Technical characteristics
Mating conditions
Processing notes
Inclination
The har-flex ® SMT/THR connectors
meet the highest demands in terms
of their processing capabilities.
The connectors are delivered in a
tape and reel packaging optimized
for automatic assembly machines. A
vacuum cover enables the automatic
assembly with a vacuum nozzle.
The insulation body material is high
temperature resistant, and due to
the black colour a secure camera
recognition is ensured.
To ensure a reliable reflow soldering
process, the signal pins are
100 % checked for coplanarity.
Mismating
Process / Moisture Sensitivity
During
the
reflow
solder
process,
the
connector
has
to
resist
extreme
variations
in
temperature.
Connectors
consist in general of both plastic
and metal parts, which have a different behaviour during
the solder process. The Process Sensivity and also the
Moisture Sensivity are tested according the ECA/IPC/JEDEC
J-STD-075 specification.
Process Sensivity:
PSL means Process Sensitivity Level. PSL is a rating used to
identify a component that is solder process sensitive. Damages
of the connector after three times soldering are not permitted
(e.g. melted edges).
Tape acc. to IEC 60 286-3
Moisture Sensitivity:
har -flex
MSL means Moisture Sensitivity Level. MSL is a rating
indicating a component’s susceptibility to damage due to
absorbed moisture during storage. Damages of the connector
after storage in damp heat and three times soldering are not
permitted (e.g. blisters).
The har-flex ® connectors are rated with PSL R0 and MSL 1.
This is the maximum possible rating in both categories. The
har-flex ® connector resists three times soldering at the following
conditions without damages:
• min. 150 s beyond 217 °C (liquidus temperature, the melting
point of the solder paste)
• min. 30 s beyond classification temperature (240 °C / 245 °C
for har-flex ®)
14
10
Tape dimensions:
poles 6 to 12
poles 14 to 20
poles 22 to 40
poles 42 to 56
poles 58 to 80
poles 82 to 100
E
24.4
32.4
44.4
56.4
72.4
88.4
• Temperature solder profile according to ECA/IPC/JEDEC
J-STD-075
• For MSL test, a storage of 168 hours at 85 °C and 85 % rel.
humidity was carried out
As the result, the har-flex ® connectors are not process sensitive
and not moisture sensitive according to ECA/IPC/JEDEC
J-STD-075.
很抱歉,暂时无法提供与“15210102601333”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+52.335471+6.73480
- 3+46.803363+6.02290
- 5+41.359075+5.32230
