SF8382-3SG-530
SF8382-3SG-530
    SWITCHCRAFT
    CONN RCPT FMALE 3POS SOLDER CUP
SF8382-3SG-530 数据手册
NOTES: 1. FINISHED ASSEMBLIES AND LOOSE PARTS BAGGED. 2. LABEL WITH CONXALL PART NUMBER, DATE CODE AND P/N BARCODE PLACED ON BAG 3. SEE DRAWING HPSFMISTD FOR HOLE PATTERNS 4. FOR FIELD INSTALLATION, SEE INSTRUCTION SHEET 2 OF 2 5. ALL DIMENSIONS ARE REFERENCE EXCEPT THOSE WITH A TOLERANCE ASSEMBLY P/N NO. OF CONTACT SF8382-2SG-5XX (2) #16 SF8382-3SG-5XX (3) #16 SF8382-4SG-5XX (4) #16 SF8382-5SG-5XX (5) #16 SF8382-6SG-5XX (6) #16 520 = BACKSHELL WITH Ø.220 [5.6] GROMMET I.D. 530 = BACKSHELL WITH Ø.330 [8.4] GROMMET I.D. .750 19.1 (2) #4x3/8 IN SELF TAPPING SCREWS MAT'L: STAINLESS STEEL CABLE STRAP MAT'L: NYLON, BLACK CUSTOMER PRINT .770 19.6 1.429 36.3 KEY 5 .375 9.5 .997 25.3 .99 25 .165 4.2 INSERT MAT'L: PBT, BLACK KEY 1 1 2.300 58.4 2 4 2 4 INSULATOR TUBE MAT'L: MYLAR 6 GROMMET MAT'L: RUBBER, BLACK 3 SF8382-6SG-5XX SHOWN WITHOUT HARDWARE 2.515 63.9 3 (X) #16 SOCKET CONTACTS, SOLDER MAT'L: GOLD PLATED COPPER ALLOY 6 FACE VIEW HOUSING ADAPTER MAT'L: NICKEL PLATED BRASS BACKSHELL MAT'L: NYLON, BLACK WASHER MAT'L: NYLON WIRE VIEW SF8382-XSG-5XX 5 SF8382-6SG-5XX SHOWN HOUSING MAT'L: NICKEL PLATED BRASS O-RING MAT'L: SILICONE, RED COPPER TAPE ASSEMBLED VIEW FOR CUSTOMER REFERENCE ONLY 3 1 4 1 PART NUMBER: 1 1 5 CUSTOMER APPROVAL 2 4 3 2 WIRE VIEW SF8382-2SG-5XX 2 3 2 WIRE VIEW SF8382-3SG-5XX DIMENSIONS IN BRACKETS [ ] ARE IN MILLIMETERS WIRE VIEW SF8382-4SG-5XX WIRE VIEW SF8382-5SG-5XX THIS DOCUMENT CONTAINS CONFIDENTIAL INFORMATION PROPRIETARY TO CONXALL CORPORATION. ANY REPRODUCTION, DISCLOSURE, OR USE OF THIS DOCUMENT /INFORMATION IS EXPRESSLY PROHIBITED UNLESS AUTHORIZED IN WRITING BY CONXALL CORPORATION. APPROVED BY: DATE: RoHS COMPLIANT MA A 01-29-19 RELEASED PER PDR 17011 PNK 12-20-18 O-RING 4290S REPLACES SF6290S-1. PNK 1-30-18 REV. INIT. DATE ALL INFORMATION ILLUSTRATED IS THE PROPERTY OF "CONXALL CORPORATION." UNAUTHORIZED DUPLICATION OR DISTRIBUTION OF THIS DOCUMENT IS PROHIBITED. ALL UNITS ARE IN FEET, INCHES, FRACTION OF INCHES AND DECIMALS. UNLESS OTHERWISE SPECIFIED TOLERANCES: 3 PLACE DECIMALS ±.005 ANGLES ±1° FRACTIONS ±1/16 = CRITICAL CHARACTERISTIC FLAG PER SPEC. XXXX DRAWING CREATED PER PDR17011 DESCRIPTION ORIG. DRAWN BY: DATE: 1-30-18 PNK CHECKED