0.4mm Pitch, 1.5mm Mated Height, Board-to-Fine Coaxial Cable Connectors
DF36 Series
1.5±0.15 (Mated height)
High contact reliability –
Effective mating length of 0.4mm
Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
(0.4) (Effective mating length)
Enhanced shielding (standard type)
Plug
■Features
1. Small mated height and board occupied
space
Small pitch (0.4mm) and mated height (1.5mm)
allows use in space-restricted areas.
Standard type : mated height 1.5mm, depth 4.4mm
Saving space type: mated height 1.5mm, depth
2.8mm Plug : Height 1.33mm, depth 2.8mm
2. Enhanced shielding and ground connections
Metal covers on the plug and receptacle connect to
each other with a reliable multi-point ground
contacts, assuring reliable ground connection and
EMC protection.
Receptacle
Ground contacts
Fully mated
Multi-point contacts
Enhanced shielding (Space Saving type)
3. Reliable lock
Fully mated condition is assured with reliable
locks at 4 locations, confirming it with a distinct
tactile click.
4. Reliable electrical and mechanical connection
Despite it’s small mated height, unique contact
configuration assures highly reliable connection,
with effective mating length of 0.4mm.
Fully mated
5. Solder wicking prevention
Nickel barriers prevent solder wicking in the
critical contact areas.
4-point lock: 2 points at each end
6. Durable plug construction
Formed metal shells on the top and side surfaces
form a strong and rigid assembly.
7. RoHS, Halogen-free*
*As defined by IEC61249-2-21
Br-900 ppm maximum,Cl-900 ppm maximum,
Cl+Br combined-1,500 ppm maximum
■Receptacle for conductivity tests
We have a line-up of connectors for inspection,
usable for electrical testing of both standard type
and space saving type.
Distinct tactile click
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2017.6e
1
DF36 Series●0.4mm Pitch, 1.5mm Mated Height, Board-to-Fine Coaxial Cable Connectors
■Product Specifications
0.25A (42 AWG)
0.25A (44 AWG) (Note 3)
0.1A (46 AWG)
Current rating
Ratings
Voltage rating
30V AC
Item
1.Insulation resistance 50Mø min
-35 to +85°C (Note 1)
20 to 80%
Storage temperature range
Storage humidity range
-10 to +60°C (Note 2)
40 to 70% (Note 2)
Specification
Conditions
100V DC
2.Withstanding voltage No flashover or insulation breakdown
100V AC / 1 minute
3.Contact resistance
Signal : 80mø max., Ground : 80mø max.
100mA (DC or 1,000Hz)
4.Vibration
No electrical discontinuity of 1μs or longer
No damage, cracks or parts dislocation.
Frequency : 10 to 55Hz, single amplitude of 0.75
mm, 10 cycles in each of the 3 axial directions
Contact resistance (Change from initial value) 50mø max.
Insulation resistance : 25Mø min.
96 hours at 40 ±2°C, and humidity of 90 to
95%
5.Humidity
Operating temperature range
Operating humidity range
6.Temperature cycle
Temperature : -55°C / 5 to 35°C / 85°C / 5 to 35°C
Time : 30 min. / 2 to 3 min. / 30 min. / 2 to 3 min.
5 cycles
7.Durability
30 cycles
8.Resistance to
soldering heat
No deformation of components affecting
performance.
Reflow : At the recommended temperature profile
Manual soldering : 350°C for 3 seconds
Note 1 : Includes temperature rise caused by current flow.
Note 2 : The term "storage" refers to products stored for a long period prior to mounting and use.
The operating temperature and humidity range covers the non-conducting condition of connectors after board mounting
and the temporary storage conditions of transportation, etc.
Note 3 : With only the connector portion at an elevated temperature level, the rated current value is set.
