8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
DESCRIPTION
DATE
BY
D
2515
ADD NOTE 10 MATING PARTS.
01/16/2012
LH
E
3120
UPDATE PROCESSING TEMPERATURE FOR NYLON 6T
MATERIAL AND CURRENT RATING TO 2 AMPS (WAS 1 AMP),
UPDATE STRAIGHTNESS TOL
04/15/2015
LH
F
F
E
E
.110±.008 2.80±0.20
.063±.008 1.60±0.20
D
D
.079±.002 2.00±0.05
.020 0.50
A±.010[ 0.25]
B±.012[ 0.30]
.122±.012 3.10±0.30
.047 1.20
C
.169 4.30
C
.181±.012 4.60±0.30
.008 0.20
02-20, 0.20mm MAX.
21-35, 0.30mm MAX.
36-40, 0.40mm MAX.
A±.004[ 0.10]
.079±.002 2.00±0.05
B
A
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING.
2. CONTACT MATERIAL: PHOSPHOR BRONZE.
3. CONTACT PLATING: .000030"-.000050" MIN NICKEL UNDERPLATE, GOLD FLASH OVERALL.
4. CURRENT RATING: 2 AMP.
5. INSULATOR RESISTANCE: 5000 MEGOHMS MIN.
6. CONTACT RESISTANCE: 20 MILLIOHMS MAX.
7. DIELECTRIC WITHSTANDING: AC 500V.
8. OPERATING TEMPERATURE: -40° C TO +105° C.
9. *PROCESSING TEMP.: WAVE/MANUAL SOLDERING ONLY.
10.MATES WITH SULLINS .079 [2.00] CONTACT CENTER MALE HEADER SERIES.
(.020 [0.50] SQUARE POSTS)
RECOMMENDED PCB LAYOUT
Pb
RoHS COMPLIANT
8
7
6
5
B
.031±.002 0.80±0.05
4
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES [MM]
TOLERANCES:
ANGULAR:
5
DECIMALS
.X= .012 [.30]
.XX= .008 [.20]
.XXX= .006 [.15]
DRAWN
DATE
NAME
03/23/2009 JH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
HEADER FEMALE, 2mm CC, 1 ROW, RA
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 4:1
3
2
NPPNxx1FGGN-RC
DWG. NO.
10490
SHEET 1 OF 1
1
REV
E
FILE NAME: 10490, NPPNxx1FGGN-RC
A
很抱歉,暂时无法提供与“NPPN071FGGN-RC”相匹配的价格&库存,您可以联系我们找货
