PHG.1B.308.CYMD52
PHG.1B.308.CYMD52
    LEMO(雷莫)
    CONN RCPT FMALE 8POS GOLD CRIMP
PHG.1B.308.CYMD52 数据手册
PHG.1B.308.CYMD52 www.lemo.com SUMMARY # Wires Low voltage 8 Image is for illustrative purpose only Series 1B Termination type Female crimp IP rating 50 AWG wire size 26.00 - 22.00 Cable Ø 4.30 - 5.20 mm Status active Matching parts FGG.1B.308.CYCD52 Download Request a quote Eplan Catalog TECHNICAL DETAILS Mechanics Shell Style/Model PH*: Free receptacle, cable collet Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 21.25 g Performance Configuration 1B.308 : 8 Low Voltage Insulator Y: PEEK for crimp contacts Rated Current 5 Amps Specifications Contact Type: Crimp Contact Retention: 22 N Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.8 mm (0.031in) Min. Conductor: 0.14 mm^2 (AWG 26) Max. Conductor: 0.34 mm^2 (AWG 22) R (max): 6.1 mOhm Vtest (contact-shell): 1300 V (AC), 1840 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Vtest (contact-contact): 1300 V (AC), 1840 V (DC) Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A L S1 S2 mm. 12.5 40.5 10 9 in. 0,49 1,59 0,39 0,35 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Crimp Tool: DPC.91.701.V Crimp settings: AWG/Selector = 22-24-26/6-5-5 Positionner: DCE.91.071.BVM Extractor: DCF.91.070.2LT Replacement contact: EGG.1B.655.ZZM Spanner wrench: DCD.1B.015.PA090 Cables 108240 PTFE White 108260 PTFE White 8280 PVC Black LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
PHG.1B.308.CYMD52
物料型号:PHG.1B.308.CYMD52
器件简介:LEMO生产的8针低压连接器,适用于电缆压接。
引脚分配:1B.308,8个低压引脚。
参数特性: - 额定电流:5安培 - 接触类型:压接 - 接触保持力:22牛顿 - 接触直径:0.7毫米 - 桶直径:0.8毫米 - 最小导体截面积:0.14平方毫米(AWG 26) - 最大导体截面积:0.34平方毫米(AWG 22) - 最大电阻:6.1毫欧姆 - 接触-壳体电压测试:1300伏交流,1840伏直流 - 接触-接触电压测试:1300伏交流,1840伏直流
功能详解: - 环境温度范围:-55°C至+250°C - 湿度:最高95%(在60°C/140°F时) - 振动:15g(10Hz至2000Hz) - 冲击抵抗力:100g(6ms) - 气候类别:50/175/21 - 屏蔽效能:最小75分贝(10MHz),最小40分贝(1GHz) - 盐雾腐蚀:超过1000小时
应用信息:适用于需要高可靠性和高性能的电子设备连接。
封装信息: - 外壳样式/型号:PH:自由插座,电缆套筒 - 键槽:1个键(alpha=0,插头:男性接触,插座:女性接触) - 外壳材料:黄铜(镀铬[SAE AMS 2460])外壳和套筒螺母,镍镀[SAE AMS QQ N 290]黄铜锁紧套和中间件 - 重量:21.25克
推荐工具和电缆: - 压接工具:DPC.91.701.V - 压接设置:AWG/选择器=22-24-26/6-5-5 - 定位器:DCE.91.071.BVM - 提取器:DCF.91.070.2LT - 替换接触:EGG.1B.655.ZZM - 扳手:DCD.1B.015.PA090 - 电缆:108240(PTFE,白色),108260(PTFE,白色),8280(PVC,黑色)
PHG.1B.308.CYMD52 价格&库存
很抱歉,暂时无法提供与“PHG.1B.308.CYMD52”相匹配的价格&库存,您可以联系我们找货
