Mixed Signal/ Power Contact Size Mini-Con-X®
NPB 631
Power and Signal contacts
in the same Mini-Con-X
connectors
Cable End, Panel Mount,
and Cable-to-Cable
Connectors Available
Made From High Quality, UV
Resistant Thermoplastic
(UL F1 rated)
Two options available:
6 pin (2#16 4#20) &
8-pin (2 #16, 6#26)
FEATURES
APPLICATIONS
Combine signal and power into the same
connector, saving space and cost.
Cable End, Panel Mount, and Cable-to-Cable
(In-Line) options available with male pin or
female socket contacts.
Fits the same overall dimensions as existing
Mini-Con-X® connectors
Made by Conxall® in the USA
Also available as factory molded cables
See drawings on Switchcraft.com for detailed
specifications
Outdoor Instrumentation
Agriculture and construction vehicles
Communication devices
Safety and Security equipment
601 EAST WILDWOOD, VILLA PARK, IL 60181 - 630.834.7504 - SALES@CONXALL.COM
NPB 631
OVERALL DIMENSIONS
0.92
23.5
1.9
48
0.80
20.3
13/16 HEX
0.71
18
CABLE END
0.582
14.78
2.0
51
0.610
15.49
PANEL MOUNT
CABLE-TO-CABLE
RECOMMENDED
PANEL CUTOUT
ALL DIMENSIONS ARE FOR REFERENCE ONLY
ORDERING CODE/ CONTACT LAYOUTS (Panel Mount Wiring Side)
W
Connector Type:
X
X
XX
XXX
XXX
6: Cable End
KEY
W
Special Features
W: Winged Coupling Ring
7: Panel Mount
8: Cable to Cable
Cable-end and Cable-to-cable
Backshell with Grommet Cable O.D. Range:
Mixed Contact Sizes:
A: #16 & #26
C: #16 & #20
6 POSITON
2 #16 & 4 #20
PIN OR SOCKET
CONTACTS
513: 0.13-0.15" (3.3 -3.8 mm)
Contacts Style:
516: 0.16-0.18" (4.1 -4.6 mm)
80: Crimp
519: 0.19-0.21" (4.8 -5.3 mm)
81: PC Tail
522: 0.22-0.25" (5.6 -6.3 mm)
82: Solder
528: 0.26-0.285" (6.6 -7.2 mm)
KEY
Positions & Contact Types:
6PG: 6 Pins (2-16 + 4-20)
Panel Mount:
6SG: 6 Sockets (2-16 + 4-20)
300: with Hex Nut & Gasket
8PG: 8 Pins (2-16 + 6-26)
3ES: 300 with Epoxy
8 POSITON
2 #16 & 6 #26
PIN OR SOCKET
CONTACTS
8SG: 8 Sockets (2-16 + 6-26)
Mixed Contacts
Arrangement
Wire
(AWG)
Maximum Current Rating (A)
at Maximim Operating Temperature (°C)
85°C max
2-#16 / 4-#20
2-#16 / 6-#26
2x16
10
4x20
4
2x16
10
6x26
2
Temperature Rise does not exceed 30°C when tested according to UL2238
Minimum
Test
Voltage
(V rms)
Voltage
Rating
(V rms)
1300
125
1700
250
Tested per UL2238
VISIT WWW.SWITCHCRAFT.COM FOR THE MOST UP-TO-DATE PRODUCT SPECIFICATIONS
NPB 631
SPECIFICATIONS
MECHANICAL:
Mating / Locking Type:
Life:
Vibration:
Panel Hex Nut Tongue:
Back Shell Type:
Bayonet with ribbed coupling ring
(winged coupling ring available)
300 cycles minimum
Mil-Std 202G Method 201A
8-10 in-lb [0.8-1.1 Nm]
Twist lock
ELECTRICAL:
Voltage Rating:
Current Rating:
Insulation Resistance:
Contact Resistance:
125 V rms for 6 contact arrangement
250 V rms for 8 contact arrangement
10A max for #16 contacts
Refer to table on pg3 for detailed information
1000 MΩ minimum
10 mΩ typical
ENVIRONMENTAL:
Operating Temperature:
Moisture Resistance:
Thermal Shock:
Salt Atmosphere :
Ingress Protection :
-40ºC to +85ºC (-40ºF to +185°F)
Refer to website for detailed information
Mil-Std 202G Method 106G
Mil-Std 202G Method 302 Condition B
Mil-Std 202G Method 107G
Mil-Std 202G Method 101E Condition B
IP67 (consult factory for specific application)
MATERIAL:
Connector Shell (Insulator)
Hex Nut:
Coupling Ring:
Cable Clamp:
Backshell:
Seal O-rings:
Seal Grommet:
Contacts:
Thermoplastic, black
Elastomer, red
Elastomer, black
Copper Alloy, gold over nickel plating
很抱歉,暂时无法提供与“W7C82-6PG-300”相匹配的价格&库存,您可以联系我们找货