■Materials / Finish
Item
Receptacle
(Standard)
Plug
(Standard)
Item
Receptacle
(Space-saving)
Plug
(Space-saving)
2
Part
Insulator
Contacts
Metal cover
Insulator
Contacts
Metal shell
Material
LCP
Phosphor bronze
Phosphor bronze
LCP
Phosphor bronze
Phosphor bronze
Finish
Color : Black
Gold plating
Tin plating
Color : Natural (Beige), Black
Gold plating
Tin plating
Remarks
UL94V-0
------------UL94V-0
Part
Insulator
Contacts
Metal cover
Insulator
Contacts
Metal shell
Material
LCP
Phosphor bronze
Phosphor bronze
LCP
Phosphor bronze
Phosphor bronze
Finish
Color: Black
Gold plating
Gold plating
Gold plating
Gold plating
Remarks
UL94V-0
------------UL94V-0
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Connector
DF 36 A J – * S – 0.4 V (**)
1
2
3
4
5
6
7
8
9
DF 36 A J – * P – SHL
1
1
2
3
2
3
4
5
6
10
4
Series name : DF
Series No. : 36
Connector style
Receptacle/shell
A : Standard
Blank : Space-saving
Plug
Blank : Standard
5
Insulator type
J
: Receptacles for conductivity
tests
Blank : Standard or space-saving
P
: Single-row plug
Number of contacts
Standard
: 15 to 50
Space-saving
: 15 to 25
Receptacles for conductivity tests : 15 to 50
6
7
8
9
10
Connector style
S
: Single-row receptacle
P
: Single-row plug
Contact pitch: 0.4mm
Termination type
V
: Straight SMT
SD : Fine coaxial cable plug
Packaging
(51) : Embossed tape packaging
Installation item (separate)
SHL : Metal cover
■Combinations
●Standard use
DF36(A)-*S-0.4V(**)
DF36(A)-*P-ASSY
DF36-*P-0.4SD(**)
DF36(A)-*P-SHL
Note: The product specification of the above combination is shown on page 2.
●Receptacle test
DF36(A)-*S-0.4V(**)
DF36(A)J-*P-ASSY • • Note
DF36-*P-0.4SD(**)
DF36(A)J-*P-SHL
Note: This harness item is only usable for the receptacle test.
For the product specification of the above combination, please contact our sales department.
●Plug test
DF36(A)J-*S-0.4V(**) • • Note
DF36(A)-*P-ASSY
DF36-*P-0.4SD(**)
DF36(A)-*P-SHL
Note : This harness item is only usable for the plug test.
π : ASSY means a harness item.
3
■Receptacles - Standard, with metal cover
B±0.2
A±0.15
P=0.4±0.1
0.15±0.05
(0.95)
(C)
Lot No.
1.5±0.15
CAV No.
Vacuum pick-up area
4.4±0.2
(0.87)
Contact No.1
All dimensions : mm
Part No.
HRS No.
No. of Contacts
A
DF36A-15S-0.4V(**)
662-4509-5-**
15
5.6
9.66
2.6
DF36A-25S-0.4V(**)
662-4011-4-**
25
9.6
13.66
2.6
DF36A-30S-0.4V(**)
662-4017-0-**
30
11.6
15.66
3.0
DF36A-40S-0.4V(**)
662-4003-6-**
40
15.6
19.66
3.0
DF36A-45S-0.4V(**)
662-4008-0-**
45
17.6
21.66
3.0
DF36A-50S-0.4V(**)
662-4043-0-**
50
19.6
23.66
3.0
B
C
[Specifications number] - * *, (* *)
(4,000 pcs/reel)
Note 1 : Tape and reel packaging (4,000 pcs/reel).
Order by number of reels.
Note 2 : The 15 pos. does not have a lot stamp.
BRecommended PCB mounting pattern
1.05±0.05
0.4±0.02
0.25±0.02
Contact No.15
3.85±0.05
3.2±0.05
2.7±0.05
2.1±0.05
0.7±0.05
0.3±0.05
1.05±0.05
Contact No.1
●25 pos.
9.47±0.05
7.09±0.05
6±0.05
5.6±0.02
3.85±0.05
3.2±0.05
2.7±0.05
2.1±0.05
0.7±0.05
0.3±0.05
●15 pos.
Contact No.1
6.7±0.05
11.09±0.05
13.47±0.05
6±0.05
7.09±0.05
9.47±0.05
●40 pos.
0.
25
0.
