EBM22MMND
EBM22MMND
    SULLINS
    P=3.96mm
EBM22MMND 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY F 2868 UPDATE 'BOM' ON PRODUCTION DRAWING 11/26/2013 KV H 3182 UPDATE DWG FORMAT, UPDATE INSERT INSTALLATION IN 'V' MOUNTING 4/16/2015 MG J 3652 REMOVE 'A' MATERIAL, ADD 'Q' MATERIAL, , UPDATE 'R' MATERIAL OPERATING TEMPERATURE, REMOVE 'Y' & 'S' PLATING 4/6/2017 EP F E F E D C 2X A .125 3.18 THRU +.005 +0.13 .370 9.40 - .015 - 0.38 D D B (.025 0.64 ) DEPTH FROM TOP OF INSULATOR TO TOP OF PIN A FITS EDGECARDS THAT ACCEPT .062 1.57 PCB's .540±.010 13.72±0.25 .250 6.35 C C .030 0.76 ACCOMMODATES .062[1.57] PCB A .025 0.64 MR = .175±.025 4.45±0.64 MN = .545 .025[13.84 0.64] .156 3.96 _ _M_ _M_ _D SECTION A-A B A B NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING 2. CONTACT MATERIAL: SEE PART NUMBER CODING 3. PLATING: SEE PART NUMBER CODING 4. OPERATING TEMPERATURE:SEE PART NUMBER CODING 5. PROCESSING TEMP: SEE PART NUMBER CODING 6. UL FLAMMABILITY RATING: 94V-0 7. OPERATING VOLTAGE: 950 VAC 8. CURRENT RATING: 3 AMP 9. CONTACT RESISTANCE: 30 MILLI OHMS MAX 10. INSULATION RESISTANCE: 5000 MEGA OHMS 11. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE 8 7 6 5 CUSTOMER COPY Pb RoHS COMPLIANT 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 03/14/08 MNH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C 2 _ _M_ _M(MR,MN)_ CAGE CODE 54453 SCALE: 3:1 3 A MALE, CARD EXTENDER, .156 CC DWG. NO. C11074 SHEET 1 OF 3 1 REV J FILE NAME: C11074, _ _M_ _M(MR,MN)_ 8 7 4 5 6 1 2 3 F F 2X #4-40 THREADED INSERTS E C E E _ _M_ _M_ _N _ _M_ _M_ _T D D 2X .125 3.18 C C C C 2X .125 3.18 .125 3.18 B .125 3.18 B 2X #4-40 THREADED INSERTS _ _M_ _M_ _Z _ _M_ _M_ _V CUSTOMER COPY Pb A RoHS COMPLIANT 8 7 6 5 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 03/14/08 MNH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C 2 _ _M_ _M(MR,MN)_ CAGE CODE 54453 SCALE: 2:1 3 A MALE, CARD EXTENDER, .156 CC DWG. NO. C11074 SHEET 2 OF 3 1 REV J FILE NAME: C11074, _ _M_ _M(MR,MN)_ 8 7 4 5 6 1 2 3 F F E E D D C C B B CUSTOMER COPY Pb A RoHS COMPLIANT 8 7 6 5 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 03/14/08 MNH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C 2 _ _M_ _M(MR,MN)_ CAGE CODE 54453 SCALE: 2:1 3 A MALE, CARD EXTENDER, .156 CC DWG. NO. C11074 SHEET 3 OF 3 1 REV J FILE NAME: C11074, _ _M_ _M(MR,MN)_
EBM22MMND 价格&库存
很抱歉,暂时无法提供与“EBM22MMND”相匹配的价格&库存,您可以联系我们找货
