B13B-ZR
B13B-ZR
    JST
    插件,P=1.5mm
B13B-ZR 数据手册
Crimp 1.5mm ZH CONNECTOR Emboss Tape Disconnectable Crimp style connectors (.059") pitch Features –––––––––––––––––––––––– • Compact, low profile design The ZH connector requires only about 45% of the installation space required by the standard JST 2.0mm (.079") pitch connector. • Housing lances The contact retention lances on the resilient housing allow visual confirmation of contact lock-in for easy and secure insertion. • Reliable contact construction The dimple at the center of the contact ensures positive contact and low contact resistance at all times, even when the connector is subjected to vibration or distortion. Therefore this connector is ideal for use under low current, low voltage conditions. The ZH connector is very small with a mounting height of 5.6mm (.220") and a thickness of only 3.5mm (.138"). Contact retention lances on the housing make insertion easier, while the dimple at the center of the contact ensures reliable contact with the post. • Distortion resistant construction The header is fully shrouded and thus protects the receptacle from damage that could be caused by mating the connectors at an angle or by otherwise mismating the connectors. • Compatible with the ZR insulation displacement connectors The same shrouded header can be used for either the ZR IDCstyle connector or the ZH crimp style connector. This allows both types of connector to be used interchangeably without replacing the header. Specifications ––––––––––––––––––– • Current rating: 1.0A AC, DC (AWG #26) • Voltage rating: 50V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/20m Ω max. After environmental testing/30m Ω max. • Insulation resistance: 500M Ω min. • Withstanding voltage: 500V AC/minute • Applicable wire: AWG #32 to #26 • Applicable PC board thickness: 0.6 to 1.2mm(.024" to .047"), 1.6mm(.063") * Contact JST if Lead-Free product is required. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Standards –––––––––––––––––––––– 0 1 2 Recognized E60389 Certified LR20812 R9351092 30 ZH CONNECTOR Contact ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Model No. Q'ty / reel SZH-002T-P0.5 0.08 to 0.13 28 to 26 0.8 to 1.1(.031 to .043) 13,000 SZH-003T-P0.5 0.032 to 0.08 32 to 28 0.5 to 0.9(.020 to .035) 16,000 Material and Finish 1.1(.043) Phosphor bronze, tin-plated 0.3 (.012) 1.5 (.059) 0.5(.020) 4.0(.157) 2.2(.087) 1.4(.055) 1.0 (.039) Applicable wire Insulation O.D. mm(in.) AWG # mm2 Housing ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Circuits 2 3 0.3(.012) 4.2(.165) 3.4(.134) 0.3(.012) B A 6 5 3 1.5(.059) 1.5(.059) 4 5 6 6 7 8 9 10 11 12 13 Model No. ZHR- 2 ZHR- 3 ZHR- 4 ZHR- 5 ZHR- 6 ZHR- 6(3.0) ZHR- 7 ZHR- 8 ZHR- 9 ZHR-10 ZHR-11 ZHR-12 ZHR-13 Dimensions mm(in.) B A Q'ty / bag 1.5(.059) 4.5(.177) 1,000 3.0(.118) 6.0(.236) 1,000 4.5(.177) 7.5(.295) 1,000 