2mm Pitch Connector for Discrete Wire Connection(Product approved by UL CSA Standard)
Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
DF3 Series
■Features
1. Correspond to Board Design in Wide Variation
●Crimp Socket
(1) Low profile design with mounting height 7.5mm.
(2) Provide the contact crimping area with the sufficient space, and secures the stable crimping
operation.
●Receptacle
(1) The board can be connected horizontally or vertically in combination with the straight header with the
right angle header.
(2) For horizontal connection, the board to board size is the low profile of 6.6mm.
(3) Compatibility with the in-line plug allows the receptacle to set the board side to the receptacle and
the cable side to the plug in the board to cable connection.
●Pin Header
(1) The board pre-fixed kink is treated with the post pin.
(2) The style employs a scoop-proof and sturborn box type.
(3) The type corresponding to SMT is avilable, using the heat-proof resin.
This SMT header is equipped with the metal tab to prevent peeling in the solder joint area.
●In-line Plug
(1) The crimping in-line plug consits of two types, one type, which has pursued after space merits, and
the other employs the panel lock type, which can be fixed to the panel.
(2) The in-line adapter is available to insert and in-line the ID socket from both sides.
2. UL, CSA Certified
■Applications
Business equipment such as copy machine and printer
B207
DF3 Series●2mm Pitch Connector for Discrete Wire Connection(Product approved by UL CSA Standard)
■Product Specifications
Current rating
Rating
Crimping
Note 1
Voltage rating
Crimping
Wire size
22 to 24 AWG : 3A
Operating Temperature Range -55ç to +105ç (Note 2)
26 AWG
: 2A
Operating Humidity Range
28 AWG
: 1A
Storage Temperature Range -10ç to +60ç (Note 4)
■UL CSA Safety Standard File No.
UL
: E52653
CSA
: LR95109
24 AWG : 3A
Rated Current
26 AWG : 2A (Note 5)
Wire size
28 AWG : 1A
Rated Voltage
30V AC
Item
Specification
Condition
1. Insulation Resistance
1000Mø min.
500V DC
2. Withstanding voltage
No flashover or insulation breakdown.
650V AC, 1 minute
3. Contact Resistance
30mø max
100mA
4. Single Insertor/Extraction Force 0.3N(30gf)min, 4.4N(450gf)max.
5. Vibration
Measure by the square steel pin with 0.5±0.002mm
No electrical discontinuity of 1μs or more
Frequency : 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions.
6. Humidity (Steady state) Contact resistance : 30mø max. Insulation resistance : 500Mø min.
7. Temperature Cycle
96 hours at temperature of 40ç and humidity of 90% to 95%
Contact resistance : 30mø max. Insulation resistance :1000Mø min. (-55ç : 30 minutes 5 to 35ç: 10 minutes 85ç: 30 minutes 5 to 35ç: 10minutes) 5 cycles
8. Durability (Mating/un-mating) Contact resistance : 30mø max.
Tin plating : 30 cycles Gold plating: 50 cycles
9. Resistance to Soldering Heat No deformation of components affecting performance.
THT type Flow : 260ç for 10 seconds
Manual soldering : 300ç for 2 seconds
SMT type Reflow : At the recommended temperature profile Manual soldering : 300ç for 3 seconds
Note 1 : Current rating of header is 3A.
Note 2 : Includes temperature rise caused by current flow.
Apply to crimping contact type. Maximum operating temperature of receptacle type is 85ç.
Note 3 : Please use under conditions with no condensation occurred.
Note 4 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and
Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation.
Note 5 : Apply to crimping contact type.