BY: 601 E. WILDWOOD VILLA PARK, IL 60181 TITLE: APPROVED BY: SCALE SIZE SHEET NTS B 1 OF 2 FILE: SF8382-XSG-5XX DIRECTORY: SLW CABLE-TO-CABLE ASSEMBLY (2-6) #16 SOCKET CONTACTS, SOLDER SHIELDED MINI-CON-X CUSTOMER: STANDARD PRODUCT PART NUMBER: SF8382-XSG-5XX REV A CABLE SHIELD CABLE CONDUCTORS HOUSING ADAPTER CABLE INSULATOR TUBE CABLE WIRING AND ASSEMBLY INSTRUCTIONS: STEP 1. SLIDE HOUSING ADAPTER, INSULATOR TUBE, AND BACKSHELL KIT, ONTO CABLE IN THE ORDER SHOWN. STEP 2. STRIP CABLE JACKET AND WIRES TO LENGTH. EXCESS CABLE SHIELD MUST BE TRIMMED OR WRAPPED AROUND WIRES. IF PRESENT, USE THE DRAIN WIRE TO WRAP THE CABLE SHIELD IN PLACE. INLINE CONNECTOR STEP 3. SOLDER WIRES TO CONTACTS. .125 3.2 DRAIN WIRE (IF PRESENT) .625 15.9 BACKSHELL KIT 1.125 28.6 CUSTOMER PRINT CONDUCTIVE TAPE WRAPPED ONTO INSULATOR TUBE STEP 4. THREAD HOUSING ADAPTER ONTO CONNECTOR AND TIGHTEN TO 5 LB-IN [0.56 N-m] MINIMUM TORQUE. STEP 5. PEEL-OFF THE BACKING OF THE CONDUCTIVE TAPE AND WRAP IT AROUND THE INSULATOR AS SHOWN. .080 2 CONDUCTIVE TAPE WRAPPED ONTO CABLE SHIELD PART NUMBER: SF8382-XSG-5XX STEP 6. SLIDE INSULATOR/CONDUCTIVE TAPE INTO THE BACK OF THE CONNECTOR. FORM FREE END OF CONDUCTIVE TAPE TIGHTLY ONTO THE SHIELD OF THE CABLE. STEP 7. SLIDE AND THREAD THE BACKSHELL KIT ONTO CONNECTOR. TIGHTEN TO 5 LB-IN [0.56 N-m] MINIMUM TORQUE. STEP 8. TIGHTEN THE TWO BACKSHELL SCREWS TO SECURE THE CABLE IN THE BACKSHELL. COMPLETED ASSEMBLY A MA 04-03-19 RELEASED PER PDR 17011 PNK 12-20-18 O-RING 4290S REPLACES SF6290S-1. PNK 1-30-18 REV. INIT. DATE ALL INFORMATION ILLUSTRATED IS THE PROPERTY OF "CONXALL CORPORATION." UNAUTHORIZED DUPLICATION OR DISTRIBUTION OF THIS DOCUMENT IS PROHIBITED. ALL UNITS ARE IN FEET, INCHES, FRACTION OF INCHES AND DECIMALS. UNLESS OTHERWISE SPECIFIED TOLERANCES: 3 PLACE DECIMALS ±.005 ANGLES ±1° FRACTIONS ±1/16 = CRITICAL CHARACTERISTIC FLAG PER SPEC. XXXX DRAWING CREATED PER PDR 17011 DESCRIPTION ORIG. DRAWN BY: DATE: 1-30-18 PNK CHECKED BY: 601 E. WILDWOOD VILLA PARK, IL 60181 TITLE: APPROVED BY: SCALE SIZE NTS B FILE: FILE NAME SHEET 2 OF 2 DIRECTORY: SLW CABLE-TO-CABLE ASSEMBLY (2-6) #16 SOCKET CONTACTS, SOLDER SHIELDED MINI-CON-X CUSTOMER: STANDARD PRODUCT PART NUMBER: SF8382-XSG-5XX REV A
SF8382-3SG-530 价格&库存
很抱歉,暂时无法提供与“SF8382-3SG-530”相匹配的价格&库存,您可以联系我们找货