05
Contact No.30
1.7±0.05
6.7±0.05
11.6±0.02
13.09±0.05
15.47±0.05
P=0.4±0.02
Contact No.1
19.47±0.05
17.09±0.05
16±0.05
15.6±0.02
11±0.05
7±0.05
2±0.05
3.85±0.05
3.2±0.05
0.25±0.02
2.7±0.05
2.1±0.05
0.7±0.05
0.3±0.05
1.05±0.05
Contact No.1
15.47±0.05
13.09±0.05
11.5±0.05
6.5±0.05
2.5±0.05
C
1.05±0.05
●30 pos.
3.85±0.05
3.2±0.05
2.7±0.05
2.1±0.05
0.7±0.05
0.3±0.05
P=0.4±0.02
0.25±0.02
Contact No.25
1.7±0.05
1.3±0.05
Ground areas
4
13.47±0.05
11.09±0.05
10±0.05
9.6±0.02
5.6±0.05
2.2±0.05
1.7±0.05
6.4±0.05
10.4±0.05
15.1±0.05
17.09±0.05
19.47±0.05
P=0.4±0.02
0.25±0.02
Contact No.40
BRecommended PCB mounting patterns
●50 pos.
21.47±0.05
19.09±0.05
18±0.05
17.6±0.02
13.4±0.05
10±0.05
5.6±0.05
2.2±0.05
23.47±0.05
21.09±0.05
20±0.05
19.6±0.02
16±0.05
12.8±0.05
8.8±0.05
5.6±0.05
1.6±0.05
Contact No.1
P=0.4±0.02
0.25±0.02
Contact No.45
3.85±0.05
3.2±0.05
2.7±0.05
2.1±0.05
0.7±0.05
0.3±0.05
1.05±0.05
Contact No.1
P=0.4±0.02
0.25±0.05
Contact No.50
1.7±0.05
1.7±0.05
6.7±0.05
12.1±0.05
17.1±0.05
19.09±0.05
21.47±0.05
6.7±0.05
14.1±0.05
19.1±0.05
21.09±0.05
23.47±0.05
Ground areas
■Receptacles - Space-saving
B±0.2
A±0.15
P=0.4±0.1
0.15±0.05
(2.8)
(0.87)
Contact No.1
CAV No.
Lot No.
(C)
1.5±0.15
(0.95)
Vacuum pick-up area
All dimensions : mm
HRS No.
No. of Contacts
A
B
C
D
DF36-15S-0.4V(**)
662-4031-1-**
15
5.6
9.66
2.6
8.28
DF36-20S-0.4V(**)
662-4039-3-**
11.66
2.6
10.28
DF36-25S-0.4V(**)
662-4005-1-**
25
9.6
13.66
2.6
12.28
Part No.
(5,000 pcs/reel)
Note 1 : Tape and reel packaging (5,000 pcs/reel).
0.3±0.05
0.7±0.05
2.1±0.05
A±0.02
Contact No.1
3.1±0.05
3.85±0.05
3.2±0.05
2.7±0.05
2.1±0.05
0.7±0.05
0.3±0.05
1.05±0.05
●45 pos.
P=0.4±0.02
0.25±0.02
1.19±0.05
D±0.05
Ground areas
5
■Plug
●Separate metal cover required
6¤%#&*
8dciVXiCd#&
86KCd#
E2%#)¤%#&
7¤%#&*
All dimensions : mm
HRS No.
No. of Contacts
A
B
C
D
Packing
DF36C-15P-0.4SD(**)
Part No.
662-4035-2 **
15
11.4
5.6
6.6
7.5
5,000 pcs./reel
DF36-20P-0.4SD(**)
662-4040-2 **
7.6
8.6
9.5
5,000 pcs./reel
DF36-25P-0.4SD(**)
662-4006-4 **
25
14.6
9.6
10.6
11.5
5,000 pcs./reel
DF36-30P-0.4SD(**)
662-4018-3 **
30
16.6
11.6
12.6
13.5
5,000 pcs./reel
DF36-40P-0.4SD(**)
662-4002-3 **
40
20.6
15.6
16.6
17.5
5,000 pcs./reel
DF36-45P-0.4SD(**)
662-4009-2 **
45
22.6
17.6
18.6
19.5
5,000 pcs./reel
DF36-50P-0.4SD(**)
662-4044-3 **
50
24.6
19.6
20.6
21.5
5,000 pcs./reel
Note 1 : Tape and reel packaging(5,000 pcs/reel) order by number of reels.