■Materials / Finish
Product
Part
Material
Finish
Remarks
Crimping Socket
Insulator
Polyamide
Black
UL94V-0
IDC Contact for Socket
Receptacle
Pin Header
SMT Pin Header
Contact
Phosphor bronze
Tin plated or gold plated
Insulator
Polyamide
Black
UL94V-0
Contact
Phosphor bronze
Insulator
Polyamide
Black
UL94V-0
Contact
Brass
Insulator
Polyamide
Beige
UL94V-0
Contact
Brass
Metal tab
Brass
Tin plated
In-line Plug
Insulator
Polyamide
Black
UL94V-0
In-line IDC Contact
Contact
Phosphor bronze
Insulator
Polyamide
Black
UL94V-0
Contact
Brass
Tin plated
In-line Adapter
B208
40% to 70% (Note 4)
Storage Humidity Range
250V AC
UL-CSA Safety Standard and Approved specification
Rating
40% to 80% (Note 3)
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Connector
DF3 - * S - 2C
q
q Series Name
w
e
: DF3, 3A, 3AA, 3EA
rt
t Connection Form/Contact Style
w Number of Contacts : 2~15
C
e Connector Type
: Crimp socket
DSA : Straight through hole
S
: Socket
DS : Right angle through hole
P
: Pin Header
V
: Straight SMT
EP
: In-line Plug
H
: Right angle SMT
: 2mm
A
: Adapter
r Contact Pitch
●Contact
DF3 - EP2428PCFA
q
q Contact Type
w
r
e
e Contact Type/Packaging Type
Blank : For socket
SCF
: Socket contact, Reel
EP
SC
: Socket contact, Pack
PCF
: Plug contact, Reel
PC
: Plug contact, Pack
: For in-line plug
w Applicable Wire Size
22
: 22 AWG
2428 : 24 to 28 AWG
r Plating Type
Blank
: Tin plated
A
: Gold plated (Plug contact)
C
: Gold plated (Socket contact)
■Application pattern
DF3-※S-2C
DF3(A)-※P-2DS(**)
DF3EA-πP-2H(**)
DF3AA-※EP-2C
Panel
DF3-※S-2C
DF3EA-πP-2V(**)
DF3(A)-※P-2DSA(**)
DF3-※S-2DSA(**)
DF3(A)-※P-2DS(**)
DF3EA-πP-2H(**)
DF3AA-※EP-2C
Panel
DF3EA-πP-2V(**)
DF3(A)-※P-2DSA(**)
B209
■Crimping Socket
[Specific No.] (* *), * *
Blank : 100pcs/pack
This picture shows the Contact
crimped status.
Unit : mm
No. of
Contacts
A
B
No. of
Contacts
A
B
DF3-2S-2C(**) 543-0003-8 **
2
06
02
DF3-19S-2C(**) 543-0010-3 **
09
DF3-3S-2C(**) 543-0004-0 **
3
08
DF3-4S-2C(**) 543-0005-3 **
4
10
04
DF3-10S-2C(**) 543-0011-6 **
10
22
18
06
DF3-11S-2C(**) 543-0012-9 **
11
24
DF3-5S-2C(**) 543-0006-6 **
5
12
08
DF3-6S-2C(**) 543-0007-9 **
6
14
10
DF3-12S-2C(**) 543-0013-1 **
12
26
22
DF3-13S-2C(**) 543-0014-4 **
13
28
24
DF3-7S-2C(**) 543-0008-1 **
7
16
12
DF3-14S-2C(**) 543-0015-7 **
14
30
26
8
18
14
DF3-8S-2C(**) 543-0009-4 **
DF3-15S-2C(**) 543-0016-0 **
Note1 : The product's contact number indicated.
Note2 : The quantity for delivery of the specification No. "None" is determined per bag (100 pcs.).
If needed, please order the products per bag.
15
32
28
Part No.
HRS No.
RoHS
YES
Part No.
HRS No.
RoHS
YES
■Receptacle
(25) : Tin plated, Tube packaging
(55) : Gold plated, Tube packaging
●Board Through-hole Diameter : Ø0.8++0.1
Unit: mm
Part No.
B210
HRS No.
No. of
Contacts
A
B
Tube Package
RoHS
Quantity
Part No.
HRS No.
