Additional Resources:
Product Page
3D Model
PCB Footprint
date
09/01/2020
page
1 of 5
SERIES: MD-S │ DESCRIPTION: MINI DIN CONNECTOR
FEATURES
• PCB mount
• right angle
• non-shielded
PART NUMBER KEY
MD - XX S
Base Number
Notes:
*Discontinued models MD-30S & MD-50S
Pin Options
30* = 3 pins
40 = 4 pins
50* = 5 pins
60 = 6 pins
70 = 7 pins
80 = 8 pins
90 = 9 pins
SPECIFICATIONS
parameter
conditions/description
rated input voltage
3~8 pin models
9 pin model
rated input current
3~8 pin models
9 pin model
min
typ
max
30
12
contact resistance
insulation resistance
Vdc
Vdc
1
2
A
A
30
mΩ
100
voltage withstand
3~8 pin models for 1 minute
9 pin model for 1 minute
insertion force
3~8 pin models
9 pin model
withdrawal force
3~8 pin models
9 pin model
MΩ
life
flammability rating
UL94V-0
RoHS
yes
Vac
Vac
45
35
N
N
N
N
-25
3~8 pin models
9 pin model
500
250
7
10
operating temperature
50
500
5,000
cuidevices.com
units
°C
cycles
cycles
Product Page
3D Model
PCB Footprint
CUI Devices │ SERIES: MD-S │ DESCRIPTION: MINI DIN CONNECTOR
date 09/01/2020 │ page 2 of 5
SOLDERABILITY
parameter
min
hand soldering
for 1~3 seconds
230
typ
max
units
250
°C
MECHANICAL DRAWINGS (MD-30S, MD-40S, MD-50S)
units: mm
tolerance:
X.X ±0.38 mm
X.XX ±0.25 mm
X.XXX ±0.13 mm
MATERIAL
MD-30S
body
PBT+30%GF
(UL94V-0)
pins
brass
tin
shield
brass
nickel
MD-40S
8
3
MD-50S
6
5
2.2X0.7
2.2X0.7
8
4.7 0.185
8.5 0.335
(2 PLCS)
1
0.9 0.035
(3 PLCS)
+0.1
-0.0
PLATING
2
11.0 0.433
6
4.7 0.185
3
5
2
2.5*1
3
0.9 0.035
6.8 0.268
Recommended PCB Layout
Top View
8.5 0.335
(3 PLCS)
Top View
cuidevices.com
0.9 0.035
(5 PLCS)
+0.1
-0.0
4
1
3
11.0 0.433
(2 PLCS)
5
1.3 0.051
6.8 0.268
(2 PLCS)
Top View
Product Page
3D Model
PCB Footprint
date 09/01/2020 │ page 3 of 5
MECHANICAL DRAWINGS (MD-60S, MD-70S, MD-80S)
units: mm
tolerance:
X.X ±0.38 mm
X.XX ±0.25 mm
X.XXX ±0.13 mm
MATERIAL
pins
brass
tin
shield
brass
nickel
MD-80S
6
8
1
5
2
8
6
2
6
4
3
1
8
7
8
5
3
3
body
MD-70S
MD-60S
2
PLATING
PBT+30%GF
(UL94V-0)
5
3
7
2
4
1
6
5
2.5*1
2.5*1
Top View
1
Top View
cuidevices.com
Top View
Product Page
3D Model
PCB Footprint
date 09/01/2020 │ page 4 of 5
MECHANICAL DRAWING (MD-90S)
units: mm
tolerance:
X.X ±0.35 mm
X.XX ±0.25 mm
X.XXX ±0.15 mm
MATERIAL
PLATING
body
PBT (UL94V-0)
cover
PBT (UL94V-0)
ground
brass
copper/tin
pins
brass
copper/tin
12.3±0.2
14±0.2
1.7±0.2
6
8
7
5
4
2
1
3
3.5
9
3.3
9-0.6
2
4.85±0.2
3.8±0.25
8.2±0.25
7.7±0.25
11±0.25
㻝
㻥㻙㽣
2.5*1
5
2
4
1
7
3
1.5
Top View
cuidevices.com
11
6
0.5
8
8.2
9
4.85
6.5
13±0.2
A
Product Page
3D Model
PCB Footprint
date 09/01/2020 │ page 5 of 5
REVISION HISTORY
rev.
description
date
1.0
initial release
02/23/2006
1.01
new template applied
02/16/2012
1.02
housing updates
03/29/2012
1.03
updated datasheet
08/25/2017
1.04
discontinued models MD-30S and MD-50S, brand update
10/08/2019
1.05
updated housing
12/12/2019
1.06
updated PCB footprints
09/01/2020
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“MD-90S”相匹配的价格&库存,您可以联系我们找货
