ECC06MMSD
ECC06MMSD
    SULLINS
    CONN CARDEDGE MALE 12POS 0.100
ECC06MMSD 数据手册
8 7 4 5 6 F 1 2 3 REV. ECO. NO L 3809 M 4133 REVISIONS DESCRIPTION ADD KEY SLOT IN POSITION, KEY SLOT BETWEEN POSITIONS OPTION, OBSOLETE DWG 12896 (REPLACE WITH DWG 11051) DATE BY 2/13/2018 JH ADD PIN A1, A2, B1, B2 NOTE, REMOVE KEY LOCATION TABLE (REPLACE WITH C13556, CHANGE 10/25/2019 S1013 TO S2425) JH F D C A 2X .125 3.18 E E +.005 +0.13 .370 9.40 - .015 - 0.38 PIN A2 (PIN B2 ON OPPOSITE SIDE) (.025 0.64 ) DEPTH FROM TOP OF INSULATOR TO TOP OF PIN B PIN A1 (PIN B1 ON OPPOSITE SIDE) A FITS EDGECARDS THAT ACCEPT .062 1.57 PCB's D D .540±.010 13.72±0.25 .250 6.35 .030 0.76 .200 5.08 ROW SPACING C .025 0.64 _ _C_ _M_ _D G_C_ _M_ _D-S2196 SECTION A-A MW = .125±.025 3.18±0.64 MS = .190 .025[4.83 0.64] MM = .560 .025[14.22 0.64] .100 2.54 A C C A 2X PIN B1 PIN B2 .125 3.18 .200 5.08 B B PIN A1 PIN A2 .043 1.09 MIN NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING RECOMMENDED PCB LAYOUT 2. CONTACT MATERIAL: SEE PART NUMBER CODING (COMPONENT SIDE) 3. PLATING: SEE PART NUMBER CODING 4. OPERATING TEMPERATURE: SEE PART NUMBER CODING 5. PROCESSING TEMP: SEE PART NUMBER CODING UNLESS OTHERWISE SPECIFIED: DRAWN 6. UL FLAMMABILITY RATING: 94V-0 DIMENSIONS ARE IN INCHES [MM] 7. OPERATING VOLTAGE: 700 VAC TOLERANCES: 8. CURRENT RATING: 3 AMP ANGULAR: 1 9. CONTACT RESISTANCE: 30 MILLI OHMS MAX 10. INSULATION RESISTANCE: 5000 MEGA OHMS DECIMALS .XX= .02 [.5] 11. CONNECTOR IDENTIFICATION: PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE .XXX= .005 [.13] 12. MODIFICATION: SEE PART NUMBER CODING .XXXX= .0005 [.013] CUSTOMER COPY A Pb 7 6 5 4 NAME 02/05/08 MNH THE INFORMATION HEREIN CONTAINS PROPRIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. RoHS COMPLIANT 8 DATE TITLE MALE, EDGECARD, .100 CC PART NUMBER SIZE C _ _C_ _M(MW,MS,MM)_-(S2196) CAGE CODE 54453 SCALE: 3:1 3 A 2 DWG. NO. C11051 SHEET 1 OF 4 1 REV M FILE NAME: C11051, _ _C_ _M(MW,MS,MM)_-OMIT, S2196, S_ _ _ _ STD KEY 8 7 4 5 6 1 2 3 F F 2X #4-40 THREADED INSERTS E C E E D G_C_ _M_ _T-(OMIT, S2196) _ _C_ _M_ _N G_C_ _M_ _N-S2196 2X D .125 3.18 C C C C 2X .125 3.18 .125 3.18 B .125 3.18 B _ _C_ _M_ _V G_C_ _M_ _V-S2196 2X #4-40 THREADED INSERTS _ _C_ _M_ _Z G_C_ _M_ _Z-S2196 CUSTOMER COPY Pb A RoHS COMPLIANT 8 7 6 5 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 