No. of
Contacts
A
B
Tube Package
RoHS
Quantity
DF3-2S-2DSA(**) 543-0048-6 **
2
06 02 80 pieces
DF3- 9S-2DSA(**) 543-0055-1 **
09
20 16 24 pieces
DF3-3S-2DSA(**) 543-0049-9 **
3
08 04 60
DF3-10S-2DSA(**) 543-0056-4 **
10
22 18 21
DF3-11S-2DSA(**) 543-0057-7 **
11
24 20 20
DF3-12S-2DSA(**) 543-0058-0 **
12
26 22 18
DF3-4S-2DSA(**) 543-0050-8 **
4
10 06 48
DF3-5S-2DSA(**) 543-0051-0 **
5
12 08 40
DF3-6S-2DSA(**) 543-0052-3 **
6
14 10 34
DF3-13S-2DSA(**) 543-0059-2 **
13
28 24 17
DF3-7S-2DSA(**) 543-0053-6 **
7
16 12 30
DF3-14S-2DSA(**) 543-0060-1 **
14
30 26 16
8
18 14 27
DF3-15S-2DSA(**) 543-0061-4 **
DF3-8S-2DSA(**) 543-0054-9 **
Note2 : Please order the tube packaging at the multiplied tube packaging quantity (pieces).
15
32 28 15
YES
YES
■Straight Pin Header
●Board Through-hole Diameter: Ø0.8++0.1
●Kink Pre-fixed Effective Diameter: Ø0.8++0.05
Unit : mm
Tin Plating
Gold Plating
Part No.
HRS No.
Part No.
HRS No.
543-0165-0
543-0017-2 01
DF3A- 2P-2DSA
DF3- 2P-2DSA(01)
543-0166-2
543-0018-5 01
DF3A- 3P-2DSA
DF3- 3P-2DSA(01)
543-0167-5
543-0019-8 01
DF3A- 4P-2DSA
DF3- 4P-2DSA(01)
543-0168-8
543-0020-7 01
DF3A- 5P-2DSA
DF3- 5P-2DSA(01)
543-0169-0
543-0021-0 01
DF3A- 6P-2DSA
DF3- 6P-2DSA(01)
543-0170-0
543-0022-2 01
DF3A- 7P-2DSA
DF3- 7P-2DSA(01)
543-0171-2
543-0023-5 01
DF3A- 8P-2DSA
DF3- 8P-2DSA(01)
543-0172-5
543-0024-8 01
DF3A- 9P-2DSA
DF3- 9P-2DSA(01)
543-0173-8
543-0025-0 01
DF3A-10P-2DSA
DF3-10P-2DSA(01)
543-0174-0
543-0026-3 01
DF3A-11P-2DSA
DF3-11P-2DSA(01)
543-0175-3
543-0027-6 01
DF3A-12P-2DSA
DF3-12P-2DSA(01)
543-0176-6
543-0028-9 01
DF3A-13P-2DSA
DF3-13P-2DSA(01)
543-0177-9
543-0029-1 01
DF3A-14P-2DSA
DF3-14P-2DSA(01)
543-0178-1
543-0030-0 01
DF3A-15P-2DSA
DF3-15P-2DSA(01)
Note : The quantity for delivery is determined per bag (100 pcs.). If needed, please order the products per bag.
No. of
Contacts
2
3
4
5
6
7
8
9
10
11
12
13
14
15
A
B RoHS
06
08
10
12
14
16
18
24
26
28
30
32
02
04
06
08
10
12
14
YES
16
18
24
26
28
■Right Angle Pin Header
Unit : mm
Tin Plating
Gold Plating
Part No.
HRS No.
Part No.
HRS No.
543-0179-4
543-0031-3 01
DF3A- 2P-2DS
DF3- 2P-2DS(01)
543-0180-3
543-0032-6 01
DF3A- 3P-2DS
DF3 -3P-2DS(01)
543-0181-6
543-0033-9 01
DF3A- 4P-2DS
DF3- 4P-2DS(01)
543-0182-9
543-0034-1 01
DF3A- 5P-2DS
DF3- 5P-2DS(01)
543-0183-1
543-0035-4 01
DF3A- 6P-2DS
DF3- 6P-2DS(01)
543-0184-4
543-0036-7 01
DF3A- 7P-2DS
DF3- 7P-2DS(01)
543-0185-7
543-0037-0 01
DF3A- 8P-2DS
DF3- 8P-2DS(01)
543-0186-0
543-0038-2 01
DF3A- 9P-2DS
DF3- 9P-2DS(01)
543-0187-2
543-0039-5 01
DF3A-10P-2DS
DF3-10P-2DS(01)
543-0188-5
543-0040-4 01
DF3A-11P-2DS
DF3-11P-2DS(01)
543-0189-8
543-0041-7 01
DF3A-12P-2DS
DF3-12P-2DS(01)
543-0190-7
543-0042-0 01
DF3A-13P-2DS
DF3-13P-2DS(01)
543-0191-0
543-0043-2 01
DF3A-14P-2DS
DF3-14P-2DS(01)
543-0192-2
543-0044-5 01
DF3A-15P-2DS
DF3-15P-2DS(01)
Note : The quantity for delivery is determined per bag(100pcs.). If needed, please order the products per bag.
