5.08
G
3.96
1.40
3.70
8.10
3.96±0.15
Pin 1.14X0.40
3.96
Recommended PCB Layout
Top Entry General Tolerance ±0.05
Bottom Entry General Tolerance ±0.05
B±0.25
Solder Area
Solder Area
F
6.10
7.10
A
2.80 Ref.
9.35±0.10
8.89
Cap
3.00
E
Dimensions
Number of
Contacts
1.40
Ø1.70
3.70
A±0.20
8.10
H
A
B
2
3.96
7.92
3
7.92
11.88
4
11.88
15.84
5
15.84
19.80
6
19.80
23.76
7
23.76
27.72
8
27.72
31.68
9
31.68
35.64
10
35.64
39.60
43.56
11
39.60
12
43.56
47.52
13
47.52
51.48
14
51.48
55.44
15
55.44
59.40
16
59.40
63.36
17
63.36
67.32
18
67.32
71.28
0.15
D
A
7.10±0.30
Section A-A
Ordering Grid
C
Specifications 规格
Material 物料
Insulator 绝缘体: LCP, UL94V-0
Contact 端子:Phosphor Bronze
B
A
Plating 电镀
Contact 接触:Tin All Over
Underplating底层电镀: Nickel all over
Electrical 电气
Current Rating 电流额定值: 7.9 Amp Per Pin
Contact Resistance 接触电阻值: 30 mΩ max.
Insulation Resistance 绝缘电阻值: 1000 MΩ min.
Dielectric Withstand Voltage 耐电压: 1000 V AC
Mechanical & Environmental 机械 & 环境
Operating Temperature 工作温度: -40°C to +105°C
Soldering Process 可焊性
IR Reflow 回流焊: 260°C for 10 sec.
Manual Solder 人工焊接: 350°C for 3-5 sec
2
3
4
X
Request Samples
and Quotation
Packing Options
E = Tube with Cap (Standard)
D = Tube
Contact Plating
C= Tin All Over
Mates with 配套之公头
(Subject to Pin Length 在端子长度适合的条件下)
BH010
For bottom entry applications, stringent soldering
control & pin alignment are required as lead to pad
misalignment could cause incorrect mating.
C
No. of Contacts
02 to 18
Part Number
Product Description
BH015
3.96mm Pitch Socket, Single Row,
Surface Mount, Vertical,Dual Entry
Drawing Date
26th May 2017
By
Detail
1
XX
BH015
Revision
Date
5
CC
Tolerances (Except as Noted)
Drawing
Release
A
05/07/17
X. ± 0.30
X.° ± 5°
X.X° ± 3°
X.X ± 0.25
X.XX ± 0.15 X.XX° ± 2°
X.XXX ± 0.10 X.XXX° ± 1°
Length
Angle
6
Units:
Metric (mm)
C
3rd Angle Projection
7
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CC
8
Sheet No.
1/1
很抱歉,暂时无法提供与“BH015-06-C-E”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+16.64280
- 200+6.64200
- 500+6.42600
- 1000+6.30720
- 国内价格 香港价格
- 1+13.684331+1.77598