02/05/08 MNH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPRIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE MALE, EDGECARD, .100 CC PART NUMBER SIZE C _ _C_ _M(MW,MS,MM)_-(S2196) CAGE CODE 54453 SCALE: 3:1 3 A 2 DWG. NO. C11051 SHEET 2 OF 4 1 REV M FILE NAME: C11051, _ _C_ _M(MW,MS,MM)_-OMIT, S2196, S_ _ _ _ STD KEY 8 7 4 5 6 1 2 3 F F E E D D C C B B CUSTOMER COPY Pb A RoHS COMPLIANT 8 7 6 5 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 02/05/08 MNH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPRIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE MALE, EDGECARD, .100 CC PART NUMBER SIZE C _ _C_ _M(MW,MS,MM)_-(S2196) CAGE CODE 54453 SCALE: 3:1 3 A 2 DWG. NO. C11051 SHEET 3 OF 4 1 REV M FILE NAME: C11051, _ _C_ _M(MW,MS,MM)_-OMIT, S2196, S_ _ _ _ STD KEY 8 7 4 5 6 1 2 3 F F E E H G .036±.002 0.91±0.05 MOLDED KEY BETWEEN POSITION .074±.002 1.88±0.05 MOLDED KEY IN POSITION D D ('D' MOUNTING AS SHOWN FOR EXAMPLE) C ('D' MOUNTING AS SHOWN FOR EXAMPLE) MATING SULLINS PRODUCT SERIES: 1. STD LOW PROFILE FEMALE CONNECTORS WITH MOLDED KEY IN POSTION 2. STD HIGH PROFILE FEMALE CONNECTORS WITH MOLDED KEY IN POSITION C MATING SULLINS PRODUCT SERIES: 1. STD LOW PROFILE FEMALE CONNECTORS WITH MOLDED KEY BETWEEN POSTIONS, OR WITH INBETWEEN CONTACT KEY (SULLINS P/N: PLA-K1) 2. HIGH PROFILE FEMALE CONNECTORS WITH MOLDED KEY .030" WIDE BETWEEN POSITIONS (CONSULT FACTORY FOR PART NUMBER) B B CUSTOMER COPY Pb A RoHS COMPLIANT 8 7 6 5 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 02/05/08 MNH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPRIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C _ _C_ _M(MW,MS,MM)_-(S2196) CAGE CODE 54453 SCALE: 3:1 3 A MALE, EDGECARD, .100 CC 2 DWG. NO. C11051 SHEET 4 OF 4 1 REV M FILE NAME: C11051, _ _C_ _M(MW,MS,MM)_-OMIT, S2196, S_ _ _ _ STD KEY
ECC06MMSD AI解析
PDF文档包含了详细的技术规格和设计信息,但未提供物料型号器件简介功能详解应用信息
以下是从文档中提取的相关信息:
1. 引脚分配:文档描述了两种引脚配置,PIN A1和A2在一边,PIN B1和B2在另一边,具体尺寸和公差有详细说明。
2. 参数特性: - 操作电压:700 VAC - 电流额定值:3 AMP - 接触电阻:最大30毫欧姆 - 绝缘电阻:5000兆欧姆 - UL阻燃等级:94V-0 3. 封装信息:提供了不同位数的连接器尺寸,包括位置数量、A、B、C、D和E的尺寸数据。
4. 推荐PCB布局:文档中提到了接触材料和UL阻燃等级。
5. 材料和镀层:提供了不同材料代码和对应的操作温度、加工温度等信息。
6. 修改信息:文档中提到了如何根据部件编号编码进行修改。
请注意,这是根据PDF文档内容的直接翻译和总结,可能缺少更广泛的背景信息或应用场景描述。
如果需要更详细的分析或特定部分的解释,请提供更具体的查询或要求。
*介绍内容由AI识别生成
ECC06MMSD 价格&库存
很抱歉,暂时无法提供与“ECC06MMSD”相匹配的价格&库存,您可以联系我们找货