Note 2 : The metal cover is required for fine coaxial cable termination.
B±0.15
Pitch maintaining
tape Note 1
Laminated tape
D MAX
0.33 MAX(Jacket)
0.47±0.03
(Ground bar)
Note 1 : The pitch maintaining tape can be left in place during the termination process. Use high quality tape.
Note 2 : Contact Hirose for Termination Procedures.
6
0.5 +0.1
2.5 MIN
0.2 MAX(Insulator)
5 MIN
C±0.1
Inner conductor
(Pre soldering required)
0.3±0.05
4 MIN
1.27±0.05(Cut dimension)
3 MIN
10±3
P=0.4±0.07
0.05 MAX
Outer shield (for individual conductor)
BRecommended Fine Coaxial Cable Preparation
■Metal cover - Required for assembly and termination of the Plug
0.25±0.1
2.8±0.1
A±0.15
[ Standard ]
All dimensions : mm
HRS No.
Plating
No.of Contacts
A
DF36A-15P-SHL
662-4511-7
15
9.92
DF36A-25P-SHL
662-4007-7
25
13.92
DF36A-30P-SHL
662-4019-6
30
15.92
DF36A-40P-SHL
662-4013-0
40
19.92
DF36A-45P-SHL
662-4010-1
45
21.92
DF36A-50P-SHL
662-4045-6
50
23.92
Tin
Note 1 : Reel packaging (10,000 pcs/reel).
All dimensions : mm
[ Space-saving ]
Part No.
HRS No.
DF36-15P-SHL
662-4026-1
DF36-20P-SHL
662-4041-5
DF36-25P-SHL
662-4012-7
Plating
No. of Contacts
A
15
9.92
25
13.92
Gold
BPackaging Specification
●Reel Dimensions
KVXjjbe^X`"jeVgZVXZciZg
●Embossed Carrier Tape Dimensions –
Standard Receptacle
EVgiCjbWZgAVWZa
8¤%#&
7¤%#&
6¤%#(
9 '%
:B6M
G%
Part No.
Part No.
JcgZZa^c\Y^gZXi^dc
All dimensions : mm
HRS No.
No. of Contacts
A
B
C
D
E
DF36A-15S-0.4V(**)
662-4509-5 **
15
32
28.4
14.2
32.4
38.4
DF36A-25S-0.4V(**)
662-4011-4 **
25
32
28.4
14.2
32.4
38.4
DF36A-30S-0.4V(**)
662-4017-0 **
30
32
28.4
14.2
32.4
38.4
DF36A-40S-0.4V(**)
662-4003-6 **
40
44
40.4
20.2
44.4
50.4
DF36A-45S-0.4V(**)
662-4008-0 **
45
44
40.4
20.2
44.4
50.4
DF36A-50S-0.4V(**)
662-4043-0 **
50
44
40.4
20.2
44.4
50.4
7
●Reel Dimensions
Space saving Receptacle
EVgiCjbWZgAVWZa
7¤%#&
6¤%#(
8¤%#&
G%
9 '%
:B6M
JcgZZa^c\Y^gZXi^dc
All dimensions : mm
HRS No.
No. of Contacts
A
B
C
D
E
DF36-15S-0.4V(**)
662-4031-1 **
15
32
28.4
14.2
32.4
38.4
DF36-20S-0.4V(**)
662-4039-3 **
28.4
14.2
32.4
38.4
DF36-25S-0.4V(**)
662-4005-1 **
25
32
28.4
14.2
32.4
38.4
Part No.
●Reel Dimensions
●Plug
EVgiCjbWZgAVWZa
¢'&¤%#8¤%#&
9 '%
:B6M
G%
7¤%#&
6¤%#(
JcgZZa^c\Y^gZXi^dc
All dimensions : mm
Part No.
