HIF3H-10DB-2.54DS(71) 数据手册
2.54mm Pitch Board to Board Connector
HIF3H Series
■Features
1. Product Variation
Afford to connect the board to board horizontally or vertically.
2. Compatibility
Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Achieve combination with other HIF3H series.
■Applications
Computers, termination equipment, various kinds of electronic equipment, Office Automation machines and so on
■Product Specifications
Rating
Current rating : 3A
Operating Temperature Range : -55 to +85ç (Note 1)
Voltage rating : 300V AC Operating Humidity Range : 40 to 80%
Item
Storage Temperature Range : -10 to +60ç (Note 2)
Operating Humidity Range : 40 to 70% (Note 2)
Specification
Condition
1. Insulation Resistance
1000Mø
500V DC
2. Withstanding Voltage
No flashover or insulation breakdown.
1000V AC/1 minute.
3. Contact Resistance
15mø max.
Measured at 0.1A
4. Vibration
No electrical discontinuity of 1μs or more
Frequency : 10 to 55 Hz, single amplitude of 0.75mm, 2 hours in each of the 3 directions.
5. Humidity (Steady state) Insulation resistance : 1000ø min.
6. Temperature Cycle
96 hours at temperature of 40ç and humidity of 90% to 95%
( -55ç : 30 minutes→15 to 35ç: 5 minutes max.→
(125ç : 30 minutes→15 to 35ç: 5 minutes max.) 5 cycles
No damage, cracks, or parts looseness.
7. Durability (Mating/un-mating) Contact resistance : 15mø max.
500 cycles
8. Resistance to Soldering heat No deformation of components affecting performance.
Solder bath : 260ç for 10 seconds
Manual soldering : 360ç for 5 seconds
Note 1 : Includes temperature rise caused by current flow.
Note 2 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and
Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation.
Note 3 : Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for
a specific part number shown.
■Material / Finish
Parts
Insulator
Receptacle Contact
DS
Material
Finish
Remarks
PBT
Black
UL94V-0
Phosphor bronze
Selective gold plated
DSA
Pin header
Brass or phosphor bronze
B53
HIF3H Series●2.54mm Pitch Board to Board Connector
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Pin Header
HIF3H - * P B - 2.54 DSA
q
w
q Series Name
e
r
t
y
: HIF3H
w Number of contacts : 4, 6, 10, 12, 14, 16, 20, 24, 26,
30, 34, 40, 50, 60
e
P
: Pin header
r Contact material A : Phosphor bronze (DS : brass)
B : Brass
t Contact pitch
: 2.54mm
y Contact type
DS : Right angle type
DSA : Straight type
W : Wrapping type
●Socket
HIF3H
q
A - * D A - 2.54 DSA
w
q Series Name
e
r
t
y
u
: HIF3H
w No symbol : Standard
A
: With mis-insertion preventive guide
B
: Similarly, guide position center 1 point type for 50, 60 and 64 contacts
e Number of contacts : 4, 6, 8, 10, 12, 14, 16, 18, 20, 24, 25,
26, 30, 34, 40, 50, 60, 64
r Contact alignment : D : double rows
S : single row
t
A
: Straight selective gold plated
B
: Right angle selective gold plated
y Contact pitch
: 2.54mm
u Contact type
DSA : Straight type
B54
■Receptacle Straight Through hole Type
Unit : mm
Part No.
HRS No.
No. of Contacts
HIF3HA- 6DA-2.54DSA(61) 618-0139-8 61
HIF3HA-10DA-2.54DSA(61) 618-0101-5 61
HIF3HA-10DA-2.54DSA(61) 618-0121-2 61
HIF3HA-12DA-2.54DSA(61) 618-0102-8 61
HIF3HA-16DA-2.54DSA(61) 618-0103-0 61
HIF3HA-16DA-2.54DSA(61) 618-0123-8 61
HIF3HA-18DA-2.54DSA(61) 618-0111-9 61
HIF3HA-20DA-2.54DSA(61) 618-0104-3 61
HIF3HA-20DA-2.54DSA(61) 618-0124-0 61
HIF3HA-24DA-2.54DSA(61) 618-0113-4 61
HIF3HA-26DA-2.54DSA(61) 618-0105-6 61
HIF3HA-26DA-2.54DSA(61) 618-0125-3 61
6
A
B
Part No.
RoHS
10
13.7 10.16
12
16.24 12.7
16
21.32 17.78
18
23.86 20.32
24
31.46 27.94
26
34.02 30.48
HRS No.
HIF3HA-30DA-2.54DSA(61) 618-0106-9 61
8.62 5.08
HIF3HA-30DA-2.54DSA(61) 618-0126-6 61
HIF3HA-34DA-2.54DSA(61) 618-0107-1 61
HIF3HA-34DA-2.54DSA(61) 618-0127-9 61
HIF3HA-40DA-2.54DSA(61) 618-0108-4 61
YES
HIF3HA-40DA-2.54DSA(61) 618-0128-1 61
No. of Contacts
A
B
RoHS
30
39.1 35.56
34
44.18 40.64
40
51.8 48.26
50
64.5 60.96 YES
60
77.2 73.66
64
82.28 78.74
HIF3HA-50DA-2.54DSA(61) 618-0109-7 61
HIF3HA-50DA-2.54DSA(61) 618-0129-4 61
HIF3HB-50DA-2.54DSA(61) 618-0131-6 61
HIF3HA-60DA-2.54DSA(61) 618-0110-6 61
HIF3HA-60DA-2.54DSA(61) 618-0130-3 61
HIF3HB-60DA-2.54DSA(61) 618-0132-9 61
HIF3HA-64DA-2.54DSA(61) 618-0112-1 61
HIF3HA-64DA-2.54DSA(61) 618-0134-4 61
HIF3HB-64DA-2.54DSA(61) 618-0133-1 61
Part No.
