BC032-08-A-2-0200-0200-L-B
    GCT
    8POS 1.0MM PITCH PIN HEADER, TYP
BC032-08-A-2-0200-0200-L-B 数据手册
PRODUCT SPECIFICATION Part Number Product Description Doc Number   BC 1.00mm Series B Rev 1.00mm Board to Board Header Connectors BC Series Prepared By: Checked By: SA AE Date 22/03/10 Page 1 Approved By: DR 1.0 SCOPE This specifies 1.00mm pitch Header Connectors. The connector shall meet the performances, specified here under the condition with the plug connector and the receptacle connector mated. This specification covers the product standards, requirements, and qualification provisions. 2.0 APPLICABLE DOCUMENTS At the time of this specifications release, the latest revisions of the following documents were used. These documents shall form a part of this specification as described within this document. 2.1 Industry Specifications / Standards UL-94 Flammability ASTM B-103 Phosphor Bronze Plate or Brass, Rod, Sheet, Strip and Rolled Bar. 2.2 EIA Specifications EIA-364-D Electrical Connector / Socket Test Procedures Including Environmental Classifications. 3.0 REQUIREMENTS  3.1 Dimensional Connectors shall meet the physical dimensions specified on the applicable product drawing. 3.2 Material  Each component shall be constructed of the materials specified within this document. Substitute materials must meet the performance requirements of this specification. 3.2.1 Contacts Phosphor Bronze, or other equivalent copper alloys. 3.2.2 Housings LCP or flame retardant 94V-0 per UL-94; or other high performance resin. www.gct.co   PRODUCT SPECIFICATION Part Number Product Description Doc Number   BC 1.00mm Series B Rev 1.00mm Board to Board Header Connectors BC Series Prepared By: Checked By: SA AE Date 22/03/10 Page 2 Approved By: DR 3.3 Plating 3.3.1 Contact Under Plate and Finish Under Plate: Nickel 30-50µ” Finish: Gold Flash or Tin all over 3.4 Design 3.4.1 Mating The connector shall be capable of mating and unmating manually with the test board. 3.5 Mechanical Requirements 3.5.1 Workmanship The product shall be uniform in quality and free from defects (burrs, scratches, cracks, voids, etc.) that will adversely affect the product performance. 3.5.2 Contact Retention Force The end of a post shall be pushed in a perpendicular to base housing at a constant speed of 25.4 mm / minute. Min. Retention Force for 1.0N / Pin. 3.5.3 Durability When measured in accordance with EIA-364-09C, the following details shall apply: 100 mating cycles at a rate of 25.4 mm / minute, contact resistance 30 mΩ Max. www.gct.co   PRODUCT SPECIFICATION Part Number Product Description Doc Number   BC 1.00mm Series B Rev 1.00mm Board to Board Header Connectors BC Series Prepared By: Checked By: SA AE Date 22/03/10 Page 3 Approved By: DR 3.6 Electrical Requirements  3.6.1 Current Rating 1.0A, When measured in accordance with EIA-364-70, 1.0 A Max., based on a 30°C rise over ambient. 3.6.2 Voltage Rating 250V AC / DC. When measured in accordance with EIA-364-20B. 3.6.3 Low Level Circuit Resistance ≤20mΩ, measured in accordance with EIA-364-23B, Initial: ≤20 mΩ, after environmental test: ≤30mΩ. The following details shall apply: (a). Current: 100 mA Max. (b). Max. Open Circuit Voltage: 20 mV DC. 3.6.4 Dielectric Withstanding Voltage There shall be of no evidence of flashover when the mated plug and receptacle are tested in accordance with EIA-364-20B, The following details shall apply: (a). Voltage: 300V AC at 50 Hz. (b). Duration: 60 sec. (c). Measurement Points: Measure across a Min. of 10 adjacent and 10 opposing contacts. 3.6.5 Insulation Resistance Shall be a Min. of 1000 MΩ before conditioning and a Min. of 500 MΩ after conditioning. When measured in accordance with EIA-364-21C, the following details shall apply: (a). Voltage: 500 V DC / 1 Min. (b). Measurement Points: Measure between 10 adjacent and 10 opposing contacts per plug and receptacle. 3.6.6 Capacitance Measure the capacitance between adjacent unmated contacts. The capacitance shall not exceed a Max. of 2 pF at 1 KHz. www.gct.co   PRODUCT SPECIFICATION Part Number Product Description Doc Number   BC 1.00mm Series B Rev 1.00mm Board to Board Header Connectors BC Series Prepared By: Checked By: SA AE Date 22/03/10 Page 4 Approved By: DR 3.7 Environmental Requirements  3.7.1 Operating Temperature Range -40°C~105°C. 3.7.2 Temperature Life After exposure of the unmated connector to a high temperature operating environment, the contact resistance shall not exceed the value specified in paragraph 3.6.3. Test shall be in accordance with EIA-364-17B. The following details shall apply: (a). Test Condition: 105°C, 96hours. 