6.0(.236) 9.0(.354) 1,000 7.5(.295) 10.5(.413) 1,000 15.0(.591) 18.0(.709) 1,000 9.0(.354) 12.0(.472) 1,000 10.5(.413) 13.5(.531) 1,000 12.0(.472) 15.0(.591) 1,000 13.5(.531) 16.5(.650) 1,000 15.0(.591) 18.0(.709) 1,000 16.5(.650) 19.5(.768) 1,000 18.0(.709) 21.0(.827) 1,000 Material Nylon 66, UL94V-0, natural (white) Note: 1. ZHR-6(3.0) is 6 circuits 3.0mm (.118") pitch plugged up. As for this housing, only circuit No.1 is marked. 2. ZHR-6 (3.0) is not UL/CSA approved. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. ZHR-2-oo(blank)…natural (white) K…black R…red E…blue M…green 31 2 1 ZH CONNECTOR Through-hole type shrouded header ––––––––––––––––––––––––––––––––––––––––– The shrouded headers are interchangeable with those of the ZR insulation displacement connectors. Model No. Top entry type B (3 circuits or more) 3.5 (.138) 2.2 (.087) 3.5(.138) 2.7 (.106) 4.5(.177) 1.5 A (.059) 2.7 (.106) 4.5(.177) Note) 3.4(.134) B 0.5 (.020)dia. A 1.5 (.059) 1.5 (.059) 2.2 (.087) Note) 3.4(.134) (2 circuits) Circuits Top entry type Side entry type A 2.7 (.106) 3.7(.146) 2.4(.094) JST 0.5 (.020)dia. 1.4 4.6(.181) (.055) 1.5 (.059) 1.5 (.059) Note) Top entry type Side entry type Dimensions mm(in.) Q'ty / box Top Side A B entry entry type type 2 B 2B-ZR S 2B-ZR B 2B-ZR-3.4 S 2B-ZR-3.4 1.5(.059) 4.5(.177) 2,000 2,000 3 B 3B-ZR S 3B-ZR B 3B-ZR-3.4 S 3B-ZR-3.4 3.0(.118) 6.0(.236) 2,000 2,000 4 B 4B-ZR S 4B-ZR B 4B-ZR-3.4 S 4B-ZR-3.4 4.5(.177) 7.5(.295) 2,000 2,000 5 B 5B-ZR S 5B-ZR B 5B-ZR-3.4 S 5B-ZR-3.4 6.0(.236) 9.0(.354) 2,000 1,000 6 B 6B-ZR S 6B-ZR B 6B-ZR-3.4 S 6B-ZR-3.4 7.5(.295) 10.5(.413) 2,000 1,000 7 B 7B-ZR S 7B-ZR B 7B-ZR-3.4 S 7B-ZR-3.4 9.0(.354) 12.0(.472) 1,000 1,000 8 B 8B-ZR S 8B-ZR B 8B-ZR-3.4 S 8B-ZR-3.4 10.5(.413) 13.5(.531) 1,000 1,000 9 B 9B-ZR S 9B-ZR B 9B-ZR-3.4 S 9B-ZR-3.4 12.0(.472) 15.0(.591) 1,000 1,000 10 B10B-ZR S10B-ZR B10B-ZR-3.4 S10B-ZR-3.4 13.5(.531) 16.5(.650) 1,000 1,000 11 B11B-ZR S11B-ZR B11B-ZR-3.4 S11B-ZR-3.4 15.0(.591) 18.0(.709) 1,000 500 12 B12B-ZR S12B-ZR B12B-ZR-3.4 S12B-ZR-3.4 16.5(.650) 19.5(.768) 1,000 500 13 B13B-ZR S13B-ZR B13B-ZR-3.4 S13B-ZR-3.4 18.0(.709) 21.0(.827) 500 Note) 3.4(.134) B Side entry type Note) 500 Material and Finish Pin: Brass, copper-undercoated, tin/lead-plated Wafer: Glass-filled nylon 66, UL94V-0, natural (ivory) Note: Headers with 3.4mm(.134") long solder tails, suited for the 1.6mm(.063") thick PC board. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. B2B-ZR-3.4-oo(blank)…natural (ivory) K…black R…red E…blue M…green Through-hole type PC board layout (viewed from soldering side) and Assembly layout ––– Top entry type Side entry type 1.5 1.5±0.05 (.059±.002 ) (.059)min. 1.5 1.5±0.05 (.059±.002 ) (.059)min. 3.5 (.138) Note: 1. Tolerances are non-cumulative: ±0.05mm (±.002") for all centers. 