NRPN232PAEN-RC
NRPN232PAEN-RC
    SULLINS
    CONN HEADER VERT 46POS 2MM
NRPN232PAEN-RC 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO F 2024 H 2828 F DESCRIPTION DATE HEAD HEIGHT 3.60mm WAS 4.00mm, UPDATE WARP 9/15/2009 TOLERANCE UPDATE PROCESSING TEMPERATURE FOR NYLON 6T MATERIAL, UPDATE DIM 'B' TOL TO .50mm )WAS .35mm), UPDATE CURRENT RATING TO 2 AMPS 04/09/2015 (WAS 1 AMP) BY JH LH F E E .157 4.00 B±.020 [ .50] A±.010 [ .25] D D .079±.002 2.00±0.05 .079±.002 2.00±0.05 .142±.008 3.60±0.20 .079 2.00 C C .110±.008 2.80±0.20 .020±.002 0.50±0.05 A±.004 [ .10] .031±.002 0.80±0.05 02-20, 0.20mm MAX. 21-30, 0.30mm MAX. 31-40, 0.40mm MAX. B .079±.002 2.00±0.05 B .079±.002 2.00±0.05 A NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING. 2. CONTACT MATERIAL: BRASS. 3. CONTACT PLATING: GOLD FLASH OVERALL. 4. CURRENT RATING: 2 AMPS 5. VOLTAGE RATING: 150V AC/DC. 6. INSULATOR RESISTANCE: 5000 MEGOHMS MIN. 7. CONTACT RESISTANCE: 20 MILLIOHMS MAX. 8. DIELECTRIC WITHSTANDING: 500V AC. 9. OPERATING TEMPERATURE: -40° C TO +105° C. 10. PROCESSING TEMP.: WAVE/MANUAL SOLDERING ONLY. 8 7 6 RECOMMENDED PCB LAYOUT Pb RoHS COMPLIANT 5 4 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] TOLERANCES: ANGULAR: 1 DECIMALS .X= .012 [.30] .XX= .008 [.20] .XXX= .006 [.15] DRAWN DATE NAME 12/12/2005 YCH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE HEADER, MALE 2mm CC, 2 ROWS, ST PART NUMBER SIZE C CAGE CODE 54453 SCALE: 12:1 3 2 NRPNxx2PAEN-RC DWG. NO. 10637 SHEET 1 OF 1 1 REV H FILE NAME: 10637, NRPNxx2PAEN-RC A
NRPN232PAEN-RC 价格&库存
很抱歉,暂时无法提供与“NRPN232PAEN-RC”相匹配的价格&库存,您可以联系我们找货
