IPSLD-3-BL-S120-M40A-UL
    PEI-GENESIS(倍捷)
    CONN PLUG FMALE 1P SILVER SCREW
IPSLD-3-BL-S120-M40A-UL 数据手册
E L G N I R S O T 7 6 C ® IP E N N L A O E C S R E E R W U O S EP L O P www.peigenesis.com I www.peigenesis.cn sales@peigenesis.com High Current Capacity The connector’s advanced contact design achieves its 800A* continuous rating by utilizing an arrangement of 29 transfer bridges. Each transfer bridge is rated at 30A, giving a total of 870A* per contact. International Electrical Color Coding Standards Region Earth Key E Neutral Key N Line 1 Key 1 Line 2 Key 2 Line 3 Key 3 Europe & UK (Harmonized) UK (Traditional) Australia USA Range - Key Specifications No of Contacts: 1 Maximum Continuous Current Rating*: Up to 800A Surge Current: 75kA Short Circuit Rating: Up to 35.5kA Cables Cross Sectional Area C.S.A.: 25 mm2 to 300 mm2 Contact Termination: Screw or Crimp Mating Method: Bayonet Lock Operating Voltage: 1000V AC Max Rated Voltage to Earth: 2kV AC / 3kV DC Minimum Flashover: 9.5kV DC or AC Peak Insulation Resistance: > 5M ohms @ 500V DC Ingress Protection**: IP67 Protection against Electrical Shock: IP2X Flammability: UL94-V0 Mating Cycles: > 500 Shell Material: High Temperature Thermoplastic Contact Plating: Silver *Subject to environmental factors and cable choice etc. **In accordance with EN60529. Single Pole Connectors Sure-Seal single pole connectors are a popular choice for engineers working in harsh environments across the globe. With a rugged design and excellent reliability and quality, they are the go-to option for high-power systems in entertainment & industrial applications. Design These connectors are designed with impressive technical capabilities and added safety features in order to connect single and three-phase high-current power circuits. They are available in cable and panel-mount formats with either crimp or screw contacts. Safety Features Safety is of the utmost importance in high-current applications. Every Sure-Seal single pole connector features finger-proofed electrical contacts in order to cut down on the risk of accidental contact when a live current is running through it. They are rated at 500A and 800A for single core cables from 25 – 300 mm2, ranking them among the safest connectors in their class. They also feature a secondary locking system which can only be unlocked with a key. Key Features: • IP67 ingress protection • Flame retardant (UL94-V0) • High impact bodies & high temperature-resistant materials • Rubber hand grip for ease of coupling and added impact protection • 800A maximum (505A UL Product) • Color coded & mechanically keyed to prevent connection errors • Locking mechanism to prevent accidental disconnection under load • Finger-proof contacts to prevent access to electrical contacts when uncoupled (M & F) • Multipoint, self-wiping contact area • Integral cable strain relief • Metric EN-compliant cable glands, with increased cable clamping range • No special tools required for assembly • Daisy chain hook-up system • Panel mount connector & mounting plates • Rubber protective caps to protect connectors from moisture, dirt and abrasion when uncoupled (optional) How to Order Sure-Seal Line Connectors 1 2 3 IPSLS SERIES - 4 E - GN KEY POSITION ORIENTATION - COLOR 6 S 120 CONTACT TYPE CABLE SIZE 7 8 M40A -UL CABLE SEALING RANGE UL RATING - CONTACT TYPE S = Set Screw C = Crimp L = Cable Lug (RA only) AC = Bi Metal Crimp** (for use with Aluminum cable only) SERIES IPSLS = Line Source IPSLD = Line Drain ORIENTATION = Straight (leave blank for straight) -RA = Right angled* CABLE SIZE 120 = 120 mm2 150 = 150 mm2 185 = 185 mm2 KEY POSITION E = Earth N = Neutral 1 = Line 1 2 = Line 2 3 = Line 3 COLOR GN = Green BL = Blue BN = Brown 5 240 = 240 mm2 300 = 300 mm2 additional sizes available upon request CABLE SEALING RANGE M40S = 15 - 23 mm2 M40B = 22 - 32 mm2 M40A = 19 - 28 mm2 M50 = 30 - 38 mm2 BK = Black GY = Grey R = Red UL RATING = Standard (leave blank for non-UL) -UL = UL Listed Y = Yellow W = White OR = Orange * Right angled connectors available for 30-240 mm2 cables non-UL | Set screw up to 150 mm2, Crimp up to 300 mm2 ** Bi metal contacts are not available for UL listed product and only available in 120 mm2 - 150 mm2 UL | Set screw contacts up to 120 mm2 (250 kcmil) Crimp up to 150 mm2 (300 kcmil) Sure-Seal Panel Connectors 1 IPSPD 2 - 3 E SERIES - KEY POSITION GN - COLOR 4 5 T5 -UL CONTACT TYPE UL RATING SERIES IPSPS = Panel Source IPSPD = Panel Drain CONTACT TYPE T5 = M12 Threaded Post (500A / 455A UL) T8 = M12 Threaded Post (800A / 600A UL) KEY POSITION E = Earth N = Neutral 1 = Line 1 2 = Line 2 3 = Line 3 UL RATING = Standard (leave blank for non-UL) -UL = UL Listed COLOR GN = Green BL = Blue BN = Brown BK = Black GY = Grey R = Red Y = Yellow W = White OR = Orange Line Drain Line Source Panel Source Panel Drain Line Source Line Drain Product Dimensions Panel Source Panel Drain 42.5 42.5 42.5 Ø 5 5. Ø 42.5 5 5. 4Panel 4 Ø4 Ø4 Cutout Ø 7 7 Ø4 Line Source 5 5. Ø 5 5. Panel Cutout Ø4 Line Drain Right Angled Connectors Sure-Seal Right Angled Connectors allow cables to be hung at 90 degrees when connected to Panel Mount Connectors. The device allows for reduced cable protrusion, this is a useful option where minimal space is available for connection of temporary power cables. The Right Angled Connector is fully compatible with all other Sure-Seal connectors. Termination of the cable is simple with nothing more than spanner required. A cable lug can be locked onto a threaded post inside the backshell. Standard sizes are supplied with a 120 x M12 Lug. Source, and Drain configurations can be supplied. Other colors and sizes are available. Corporate Headquarters, Philadelphia, PA European Headquarters & Production Facility, Southampton, UK North American Production Facility, South Bend, IN Production Facility, Zhuhai, China FilConn, Chandler, AZ PEI-Genesis has sales offices throughout the Americas, Europe and Asia. Visit www.peigenesis.com, call +1 800.675.1214 (North America), +44 (0) 23 8062 1260 (Europe), +86 756 7683 088 (Asia), +1 631.475.5050 (Rest of World), or email: sales@peigenesis.com. www.peigenesis.com | www.peigenesis.cn
IPSLD-3-BL-S120-M40A-UL 价格&库存
很抱歉,暂时无法提供与“IPSLD-3-BL-S120-M40A-UL”相匹配的价格&库存,您可以联系我们找货
