BG305-02-A-0500-L-G
BG305-02-A-0500-L-G
    GCT
    插件,P=2.54mm
    排针 间距:2.54mm 1x2P 直插
BG305-02-A-0500-L-G 数据手册
Ø B±0.20 F D±0.30 2.50±0.10 G 10 1. 7.00±0.20 D H 2.54 3.00±0.20 A ±0.50 Recommended PCB Layout (Tolerance:±0.05mm) Specifications E Plating Underplating: 30µ”-50µ” Nickel Contact Area: Gold Flash 2.50±0.10 D Material Insulator: LCP, UL94V-0, Natural Contact: Brass Ordering Grid 0.64 sq. Pin BG305 2.54±0.10 No. of Contacts 2 3 4 5 6 7 8 9 10 11 12 C B A XX X 0500 L X No. of Contacts 02 to 12 Packing Options G = Plastic Box (Standard packing for 2 contacts) D = Tube (Standard packing for 3-6 contacts) Contact Plating A = Gold Flash All Over Dimensions A B 5.08 2.54 7.62 5.08 10.16 7.62 12.70 10.16 15.24 12.70 17.78 15.24 20.32 17.78 22.86 20.32 25.40 22.86 27.94 25.40 30.48 27.94 Request Samples and Quotation Insulator Material L = LCP (Natural) (Other plating options available on request) e.g. 1000 = 10.00mm (Maximum 2500=25.00mm) (Minimum 0500=5.00mm) Mates with: BG306 or Direct solder to PCB Part Number Product Description BG305 2.54mm Pitch Pin Header, Single Row, U-Shaped, Thru-Hole, Dual Insulator, Natural LCP Drawing Date 7th December 2011 By 2 Mechanical & Environmental Operating Temperature: -40°C to +105°C Soldering Process: Wave : 250°C for 5-10 sec. Manual Solder: 350°C for 3-5 sec Dimension D (Footprint width) 0500 = 5.00mm (Standard) Or specify custom Footprint Width Detail 1 Electrical Current Rating: 3A per pin Contact Resistance: 20 mΩ max. Insulating Resistance: 1000 MΩ min. Dielectric Withstand Voltage: 500V AC 3 4 Revision Date 5 CC Drawing Release A4 01/11/17 Tolerances (Except as Noted) Length Angle Units: Metric (mm) X.X ± 0.30 X.XX ± 0.20 C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By CM 8 Sheet No. 1/1
BG305-02-A-0500-L-G 价格&库存
很抱歉,暂时无法提供与“BG305-02-A-0500-L-G”相匹配的价格&库存,您可以联系我们找货
