FM20C05VBDN00G7
FM20C05VBDN00G7
    METZCONNECT
    SMD,P=2mm
    排母 间距:2mm 2x5P SMT
FM20C05VBDN00G7 数据手册
Page 1/4 Data sheet P/N FM20CXXVBDN xx=number of poles FM20CxxVBDN 2020/10/20 Version: Q Illustrations Dimensional drawing Drill pattern See enlarged drawings at the end of document Product specification • female connector, SMT solderable • centerline 2.00 mm, direction of connection vertical 0° • closed ends • color black • Tape & Reel packaging possible • dual rows Data sheet Page 2/4 FM20CxxVBDN P/N FM20CXXVBDN xx=number of poles 2020/10/20 Version: Q Technical Data General Data Min. number of poles Max. number of poles 2 Insulating material class CTI 450 clearance/creepage dist. 0.65 mm Protection category IP00 Rated current 1A 40 Material Insulating material PA6 Contact material CuSn Contact surface Ni + Ag Contact pin material CuSn Contact pin surface Ni + Au Flash Glow-Wire Flammability GWFI - Glow-Wire Flammability GWIT - Climatic Data Upper limit temperature 105 °C Lower limit temperature -40 °C general Tolerance ISO 2768 -mH Solderability Acc. to IPC/JEDEC J-STD-020D-MSL 1 Data sheet FM20CxxVBDN Page 3/4 P/N FM20CXXVBDN xx=number of poles 2020/10/20 Version: Q Illustrations Dimensional drawing L=(pole size - 1) x centerline + 2 mm [0.079] Data sheet FM20CxxVBDN Page 4/4 P/N FM20CXXVBDN xx=number of poles 2020/10/20 Version: Q Illustrations Drill pattern Powered by TCPDF (www.tcpdf.org)
FM20C05VBDN00G7 价格&库存
很抱歉,暂时无法提供与“FM20C05VBDN00G7”相匹配的价格&库存,您可以联系我们找货