2. Hole dimension differ according to the kind of PC board and piercing method. If PC boards made of hard material are used, the hole dimensions should be larger. The dimensions above should serve as a guideline. Contact JST for details. 32 4.6 (.181) [3.4(.134)] 0.7±0.03 (.028±.001 )dia. 2.7 3.7 (.106) (.146) 4.6(.181) [3.4(.134)] 0.7±0.03 (.028±.001 )dia. 2.7 (.106) 5.6(.220) 2.2 (.087)min. 7.1(.280) ZH CONNECTOR SMT type shrouded header ––––––––––––––––––––––––––––––––––––––––––––––––– SM2 type Side entry type 1.5 3.7 (.059) (.146) 1.5(.059) 1.5(.059) 5.0(.197) B A 2.25(.089) 1.5(.059) 1.5 5.0(.197) (.059) 1.0(.039) 1.5 3.7 (.059) (.146) B A SM3, SM4 type (with solder tabs) Top entry type JST 1.0(.039)dia. 0.9(.035) Side entry type 1.5 5.0(.197) (.059) 1.0(.039) 2.25(.089) 1.5(.059) 3.7 (.146) B A SM2 type Circuits Model No. SM3 type Dimensions mm(in.) Model No. Side entry type A B Q'ty / reel 2 S 2B-ZR-SM2-TF 1.5(.059) 4.5(.177) 3 S 3B-ZR-SM2-TF 3.0(.118) 6.0(.236) 4 S 4B-ZR-SM2-TF 4.5(.177) 5 S 5B-ZR-SM2-TF Dimensions mm(in.) B Q'ty / reel Top entry type Side entry type Top entry type Side entry type A 1,000 B 2B-ZR-SM3-TF S 2B-ZR-SM3A-TF 1.5(.059) 6.0(.236) 1,000 1,000 1,000 B 3B-ZR-SM3-TF S 3B-ZR-SM3A-TF 3.0(.118) 7.5(.295) 1,000 1,000 7.5(.295) 1,000 B 4B-ZR-SM3-TF S 4B-ZR-SM3A-TF 4.5(.177) 9.0(.354) 1,000 1,000 6.0(.236) 9.0(.354) 1,000 B 5B-ZR-SM3-TF S 5B-ZR-SM3A-TF 6.0(.236) 10.5(.413) 1,000 1,000 6 S 6B-ZR-SM2-TF 7.5(.295) 10.5(.413) 1,000 B 6B-ZR-SM3-TF S 6B-ZR-SM3A-TF 7.5(.295) 12.0(.472) 1,000 1,000 7 S 7B-ZR-SM2-TF 9.0(.354) 12.0(.472) 1,000 B 7B-ZR-SM3-TF S 7B-ZR-SM3A-TF 9.0(.354) 13.5(.531) 1,000 1,000 8 S 8B-ZR-SM2-TF 10.5(.413) 13.5(.531) 1,000 B 8B-ZR-SM3-TF S 8B-ZR-SM3A-TF 10.5(.413) 15.0(.591) 1,000 1,000 9 S 9B-ZR-SM2-TF 12.0(.472) 15.0(.591) 1,000 B 9B-ZR-SM3-TF S 9B-ZR-SM3A-TF 12.0(.472) 16.5(.650) 1,000 1,000 10 S10B-ZR-SM2-TF 13.5(.531) 16.5(.650) 1,000 B10B-ZR-SM3-TF S10B-ZR-SM3A-TF 13.5(.531) 18.0(.709) 1,000 1,000 11 S11B-ZR-SM2-TF 15.0(.591) 18.0(.709) 1,000 B11B-ZR-SM3-TF S11B-ZR-SM3A-TF 15.0(.591) 19.5(.768) 1,000 1,000 12 S12B-ZR-SM2-TF 16.5(.650) 19.5(.768) 1,000 B12B-ZR-SM3-TF S12B-ZR-SM3A-TF 16.5(.650) 21.0(.827) 1,000 1,000 13 S13B-ZR-SM2-TF 18.0(.709) 21.0(.827) 1,000 B13B-ZR-SM3-TF S13B-ZR-SM3A-TF 18.0(.709) 22.5(.886) 1,000 1,000 Material and Finish Pin: Brass, copper-undercoated, tin/lead-plated Wafer: Glass-filled nylon 46, UL94V-0, natural (white) Solder tab: Brass, copper-undercoated, tin/lead-plated Note: 1. The products listed above are supplied on embossed-tape. 2. Contact JST for the top entry type headers with suction cap. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. S2B-ZR-SM3A-oo-TF(blank)…natural (white) K…black R…red E…blue M…green 33 ZH CONNECTOR SMT type shrouded header ––––––––––––––––––––––––––––––––––––––––––––––––– Dimensions mm(in.) SM4 type Circuits Top entry type 2 3 4 5 6 7 8 9 10 11 12 13 B 2B-ZR-SM4-TF B 3B-ZR-SM4-TF B 4B-ZR-SM4-TF B 5B-ZR-SM4-TF B 6B-ZR-SM4-TF B 7B-ZR-SM4-TF B 8B-ZR-SM4-TF B 9B-ZR-SM4-TF B10B-ZR-SM4-TF B11B-ZR-SM4-TF B12B-ZR-SM4-TF B13B-ZR-SM4-TF Side entry type S 2B-ZR-SM4A-TF S 3B-ZR-SM4A-TF S 4B-ZR-SM4A-TF S 5B-ZR-SM4A-TF S 6B-ZR-SM4A-TF S 7B-ZR-SM4A-TF S 8B-ZR-SM4A-TF S 9B-ZR-SM4A-TF S10B-ZR-SM4A-TF S11B-ZR-SM4A-TF S12B-ZR-SM4A-TF S13B-ZR-SM4A-TF A Q'ty / reel Top entry Side entry type type B 1.5(.059) 6.0(.236) 1,000 1,000 3.0(.118) 7.5(.295) 1,000 1,000 4.5(.177) 9.0(.354) 1,000 1,000 6.0(.236) 10.5(.413) 1,000 1,000 7.5(.295) 12.0(.472) 1,000 1,000 9.0(.354) 13.5(.531) 1,000 1,000 10.5(.413) 15.0(.591) 1,000 1,000 12.0(.472) 16.5(.650) 1,000 1,000 13.5(.531) 18.0(.709) 1,000 1,000 15.0(.591) 19.5(.768) 1,000 1,000 16.5(.650) 21.0(.827) 1,000 1,000 18.0(.709) 22.5(.886) 1,000 1,000 Material and Finish Pin: Brass, copper-undercoated, tin-plated Wafer: Modified PA6T, UL94V-0, natural (white) Solder tab: Brass, nickel-undercoated, tin/copper alloy-plated Note: 1. The products listed above are supplied on embossed-tape. 2. Contact JST for the top entry type headers with suction cap. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. S2B-ZR-SM3A-oo-TF(blank)…natural (white) K…black R…red E…blue M…green SMT type PC board layout (viewed from component side) –––––––––––––––––––––––––––– SM3, SM4 type Top entry type Note: 1. Tolerances are non-cumulative: ±0.05mm(±.002" ) for all centers. 2. The dimensions above should serve as a guideline. Contact JST for details. 34 0.7 (.028) min. 1.5±0.05 1.4±0.1 1.1±0.1 (.059±.002) (.055±.004) (.043±.004) 1.9±0.1 (.075±.004) 4.3 (.169) 2.3±0.1 (.091±.004) 0.6(.024) 2.0 (.079) 2.5 (.098)max. 1.1 + 00.1 (.043 + .004 0 )dia. 1.5±0.05 1.3±0.1 1.5±0.1 (.059±.002) (.051±.004) (.059±.004) 2.0 (.079)min. 1.5 x (No.of circuits - 1) + 0.9 [.059 x (No.of circuits - 1) + .035] 1.5 ± 0.05 0.9 ± 0.05 0.7(.028) (.059 ±.002) (.035 ± .002) Side entry type 0.7 (.028) min. 1.4±0.1 (.055±.004) SM2 type Side entry type ZH CONNECTOR Taping specifications –––––––––––––––––––––––––––––––––––––––––––––––––––––– 330 ± 2.0(12.992 ± .079)dia. Feeding direction [13(.512)dia.] W1 +- 2.5 1.0 ( +.098 - .039 ) Feeding direction Carrier tape Leader part The end part Connector 100(3.937)min. 160(6.299)min. mounting part 400(15.748)min. 2.0 ± 0.5 (.079 ± .020) SM2 type (Side entry type) 2 to 11 circuits SM3, SM4 type (Side entry type) 2 to 10 circuits 1.55±0.05 (.061±.002)dia. 4.0±0.1 (.157±.004) 1.75±0.1 (.069±.004) Feeding direction 1.55±0.05 (.061±.002)dia. 4.0±0.1 (.157±.004) 2.0±0.1 (.079±.004) 1.75±0.1 (.069±.004) SM2 type (Side entry type) 12 to 13 circuits SM3, SM4 type (Side entry type) 11 to 13 circuits Feeding direction 2.0±0.1 (.079±.004) Cover tape leader Cover tape F±0.1 (.004) (S) W±0.3(.012) F±0.1 (.004) S±0.1(.004) W±0.3(.012) Cover tape Carrier tape Carrier tape 12.0 ±0.1 (.472 ±.004) 12.0 ±0.1 (.472 ±.004) SM3, SM4 type (Top entry type) 2 to 10 circuits SM3, SM4 type (Top entry type) 11 to 13 circuits 2.0±0.1 (.079±.004) 1.55±0.05 (.061±.002)dia. 4.0±0.1 (.157±.004) 1.75±0.1 (.069±.004) 1.55±0.05 (.061±.002)dia. 4.0±0.1 (.157±.004) 2.0±0.1 (.079±.004) 1.75±0.1 (.069±.004) Feeding direction Feeding direction Cover tape F±0.1 (.004) (S) W±0.3(.012) F±0.1 (.004) S±0.1(.004) W±0.3(.012) Cover tape Carrier tape Carrier tape 12.0 ±0.1 (.472 ±.004) 12.0±0.1 (.472±.004) Taping dimensions mm(in.) Circuits F Side SM2 entry Type type Top entry type SM3 SM4 Type S 7.5(.295) W Reel dimensions mm(in.) W1 Q'ty / reel 6.75( .266) 16.0( .630) 17.5( .689) 1,000 11.5(.453) 10.75( .423) 24.0( .945) 25.5(1.004) 1,000 12 to 13 14.2(.559) 28.4(1.118) 32.0(1.260) 33.5(1.319) 1,000 2 5.5(.217) 4.75( .187) 12.0( .472) 13.5( .531) 1,000 3 to 5 7.5(.295) 6.75( .266) 16.0( .630) 17.5( .689) 1,000 11.5(.453) 10.75( .423) 24.0( .945) 25.5(1.004) 1,000 11 to 13 14.2(.559) 28.4(1.118) 32.0(1.260) 33.5(1.319) 1,000 2 to 5 7.5(.295) 6.75( .266) 16.0( .630) 17.5( .689) 1,000 11.5(.453) 10.75( .423) 24.0( .945) 25.5(1.004) 1,000 14.2(.559) 28.4(1.118) 32.0(1.260) 33.5(1.319) 1,000 20.2(.795) 40.4(1.591) 44.0(1.732) 45.5(1.791) 1,000 2 to 6 7 to 11 6 to 10 Side 6 to 10 entry type 11 to 12 13 Material and Finish Note: 1. Specifications conform to JIS C 0806. The tape width, connector recess dimensions, etc. are determined by the number of circuits and external shape of the connector to be loaded. 2. Specifications are subject to change without prior notice. 35 ZH CONNECTOR Applicator for the semi-automatic press AP-K2N ––––––––––––––––––––––––––––––– Contact SZH-002T-P0.5 SZH-003T-P0.5 36 Crimp applicator MKS-L with safety cover without safety cover Compact crimp applicator MKS-LS with safety cover without safety cover Strip-crimp applicator MKS-SC with safety cover APLMK SZH002-05 APLNC SZH002-05 – – – APLMK SZH003-05 APLNC SZH003-05 – – APLSC SZH003-05
B13B-ZR
物料型号: - 型号包括SZH-002T-P0.5和SZH-003T-P0.5等。
器件简介: - ZH CONNECTOR是一种小型化的可分离的压接式连接器,具有5.6mm的安装高度和3.5mm的厚度。
引脚分配: - 提供了不同电路数量的型号,如2至13电路。
参数特性: - 电流额定值:1.0A AC/DC (AWG #26) - 电压额定值:50V AC/DC - 温度范围:-25˚C 至 +85˚C - 接触电阻:初始值/20mΩ最大,环境测试后/30mΩ最大 - 绝缘电阻:最小500MΩ - 耐电压:500V AC/分钟 - 适用电线:AWG #32至#26 - 适用PCB板厚:0.6至1.2mm(.024"至.047"),1.6mm(.063")
功能详解: - 设计紧凑,低轮廓。 - 接触保持凸耳在外壳上,便于插入。 - 可靠的接触结构,即使在振动或变形下也能保持低接触电阻。 - 防变形结构,全罩式保护插座。 - 与ZR绝缘位移连接器兼容。
应用信息: - 适用于低电流、低电压条件下使用。
封装信息: - 提供了详细的尺寸信息和材料说明,包括磷青铜镀锡的接触件,尼龙66材质的外壳等。
B13B-ZR 价格&库存
很抱歉,暂时无法提供与“B13B-ZR”相匹配的价格&库存,您可以联系我们找货
B13B-ZR
  • 1+4.506711+0.58307
  • 10+3.7975910+0.49132
  • 100+3.22262100+0.41693
  • 500+2.87645500+0.37215
  • 1000+2.739031000+0.35437
  • 5000+2.444945000+0.31632
  • 10000+2.3282810000+0.30123
库存:495
B13B-ZR
    • 500+0.82910
    库存:5500
    B13B-ZR
      • 500+1.06250
      库存:4586
      B13B-ZR
        • 500+1.40800
        库存:7000
