FGG.1B.307.CLAD52
FGG.1B.307.CLAD52
    LEMO(雷莫)
    FGG.1B.307.CLAD52
FGG.1B.307.CLAD52 数据手册
FGG.1B.307.CLAD52 www.lemo.com SUMMARY # Wires Low voltage 7 Image is for illustrative purpose only Series 1B Termination type Male solder IP rating 50 AWG wire size 30.00 - 22.00 Catalog Cable Ø 4.30 - 5.20 mm See video assembly instructions Status active Matching parts EGG.1B.307.CLL Download Request a quote Eplan PHG.1B.307.CLLD52 TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 15.39 g Performance Configuration 1B.307 : 7 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 7 Amps Specifications Contact Type: Solder Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.8 mm (0.031in) Max. Stranded Conductor: 0.34 mm^2 (AWG 22) Max. Conductor: 0.34 mm^2 (AWG 22) R (max): 6.1 mOhm Vtest (contact-shell): 1050 V (AC), 1490 V (DC) Vtest (contact-contact): 950 V (AC), 1340 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S1 S2 mm. 12 43 32 10 9 in. 0,47 1,69 1,26 0,39 0,35 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.1B.015.PA090 Caps: BFG.1B.100.PCSG LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables CMN.07.T28.044PGZE Grey CMN.07.T28.044PNZE 70140 PVC Grey LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.1B.307.CLAD52 价格&库存
很抱歉,暂时无法提供与“FGG.1B.307.CLAD52”相匹配的价格&库存,您可以联系我们找货
FGG.1B.307.CLAD52
    • 1+268.25003
    • 5+259.86689
    • 25+251.19217
    • 50+242.81944
    库存:279
    FGG.1B.307.CLAD52
      • 1+379.785051+48.86232
      • 10+366.4635110+47.14840
      • 25+342.4313925+44.05648
      • 50+321.3578250+41.34520
      库存:100
      FGG.1B.307.CLAD52
      • 1+382.255601+48.68520
      • 10+324.8922010+41.37920
      • 25+300.6477025+38.29140
      • 50+299.3649050+38.12800
      库存:79
      FGG.1B.307.CLAD52
      • 1+394.832771+51.28678
      • 10+335.6158510+43.59480
      • 30+310.5870030+40.34368
      • 50+309.2296250+40.16736
      库存:198
