BK015-10-C-E
BK015-10-C-E
    GCT
    SMD,P=5.08mm
    排母 间距:5.08mm 1x10P SMT
BK015-10-C-E 数据手册
H B±0.35 A±0.30 1.40 5.08±0.15 1.40 5.08 3.70 8.10 3.70 8.10 5.08 G 5.08 Ø1.80 Number of Contacts Pin 1.14X0.40 Recommended PCB Layout Bottom Entry General Tolerance ±0.05 F Recommended PCB Layout Top Entry General Tolerance ±0.05 6.10 Cap 9.35±0.25 E 8.90 7.10 3.00 A Solder Area 2.80 ref Solder Area 0.12 Dimensions A B 2 5.08 10.16 3 10.16 15.24 4 15.24 20.32 5 20.32 25.40 6 25.40 30.48 7 30.48 35.56 8 35.56 40.64 9 40.64 45.72 10 45.72 50.80 11 50.80 55.88 12 55.88 60.96 13 60.96 66.04 14 66.04 71.12 15 71.12 76.20 7.10±0.30 A D Section A-A Ordering Grid Specifications C B Material Insulator: LCP, UL94V-0 Contact: Phosphor Bronze BK015 Mechanical & Environmental Operating Temperature: -40°C to +105°C Soldering Process IR Reflow: 260°C for 10 sec. Manual Solder: 350°C for 3-5 sec Plating Contact: Tin All Over Underplating: Nickel all over Electrical Current Rating: 7.9 Amp Per Pin Contact Resistance: 30 mΩ max. Insulation Resistance: 1500 MΩ min. Dielectric Withstand Voltage: 1500 V AC A Mates with (Subject to Pin Length) BK010 BK020 For bottom entry applications, stringent soldering control & pin alignment are required as lead to pad misalignment could cause incorrect mating. 3 X Request Samples and Quotation Packing Options E = Tube with Cap (Standard) B = Tape and Reel with Cap D = Tube Contact Plating C= Tin All Over Part Number Product Description BK015 5.08mm Pitch Socket, Single Row, Surface Mount, Vertical,Dual Entry Drawing Date 26th May 2017 By 2 C No. of Contacts 02 to 15 Detail 1 XX 4 Revision Date 5 CC Tolerances (Except as Noted) Drawing Release A1 09/09/21 X. ± 0.30 X.° ± 5° X.X° ± 3° X.X ± 0.25 X.XX ± 0.15 X.XX° ± 2° X.XXX ± 0.10 X.XXX° ± 1° Length Angle 6 Units: Metric (mm) C 3rd Angle Projection 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By CC 8 Sheet No. 1/1
BK015-10-C-E
1. 物料型号:BK015 2. 器件简介:BK015是一个排针插座,用于表面贴装,垂直,双入口,间距为5.08mm。 3. 引脚分配:提供了不同引脚数量的尺寸,从2个引脚到15个引脚,每个引脚之间的间距为5.08mm。 4. 参数特性: - 绝缘体材料:LCP, UL94V-0 - 接触材料:磷青铜 - 电镀:接触点镀锡,底层镀镍 - 电气特性:每个引脚的电流额定值为7.9安培,接触电阻最大为30毫欧,绝缘电阻最小为1500兆欧,介电强度为1500V交流电 - 机械和环境特性:工作温度范围为-40°C至+105°C,焊接过程包括IR回流(260°C持续10秒)和手动焊接(350°C持续3-5秒) 5. 功能详解:文档中提到了对于底入式应用,需要严格控制焊接和引脚对齐,因为引脚与焊盘的不对齐可能会导致错误的配合。 6. 应用信息:BK015与BK010(受引脚长度限制)和BK020兼容。 7. 封装信息:提供了订购网格,包括不同引脚数量的选项和包装选项,如带帽的胶带和卷轴(B),带帽的管(E)(标准),不带帽的管(D)。
BK015-10-C-E 价格&库存
很抱歉,暂时无法提供与“BK015-10-C-E”相匹配的价格&库存,您可以联系我们找货
BK015-10-C-E
  • 1+16.284511+2.10786
  • 12+13.6480012+1.76659
  • 108+11.68367108+1.51233
  • 504+10.47978504+1.35650
  • 1008+9.979621008+1.29176
  • 5004+8.913525004+1.15377
  • 10008+8.4885310008+1.09876
库存:1955