3.7.3 Thermal shock test There shall be no evidence of physical damage when the mated module and socket are subjected to transient acceleration. During and after each shock, the test shall show no evidence of discontinuity greater than 1 microsecond. The test shall be in accordance with EIA-364-32C, Test Condition a, b: (a). Temperature: -40°C / 30 minutes to +105°C / 30 minutes, 5cycles. (b). Initial, After Test THERMAL: Max. Circuit Resistance: 30 mΩ or below. 3.7.4 Humidity Test After exposure of the plug and receptacle to a high humidity environment, the insulation resistance shall not be less than 500 MΩ. The dielectric withstanding voltage shall be greater than 300V AC for 1 minute. The test shall be in accordance with EIA-364-31B. (a). Test Condition: (40±2°C, 90-95% RH, 96 hrs). 3.7.5 Salt Spray After exposure, the contact resistance shall not exceed that specified (see paragraph 3.6.3). The insulation resistance shall not be less than 500 MΩ (see paragraph 3.6.5). The dielectric withstanding voltage shall be greater than 300V AC for 1 minute (see paragraph 3.6.4). The test shall be in accordance with EIA-364-26B, The following details shall apply: (a). Gold, Test Condition: 35±2°C, 16 hrs, 5% NaCL. (b) Gold/Tin, Tin, Test Condition: 35±2°C, 8 hrs, 5% NaCL. (c). Special Handling: The mated sockets shall be mildly rinsed in water to remove salt residue and allowed to dry for 24 hours at room temperature before measurements are to be taken. www.gct.co   PRODUCT SPECIFICATION Part Number Product Description Doc Number   BC 1.00mm Series B Rev 1.00mm Board to Board Header Connectors BC Series Prepared By: Checked By: SA AE Date 22/03/10 Page 5 Approved By: DR 3.7.6 Resistance to Soldering Heat There shall be no evidence of physical damage to the insulator or finished product when the unmated socket is subjected to the reflow soldering process. The following details shall apply: (a). Test Condition: Test connector shall be placed on the PCB, (b). Pre-Heat Temperature: 100~150°C for 60 seconds Max. (c). Temperature: Min. 210°C for 30 seconds Max. (d). Peak Temperature: 260±5°C, 10±5sec. 3.7.7 Solderability Test After exposure, the contact solder tails shall have a minimum of 95% solder coverage. The covered area must not show any evidence of voids or pinholes. The test shall be in accordance with EIA-364-71B. The contact solder tails must have solder coverage of 95% up and the plastics have no damage. The following details shall apply: (a). Solder Dwell Time: Contacts shall be held above the solder for 3 to 5 seconds before being immersed in the solder. (b). Test Temperature: 245±3°C, 3~5sec.         www.gct.co   PRODUCT SPECIFICATION Part Number Product Description Doc Number   BC 1.00mm Series B Rev 1.00mm Board to Board Header Connectors BC Series Prepared By: Checked By: SA AE Date 22/03/10 Page 6 Approved By: 4.0 QUALITY ASSURANCE PROVISIONS 4.1 Inspection Conditions   Unless otherwise specified, all inspections shall be performed under the following ambient conditions. (a). Temperature: 25±5°C. (b). Relative Humidity: 30% to 70%. (c). Barometric Pressure: Local Ambient. 4.2 Qualification Inspection  Qualification inspections shall be performed on sample units produced with production equipment. 4.2.1 Sample Selection Connectors shall be prepared according to applicable instruction sheets. Samples shall be selected at random from current production. A total of 26 samples are required for the specified test sequence. 4.2.2 Test Sequence The sample connectors shall be subjected to the inspections specified in the order shown.   Test Item A B C D E F G H Sample Size 3 3 3 3 3 3 3 3 Examination of Product 1,5 1,5 1,9 1,7 1,9 1,3 1,3 1,3 Terminal Resistance 2,4 2,4 2,8 2,8 Insulation Resistance 3,7 2,5 Dielectric Withstanding Voltage 4,6 3,6 Temperature Life 3 Humidity Test Thermal Shock 4 3 Solderability 2 Resistance to Soldering Heat 2 Insertion Force 3,6 Unmating Force 4,7 Contact Resistance Force 2 Durability Salt Spray 5 5 www.gct.co   DR PRODUCT SPECIFICATION Part Number Product Description Doc Number   BC 1.00mm Series B Rev 1.00mm Board to Board Header Connectors Prepared By: BC Series Checked By: SA AE Date 22/03/10 Page 7 Approved By: Revision details :Revision Information Page Release Date A Specification released. - 22/03/10 B Clarified Underplating Information. 2 16/08/13   www.gct.co   DR
物料型号:BC1.00mm Series
器件简介:这是1.00mm间距的板对板连接器,用于实现电路板之间的连接。
引脚分配:文档中未明确提供引脚分配的具体信息,但通常这类连接器会根据其物理尺寸和设计来确定引脚数量。
参数特性: - 物理尺寸:符合适用的产品图纸。 - 材料:接触件使用磷青铜或其他等效铜合金;外壳使用LCP或UL-94标准的94V-0阻燃材料。 - 镀层:接触件下镀镍30-50微米,表面镀金闪镀或全锡。
功能详解: - 插拔能力:连接器能够手动插拔。 - 机械要求:产品应无缺陷,如毛刺、划痕、裂纹等。 - 电气要求:包括电流额定值1.0A,电压额定值250V AC/DC,低电平电路电阻等。
应用信息:适用于需要板对板连接的应用,如电子设备内部的电路板连接。
封装信息:文档中未提供封装的详细信息,但通常这类连接器会有特定的封装设计以适应不同的应用需求。
环境要求:包括工作温度范围-40°C至105°C,以及经过温度寿命、热冲击、湿度测试、盐雾测试和耐焊接热测试等环境测试。
质量保证:包括检查条件、合格检查和样品选择等质量保证措施。
BC032-08-A-2-0200-0200-L-B 价格&库存
很抱歉,暂时无法提供与“BC032-08-A-2-0200-0200-L-B”相匹配的价格&库存,您可以联系我们找货