HRS No.
No. of Contacts
A
B
C
D
E
DF36C-15P-0.4SD(**)
662-4035-2 **
15
32
28.4
14.2
32.4
32.4
DF36-20P-0.4SD(**)
662-4040-2 **
28.4
14.2
32.4
32.4
DF36-25P-0.4SD(**)
662-4006-4 **
25
32
28.4
14.2
32.4
32.4
DF36-30P-0.4SD(**)
662-4018-3 **
30
32
28.4
14.2
32.4
32.4
DF36-40P-0.4SD(**)
662-4002-3 **
40
44
40.4
20.2
44.4
44.4
DF36-45P-0.4SD(**)
662-4009-2 **
45
44
40.4
20.2
44.4
44.4
DF36-50P-0.4SD(**)
662-4044-3 **
50
44
40.4
20.2
44.4
44.4
8
BExtraction tool
For details about the extraction tool, please contact your Hirose sales representative.
BUsage Recommendations
1.Recommended temperature
profile
Temperature (ç)
250ç
250
220ç
200
60sec max
180ç
150
150ç
90 to 120sec
100
50
Room
temperature
100
150
200
250
300
Time (sec.)
Solder composition : Paste, 96.5%Sn/3.0%Ag/0.5%Cu
Note 1 : Up to 2 cycles of Reflow soldering are possible under the
same conditions, provided that there is a return
to normal temperature between the first and second cycle.
Note 2 : The temperature profile indicates the board surface
temperature at the point of contacts with the connector
terminals.
2.Recommended manual soldering
3.Recommended screen thickness
and open area ratio (Pattern area
ratio)
Manual soldering : 350ç for 3 seconds
Do NOT use flux compound when manual soldering.
Standard Thickness : 0.1mm
Open area ratios : Lead terminal : 90%
Ground terminal : 100%
Space-saving Thickness : 0.1mm
Ground terminal : 90%
4.Board warpage
Maximum of 0.02mm at the connector center, with both ends of the
connector as reference points.
5.Cleaning conditions
IPA (Isopropyl Alcohol) cleaning is permitted. (Cleaning is not
recommended as it may change the feel of the mating and un-mating
of the connector. Please contact your Hirose sales representative for
information if you plan to use any other cleaning agents.)
9
BPrecautions
Precautions
■Mating / un-mating
[ Standard ]
Mate the plug with the receptacle by pressing straight against the entire plug surface. Do NOT mate the plug while holding by the
terminated cable.
Use a dedicated extraction tool to un-mate the plug.
Insert the tool under either end of the plug (clearance) and pull straight up as illustrated below.
Please refrain from removing by holding the electrical cable, otherwise this may result in cable disconnection, connector breakage and
so on.
Extraction tool
Plug
End side (clearance)
[ Space-saving ]
Mate the plug with the receptacle by pressing straight against the entire plug surface, the same as the standard. Use a dedicated
Insert the tool under the plug at the front side (clearance) and pull straight up, as illustrated below.
Do NOT mate / un-mate the connectors when receptacle is not mounted on the board.
and so on.
Extraction tool
Extraction tool
Front side
Plug
■Do not mate / un-mate the connectors when receptacle is not mounted on the board.
■In the manual soldering process, don't carry out the flux coating which will cause a flux
blister on the connector.
■Different production lots may exhibit different shades of the insulator materials. No affect
on form, fit or function of the connectors.
■Excessive scoop insertion or extraction may result in damage.
10
MEMO :
11
USA:
HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE
2300 Warrenville Road, Suite 150,
Downers Grove, IL 60515
Phone : +1-630-282-6700
http://www.hirose.com/us/
USA:
HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE
2841 Junction Ave, Suite 200
San Jose, CA. 95134
Phone : +1-408-253-9640
Fax : +1-408-253-9641
USA:
HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE)
17197 N. Laurel Park Drive, Suite 253,
Livonia, MI 48152
Phone : +1-734-542-9963
Fax : +1-734-542-9964
USA:
HIROSE ELECTRIC (U.S.A.), INC. BOSTON OFFICE
300 Brickstone Square Suite 201,
Andover, MA 01810
Phone : +1-978-662-5255
THE NETHERLANDS:
HIROSE ELECTRIC EUROPE B.V.