HRS No.
HIF3H-6SA-2.54DSA(61)
No. of Contacts
A
Unit : mm
B RoHS
562-0713-1 61
6
16.24 12.7
HIF3H-10SA-2.54DSA(61) 562-0719-8 61
10
26.4
HIF3H-12SA-2.54DSA(61) 562-0723-5 61
12
31.48 27.94
HIF3H-14SA-2.54DSA(61) 562-0655-7 61
14
36.56 33.02
HIF3H-20SA-2.54DSA(61) 562-0704-0 61
48.26
HIF3H-25SA-2.54DSA(61) 562-0705-3 61
25
64.5
60.96
22.86
YES
B55
■Receptacle Right Angle Through hole Type
B56
Part No.
HRS No.
No. of Contacts
HIF3H- 4DB-2.54DS(61)
618-0150-0 61
4
HIF3H- 8DB-2.54DS(61)
618-0153-9 61
8
HIF3H-10DB-2.54DS(61)
618-0141-0 61
10
13.7 10.16
HIF3H-12DB-2.54DS(61)
618-0152-6 61
12
16.24 12.70
HIF3H-14DB-2.54DS(61)
618-0154-1 61
14
HIF3H-16DB-2.54DS(61)
618-0142-2 61
16
RoHS
B
6.0
2.54
HIF3H-18DB-2.54DS(61) 618-0165-8 61
18
23.86 20.32
11.16 7.62
HIF3H-20DB-2.54DS(61) 618-0143-5 61
HIF3H-24DB-2.54DS(61) 618-0216-7 61
24
31.48 27.94
HIF3H-26DB-2.54DS(61) 618-0144-8 61
26
34.02 30.48
18.78 15.24
HIF3H-30DB-2.54DS(61) 618-0145-0 61
30
39.1 35.56 YES
21.32 17.78
HIF3H-34DB-2.54DS(61) 618-0146-3 61
34
44.18 40.64
HIF3H-40DB-2.54DS(61) 618-0147-6 61
40
51.8 48.26
HIF3H-50DB-2.54DS(61) 618-0148-9 61
50
64.5 60.96
HIF3H-60DB-2.54DS(61) 618-0149-1 61
60
77.2 73.66
YES
Part No.
HRS No.
No. of Contacts
A
Unit : mm
B RoHS
A
■Pin Header Through hole Type
Part No.
HRS No.
No. of Contacts
A
B
RoHS
Part No.
HRS No.
HIF3H-04PA-2.54DS(61)
618-0073-1 61
4
6
HIF3H-30PB-2.54DSA(61)
618-0207-6 61
HIF3H-06PB-2.54DSA(61)
618-0215-4 61
6
8.62 5.08
HIF3H-30P0-2.54W
618-0186-8
HIF3H-10PB-2.54DSA(61)
618-0201-0 61
HIF3H-10P0-2.54W
618-0185-5
10
13.7 10.16
HIF3H-34PB-2.54DSA(61)
618-0208-9 61
HIF3H-34P0-2.54W
618-0181-4
HIF3H-12PB-2.54DSA(61)
618-0202-2 61
12
HIF3H-14PB-2.54DSA(61)
618-0213-9 61
14
16.24 12.7
HIF3H-40PB-2.54DSA(61)
618-0209-1 61
18.78 15.24
HIF3H-40P0-2.54W
618-0182-7
HIF3H-16PB-2.54DSA(61)
618-0203-5 61
HIF3H-16PA-2.54DS(61)
618-0065-3 61
16
21.3 17.78 YES
HIF3H-50PB-2.54DSA(61)
618-0210-0 61
HIF3H-60PB-2.54DSA(61)
618-0211-3 61
HIF3H-20PB-2.54DSA(61)
618-0204-8 61
HIF3H-60P0-2.54W
618-0187-0
HIF3H-20P0-2.54W
618-0183-0
HIF3H-24PB-2.54DSA(61)
618-0205-0 61
HIF3H-24PA-2.54DS(61)
618-0067-9 61
HIF3H-26PB-2.54DSA(61)
618-0206-3 61
HIF3H-26P0-2.54W
618-0184-2
2.54
24
31.46 27.94
26
34.02 30.48
No. of Contacts
A
Unit : mm
B RoHS
30
39.1 35.56
34
44.18 40.64
40
51.8 48.26
50
64.5 60.96
60
77.2 73.66
YES
Note 1 : The stitch line area is divided in two for 50 and 60
contacts.
Note 2 : *indicates the number of contacts.
Note 3 : Wrapping is 6.0.
Note 4 : Wrapping is 16.0.
B57
BPCB mounting pattern
●Pin Header Straight and Right Angle Type
Size A List
●Receptacle Right Angle Type
●Receptacle Straight Type
B58
No. of Contacts
A
4
2.54
6
5.08
8
7.62
10
10.16
12
12.7
14
15.24
16
17.78
18
20.32
24
27.94
26
30.48
30
35.56
34
40.64
40
48.26
50
60.96
60
73.66
64
78.74
HIF3H-10DB-2.54DS(71) 价格&库存
很抱歉,暂时无法提供与“HIF3H-10DB-2.54DS(71)”相匹配的价格&库存,您可以联系我们找货
