PR20206HBNN
PR20206HBNN
    METZCONNECT
    弯插,P=2.54mm
    PIN HEADER, THR, SINGLE ROW, .10
PR20206HBNN 数据手册
Page 1/4 Data sheet P/N PR202XXHBNN xx=number of poles PR202xxHBNN 2021/09/15 Version: V Illustrations Dimensional drawing Drill pattern See enlarged drawings at the end of document Product specification • pin header, THR solderable • centerline 2.54 mm, direction of connection 90° • color black • Tape & Reel packaging possible • single row Data sheet Page 2/4 PR202xxHBNN P/N PR202XXHBNN xx=number of poles 2021/09/15 Version: V Technical Data General Data Solder pin length min. number of poles 3 mm max. number of poles 40 Protection category IP00 Rated current 3A 2 Material insulating material PE-HT contact material CuZn Contact surface Ni + Au contact pin material CuZnPb contact pin surface Ni + Au Flash Glow-Wire Flammability GWFI - Glow-Wire Flammability GWIT - Climatic Data upper limit temperature 105 °C lower limit temperature -40 °C general Tolerance ISO 2768 -mH Solderability Acc. to IPC/JEDEC J-STD-020D-MSL 1 Data sheet PR202xxHBNN Page 3/4 P/N PR202XXHBNN xx=number of poles 2021/09/15 Version: V Illustrations Dimensional drawing L=(pole size - 1) x centerline + 2.19 mm [0.086] Data sheet PR202xxHBNN Page 4/4 P/N PR202XXHBNN xx=number of poles 2021/09/15 Version: V Illustrations Drill pattern Powered by TCPDF (www.tcpdf.org)
PR20206HBNN 价格&库存
很抱歉,暂时无法提供与“PR20206HBNN”相匹配的价格&库存,您可以联系我们找货
PR20206HBNN
  • 1+1.625851+0.19661
  • 10+1.2934310+0.15642
  • 100+1.05598100+0.12770
  • 500+0.91497500+0.11065
  • 1000+0.860421000+0.10405
  • 5000+0.745965000+0.09021
  • 10000+0.7015110000+0.08484
库存:877