Hogehillweg #8 1101 CC Amsterdam Z-O
Phone : +31-20-6557460
Fax : +31-20-6557469
http://www.hirose.com/eu/
GERMANY:
HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH
Schoenbergstr. 20, 73760 ostfildern
Phone : +49-711-456002-1
Fax : +49-711-456002-299
GERMANY:
HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE
Neumeyerstrasse 22-26, 90411 Nurnberg
Phone : +49-911 32 68 89 63
Fax : +49-911 32 68 89 69
GERMANY:
HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE
Bayernstr. 3, Haus C 30855 Langenhagen, Germany
Phone : +49-511 97 82 61 30
Fax : +49-511 97 82 61 35
FRANCE:
HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE
Regus La Garenne Colombes,Place de La Belgique,
71 Boulevard National La Garenne Colombes, 92250, France
Phone : +33 (0) 1 7082 3170
Fax : +33 (1) 7082 3101
UNITED KINGDOM:
HIROSE ELECTRIC EUROPE BV (UK BRANCH)
4 Newton Court, Kelvin Drive, Knowlhill,
Milton Keynes, MK5 8NH
Phone : +44-1908 202050
Fax : +44-1908 202058
CHINA:
HIROSE ELECTRIC (SHANGHAI) CO., LTD.
18, Enterprise Center Tower 2, 209# Gong He
Road, Jing’an District, Shanghai, CHINA 200070
Phone : +86-21-6391-3355
Fax : +86-21-6391-3335
http://www.hirose.com/cn/
CHINA:
HIROSE ELECTRIC (SHANGHAI) CO.,LTD. BEIJING BRANCH
A1001, Ocean International Center, Building 56# East 4th
Ring Middle Road, ChaoYang District, Beijing, 100025
Phone : +86-10-5165-9332
Fax : +86-10-5908-1381
CHINA:
HIROSE ELECTRIC TECHNOLOGIES (SHENZHEN) CO., LTD.
Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre,
5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008
Phone : +86-755-8207-0851
Fax : +86-755-8207-0873
HONG KONG:
HIROSE ELECTRIC HONGKONG TRADING CO., LTD.
Room 1001, West Wing, Tsim Sha Tsui Centre, 66
Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong
Phone : +852-2803-5338
Fax : +852-2591-6560
http://www.hirose.com/hk/
TAIWAN:
HIROSE ELECTRIC TAIWAN CO., LTD.
103 8F, No.87, Zhengzhou Rd., Taipei
Phone : +886-2-2555-7377
Fax : +886-2-2555-7350
http://www.hirose.com/tw/
KOREA:
HIROSE KOREA CO.,LTD.
143, Gongdan 1-daero, Siheung-si,
Gyeonggi-do, 15084, Korea
Phone : +82-31-496-7000
Fax : +82-31-496-7100
http://www.hirose.co.kr/
SINGAPORE:
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE
03, Anson Road, #20-01, Springleaf Tower, Office NO.552, Regus-Green Boulevard, Level5, Tower C,
Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India
Singapore 079909
Phone : +91-12-660-8018
Phone : +65-6324-6113
Fax : +91-120-4804949
Fax : +65-6324-6123
http://www.hirose.com/sg/
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE
Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma
Gandhi (MG) Road, Bangalore 560 001, Karnataka, India
Phone : +91-80-4120 1907
Fax : +91-80-4120 9908
MALAYSIA:
THAILAND:
PENANG REPRESENTATIVE OFFICE
BANGKOK OFFICE (REPRESENTATIVE OFFICE)
73-3-1, Ideal@The One, Jalan Mahsuri, Bayan Unit 4703, 47th FL., 1 Empire Tower, South Sathorn
Road, Yannawa, Sathorn, Bangkok 10120 Thailand
Lepas Penang, 11950, Malaysia
Phone : +66-2-686-1255
Phone : +604-648-5536
Fax : +66-2-686-3433
12
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 06/2017. Contents are subject to change without notice for the purpose of improvements.
