples and Quotation C B (Available from 3 contacts and above) D = Tube (Available from 3 contacts and above) G = Box (Only available in 2 contacts) Contact Plating C= Tin All Over Dimension C (1/100mm) (Post Height) 0850 = 8.50mm (Standard) Or specify Custom Post Height (Maximum 1500=15.00mm) (Minimum 0050=0.50mm) A Dimension E (1/100mm) (PCB to Top of Insulator) 0405 = 4.05mm (Standard-Minimum ) Or specify custom dimension Dimension D (1/100mm) (Footprint Width) 1000 =10.00mm (Standard) Or specify Custom Footprint Width (Tooling charge may apply) Mates with (Subject to Pin Length) BK015 Part Number Product Description BK010 5.08mm Pitch Pin Header, Single Row, Surface Mount, Vertical Drawing Date 10th August 2017 By Detail 1 Mechanical & Environmental Operating Temperature: -40°C to +105°C Soldering Process IR Reflow: 260°C for 10 sec. Manual Solder: 350°C for 3-5 sec Packing Options E = Tube with Cap (Standard) No. of Contacts 02 to 15 2 3 4 Revision Date 5 CC Tolerances (Except as Noted) Drawing Release A 16/08/17 X. ± 0.30 X.° ± 5° X.X° ± 3° X.X ± 0.25 X.XX ± 0.15 X.XX° ± 2° X.XXX ± 0.10 X.XXX° ± 1° Length Angle 6 Units: Metric (mm) C 3rd Angle Projection 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By CC 8 Sheet No. 1/1
BK010-10-C-0850-0864-0508-G 价格&库存
很抱歉,暂时无法提供与“BK010-10-C-0850-0864-0508-G”相匹配的价格&库存,您可以联系我们找货
  • 1+12.828601+1.66053
  • 20+10.3565020+1.34054
  • 100+9.24451100+1.19661
  • 500+8.25144500+1.06807
  • 1000+7.857601000+1.01709
  • 5000+7.014445000+0.90795
  • 10000+6.6799810000+0.86466
库存:1915
