PR20C03VBDN
PR20C03VBDN
    METZCONNECT
    插件,P=2mm
    排针 间距:2mm 2x3P 插件
PR20C03VBDN 数据手册
Page 1/4 Data sheet P/N PR20CXXVBDN xx=number of poles PR20CxxVBDN 2021/09/15 Version: R Illustrations Dimensional drawing Drill pattern See enlarged drawings at the end of document Product specification • pin header, THR solderable • centerline 2.00 mm, direction of connection vertical 0° • color black • Tape & Reel packaging possible • dual rows Data sheet Page 2/4 PR20CxxVBDN P/N PR20CXXVBDN xx=number of poles 2021/09/15 Version: R Technical Data General Data min. number of poles max. number of poles 2 clearance/creepage dist. 1.5 mm Protection category IP00 Rated current 1A 40 Material insulating material PE-HT contact pin material CuZnPb contact pin surface Ni + Au Flash Glow-Wire Flammability GWFI - Glow-Wire Flammability GWIT - Climatic Data upper limit temperature 105 °C lower limit temperature -55 °C general Tolerance ISO 2768 -mH Solderability Acc. to IPC/JEDEC J-STD-020D-MSL 1 Data sheet PR20CxxVBDN Page 3/4 P/N PR20CXXVBDN xx=number of poles 2021/09/15 Version: R Illustrations Dimensional drawing L=(pole size - 1) x centerline + 2 mm [0.079] Data sheet PR20CxxVBDN Page 4/4 P/N PR20CXXVBDN xx=number of poles 2021/09/15 Version: R Illustrations Drill pattern Powered by TCPDF (www.tcpdf.org)
PR20C03VBDN 价格&库存
很抱歉,暂时无法提供与“PR20C03VBDN”相匹配的价格&库存,您可以联系我们找货
PR20C03VBDN
  • 1+1.322951+0.16556
  • 10+1.0935610+0.13685
  • 100+0.92724100+0.11604
  • 500+0.82757500+0.10356
  • 1000+0.787951000+0.09861
  • 5000+0.703255000+0.08801
  • 10000+0.6696710000+0.08381
库存:2951
PR20C03VBDN
  • 1+1.30515
  • 10+1.07735
  • 100+0.91361
  • 500+0.81513
  • 1000+0.77598
  • 5000+0.69292
  • 10000+0.65970
库存:891