No. of
Contacts
2
3
4
5
6
7
8
9
10
11
12
13
14
15
A
B RoHS
06
08
10
12
14
16
18
24
26
28
30
32
02
04
06
08
10
12
14
YES
16
18
24
26
28
B211
■Straight Pin Header (SMT)
1.575
A
5.6
4.2
P=2
2.2
2
Number of Contacts
5.9
B
BPCB mounting pattern
1.5
(0.7)
HRS marking
Configuration of 2 to 6 position
Cavity No.
C
HRS marking
Cavity No.
Note :
If a pattern is included in the shaded area and is not treated with resist,
it could touch the connector contact.
(21) : Tin plated packaging
(51) : Gold plated packaging
Unit : mm
Part No.
HRS No.
No. of Contacts
A
DF3EA-2P-2V(**)
543-0315-0 **
2
02
08.5 08.74
DF3EA-3P-2V(**)
543-0316-0 **
3
04
10.5 10.74
DF3EA-4P-2V(**)
543-0317-0 **
4
06
12.5 12.74
DF3EA-5P-2V(**)
543-0318-0 **
5
08
14.5 14.74
DF3EA-6P-2V(**)
543-0319-0 **
6
10
16.5 16.74
DF3EA-7P-2V(**)
543-0320-0 **
7
12
18.5 18.74
DF3EA-8P-2V(**)
543-0321-0 **
8
14
20.5 20.74
DF3EA-9P-2V(**)
543-0322-0 **
9
16
22.5 22.74
DF3EA-10P-2V(**)
543-0323-0 **
10
18
24.5 24.74
DF3EA-11P-2V(**)
543-0324-0 **
11
DF3EA-12P-2V(**)
543-0325-0 **
12
22
28.5 28.74
DF3EA-13P-2V(**)
543-0326-0 **
13
24
30.5 30.74
DF3EA-14P-2V(**)
543-0327-0 **
14
26
32.5 32.74
543-0328-0 **
B
C
RoHS
YES
15
DF3EA-15P-2V(**)
28 34.5 34.74
Note1 : Please order the emboss packaging product by the reel number. (1 reel : 1000pcs.)
B212
■Right Angle Pin Header (SMT)
A
5.6
4.2
P=2
Number of Contacts
B
2.5
5.9
2.2
1
1
(0.7)
Cavity No.
Cavity No.
1.5
HRS marking
HRS marking
(21) : Tin plated embossed packaging
(51) : Gold plated embossded packaging
Unit : mm
Part No.
HRS No.
No. of Contacts
A
DF3EA-2P-2H(**)
543-0329-0 **
2
02
08.5 08.74
DF3EA-3P-2H(**)
543-0330-0 **
3
04
10.5 10.74
DF3EA-4P-2H(**)
543-0331-0 **
4
06
12.5 12.74
DF3EA-5P-2H(**)
543-0332-0 **
5
08
14.5 14.74
DF3EA-6P-2H(**)
543-0333-0 **
6
10
16.5 16.74
DF3EA-7P-2H(**)
543-0334-0 **
7
12
18.5 18.74
DF3EA-8P-2H(**)
543-0335-0 **
8
14
20.5 20.74
DF3EA-9P-2H(**)
543-0336-0 **
9
16
22.5 22.74
DF3EA-10P-2H(**)
543-0337-0 **
10
18
24.5 24.74
DF3EA-11P-2H(**)
543-0338-0 **
11
DF3EA-12P-2H(**)
543-0339-0 **
12
22
28.5 28.74
DF3EA-13P-2H(**)
543-0340-0 **
13
24
30.5 30.74
DF3EA-14P-2H(**)
543-0341-0 **
14
26
32.5 32.74
B
C
RoHS
YES
28 34.5 34.74
15
DF3EA-15P-2H(**)
543-0342-0 **
Note1 : Please order the emboss packaging product by the reel number. (1reel : 1000pcs.)
B213
■In-line Plug
Photo: Contact inserted status
B214
Part No.
HRS No. No. of Contacts
543-0064-2
2
DF3- 2EP-2C
3
543-0065-5
DF3- 3EP-2C
4
543-0066-8
DF3- 4EP-2C
5
543-0067-0
DF3- 5EP-2C
6
543-0068-3
DF3- 6EP-2C
7
543-0069-6
DF3- 7EP-2C
8
543-0070-5
DF3- 8EP-2C
Note : The specific No."None" item is delivered
A
B
RoHS
Part No.
543-0071-8
02
06
09
DF3- 9EP-2C
04
08
10
543-0072-0
DF3-10EP-2C
06
10
11
543-0073-3
DF3-11EP-2C
YES
08
12
12
543-0074-6
DF3-12EP-2C
10
14
13
543-0075-9
DF3-13EP-2C
12
16
14
543-0076-1
DF3-14EP-2C
14
18
15
543-0077-4
DF3-15EP-2C
per bag (100pcs.). Please order products per bag unit.
■In-line Plug with Panel Lock
A
24
26
28
30
32
B
16
18
24
26
28
Unit : mm
RoHS
YES
BPanel Cutouts
Photo: Contact insertion status
Part No.
DF3AA- 2EP-2C
DF3AA- 3EP-2C
DF3AA- 4EP-2C
DF3AA- 5EP-2C
DF3AA- 6EP-2C
DF3AA- 7EP-2C
DF3AA- 8EP-2C
DF3AA- 9EP-2C
DF3AA-10EP-2C
DF3AA-11EP-2C
DF3AA-12EP-2C
DF3AA-13EP-2C
DF3AA-14EP-2C
DF3AA-15EP-2C
Note : The specific
No. of Contacts
HRS No.
2
543-0151-5
3
543-0152-8
543-0153-0
4
5
543-0154-3
6
543-0155-6
7
543-0156-9
8
543-0157-1
9
543-0158-4
10
543-0159-7
543-0160-6
11
12
543-0161-9
13
543-0162-1
14
543-0163-4
15
543-0164-7
No. "None" item is delivered
Unit : mm
A
B
C
D
E RoHS
9.4 6.3
02
06
11
Note1 : Applicable panel thickness is
1.6 to 1.0mm. (However, a
04 11.4 8.3
08
13
slight backlash is considered
06 13.4 10.3
10
15
for the thickness other than 1.6
08 15.4 12.3
12
17
and 1.2mm.)
10 17.4 14.3
14
19
Note2 : Use the non-radius surface at
12 19.4 16.3
16
21
the hooking panel edge.
14 21.4 18.3
18
23
YES
Note3
Contact No. indicates 1, 4, 8,
16 23.4 20.3
12, and 15.
18 25.4 22.3
22
27
20 27.4 24.3
24
29
22 29.4 26.3
26
31
24 31.4 28.3
28
33
26 33.4 30.3
30
35
28 35.4 32.3
32
37
■In-line Adapter with Panel Lock
BPanel Cutouts
Adapter to in-line by pushing 2pcs. of
No.1-No.1 connection circuit type
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
C
D
E
DF3- 2EP-2A
543-0267-0
2
11
06
02
9.4
6.3
DF3- 3EP-2A
543-0268-2
3
13
08
04
11.4
8.3
DF3- 4EP-2A
543-0269-5
4
15
10
06
13.4 10.3
DF3- 5EP-2A
543-0270-4
5
17
12
08
15.4 12.3
DF3- 6EP-2A
543-0271-7
6
19
14
10
17.4 14.3
DF3- 7EP-2A
543-0272-0
7
21
16
12
19.4 16.3
DF3- 8EP-2A
543-0273-2
8
23
18
14
21.4 18.3
DF3- 9EP-2A
543-0274-5
9
25
23.4 20.3
DF3-10EP-2A
543-0275-8
10
27
22
18
25.4 22.3
DF3-11EP-2A
543-0276-0
11
29
24
DF3-12EP-2A
543-0277-3
12
31
26
22
29.4 26.3
DF3-13EP-2A
543-0278-6
13
33
28
24
31.4 28.3
DF3-14EP-2A
543-0279-9
14
35
30
26
33.4 30.3
DF3-15EP-2A
543-0280-8
15
37
32
28
35.4 32.3
RoHS
Note1 : Applicable panel thickness is 1.6
to 1.0mm.(However,backlash
will occur except for 1.6, 1.2mm
thickness.)
Note2 : Please use the non-radius surface
at the hooking panel edge.
YES
Note : The specific No. "None" item is delivered per bag (100pcs.). Please order products per bag unit.
B215
■Crimping Contact for Socket
Applicable Cable
Packaging Finish RoHS
ULstyle Jacket Diameter Wire Size Stranded Wire Conductor
543-0235-3 1061
22 AWG
DF3-22SCF
1.2-1.5
17/0.16
10,000/reel
Tin plated
543-0236-6 1061
22 AWG
DF3-22SC
1.3
17/0.16
100/pack
22 AWG
DF3-22SCFC 543-0861-0 1061
1.2-1.5
17/0.16
10,000/reel
Gold plated
543-0862-3 1061
22 AWG
DF3-22SCC
1.3
17/0.16
100/pack
24 AWG
11/0.16
1007
7/0.16
DF3-2428SCF 543-0001-2
0.75 to 1.5 26 AWG
10,000/reel
1061
28 AWG
7/0.127
Tin plated
24 AWG
11/0.16
1.5
YES
26 AWG
7/0.16
DF3-2428SC 543-0002-5 1007
1.3
100/pack
28 AWG
7/0.127
1.2
24 AWG
11/0.16
1007
7/0.16
DF3-2428SCFC 543-0046-0
0.75 to 1.5 26 AWG
10,000/reel
1061
28 AWG
7/0.127
Gold plated
24 AWG
11/0.16
1.5
26 AWG
7/0.16
1.3
DF3-2428SCC 543-0047-3 1007
100/pack
28 AWG
7/0.127
1.2
Note1 : Crimping contact Extraction Tool DF-C-PO(A)
Note2 : Applicable wire with tin plated solid soft conductor.
Note3 : When using other than the recommended wire, contact your nearest Hirose
representative.
Part No.
HRS No.
■Crimping Contact for In-line Plug
Applicable Cable
24 AWG
11/0.16
1007
7/0.16
DF3-EP2428PCF 543-0062-7
0.75 to 1.5 26 AWG
10,000/reel
1061
28 AWG
7/0.127
Tin plated
24 AWG
11/0.16
1.5
26 AWG
7/0.16
DF3-EP2428PC 543-0063-0 1007
1.3
100/pack
28 AWG
7/0.127
1.2
YES
24 AWG
11/0.16
1007
7/0.16
0.75 to 1.5 26 AWG
DF3-EP2428PCFA 543-0149-3
10,000/reel
1061
28 AWG
7/0.127
Gold plated
24 AWG
11/0.16
1.5
26 AWG
7/0.16
1.3
DF3-EP2428PCA 543-0150-2 1007
100/pack
28 AWG
7/0.127
1.2
Note1 : Crimping contact Extraction Tool DF-C-PO(B)
representative.
Part No.
HRS No.
BApplicable Crimping Tool
Type
Applicator
Press Unit
Hand Crimping Tool
Extraction Tool
Part No.
HRS No.
Applicable Contact
AP105-DF3-2428S
901-4503-3
DF3-2428SCF/SCFC
AP105-DF3-22S
901-4549-4
DF3-22SCF/SCFC
AP105-DF3-EP2428P
901-4508-7
DF3-EP2428PCF/PCFA
CM-105C
901-0001-0
DF3-TA2428HC
550-0164-5
DF3-2428SC/SCC
DF3EP-TA2428HC
550-0184-2
DF3-EP2428PC/PCA
DF3-TA22HC
550-0257-4
DF3-22SC/SCFC
DF-C-PO (A)
550-0170-8
DF3-****SC(F)(C)
DF3-EP****PC(F)(A)
Note1 : If any trouble has occurred due to tools other than designated tool, Hirose bears no respoisibility for any trouble.
Note2 : Please follow the "Crimping quality standards" and "Table of crimping condition" when crimping contacts.
B216
■ Crimped contacts with cable assemblies
DF3-2428S 2 - 24 A 9 - 300
1
1
2
3
Part No.
DF3-2428SF:DF3-2428SCF
Wire Type
2:UL1007
Applicable wire size
24:24 AWG
Part No.
DF3-2428S2-24A9-300(05)
2
4
3
4
5
Crimped condition / Terminal treatment
A:Both-end crimped
B:Single-end crimped / Without terminal treatment
S:Single-end crimped / With terminal treatment
Terminal treatment : Stripped jacket
HRS No.
Packaging
Finish
543-9001-0 05
100pcs/pack
Tin plated
6
5
6
Wire color
9:White
0:Black
Wire length
300:300mm
Note1 : Bag packaging (100pcs/pack). Order by number of packs.
Note2 : Please contact our sales representative when using the other specifications.
B217
BEmbossed Carrier Tape Dimensions
●Straight Pin Header
E
1.5±0.3
0.4±0.1
C±0.1
φ
13
2±0.5
.8
A±0.3
B±0.1
φ21±0
D +20
0.2
1.7 +0.05
(D+6) MAX
E
.75
R0
Unreeling direction
1.5 +0.1
Unit : mm
Product Type
Size
DF3EA-*P-2V(**)
No. of Contacts
A
B
C
D
2 to 4
24.0
11.5
24.4
5 to 7
32.0
28.4
14.2
32.4
8 to 10
44.0
40.4
20.2
44.4
11 to 15
56.0
52.4
26.2
56.4
●Right Angle Pin Header
4±0.1
1
0.
+ 0
E
5
1.
Ø
2±0.5
E–E
B±0.1
A±0.3
Ø13±0.2
Ø80
C±0.1
Carrier hole
(Ø1.5 +0.1
0 ) far side
Ø370±2
12±0.1
1.75±0.1
2±0.1
.75
R0
E
Unreeling direction
D +20
0.2
Carrier hole
(Ø1.5 +0.1
0 ) far side
(φ80 )
1
0.
+ 0
5
12±0.1
φ370±2
1.
4±0.1
6.4±0.3
0.2
φ
2 ±0.1
1.75 ±0.1
E-E
0.4±0.1
(D+6)MAX
6.1±0.3 1.6±0.3
Unit : mm
Product Type
DF3EA-*P-2H(**)
B218
Size
No. of Contacts
A
B
C
D
2 to 4
24.0
11.5
24.4
5 to 7
32.0
28.4
14.2
32.4
8 to 10
44.0
40.4
20.2
44.4
11 to 15
56.0
52.4
26.2
56.4
BPrecautions
1. Recommended Temperature Profile (SMT)
10secMAX
MAX 250℃
250
TEMPERATURE
230℃
200
180℃
150
100
TIME (sec)
90 – 120sec
PRE-HEATING TIME
60secMAX
SOLDERING TIME
[Applicable Conditions]
1.Peak temperature : a maximum of 250ç for no more than 10 seconds
2.Heating unit : no less than 230ç for no more than 60 seconds
3.Preheating unit : 150 to 180ç for 90 to 120 seconds
4.Number of times : no more than 2 times
* Measurement is conducted at the contact lead part
As it may change depending on the conditions such as solder paste types,
manufacturers, PCB size, and other soldering materials, please fully check
the mounting conditions before use.
(Note 1) This temperature profile is a recommended value.
2. Recommended Manual Soldering Condition (SMT) Soldering iron temperature : 290±10ç, Soldering time: Within 3 seconds
3. Recommended Screen Thickness (SMT) 0.15 to 0.2mm
4. Board Warpage (SMT)
5. Recommended Soldering Condition (DIP)
6. Cleaning Condition
Based on both connector edges, 0.03mm max. in the connector center portion
■Flow Condition with Automatic Soldering Tool. Soldering temperature : 250±5ç, Soldering time : Within 10 seconds
■Manual Soldering Condition. Soldering iron temperature : 290±10ç, Soldering time : Within 2 seconds
Refer to the "Wire-to-Board Connector Use Hand book".
IPA cleaning is allowed. (Cleaning is not recommended because cleaning may change the
push/pull feeling etc. Please contact us when you use other cleaning agents. )
7. Connection Condition
8. Precations
B219
MEMO:
B220
