BG304-02-A-0500-L-G
BG304-02-A-0500-L-G
    GCT
    插件,P=2.54mm
    排针 间距:2.54mm 1x2P 直插
BG304-02-A-0500-L-G 数据手册
H 3.00±0.25 Pin 0.64 sq. F D D±0.30 2.50 G .10 Ø1 2.07±0.20 B±0.20 2.54(Non-Accum) RECOMMENDED PCB LAYOUT General Tolerance: ±0.05 Specifications E Material Insulator: Polymer, LCP , Natural, UL94V-0 Contact:Brass 6 Position Example 2.50±0.10 D Plating Underplating: 30µ”-50µ" Nickel all over Contact Area: See ordering grid 2.54±0.10 Electrical Current Rating: 3A per pin Contact Resistance: 20 mΩ max. Insulating Resistance: 1000 MΩ min. Dielectric Withstand Voltage: 500V AC A ±0.50 Ordering Grid BG304 X Dimensions No. of Contacts 02 to 08 A B Contact Plating A = Gold Flash All Over 2 5.08 2.54 3 7.62 5.08 C Contacts B XX 4 10.16 7.62 5 12.70 10.16 6 15.24 12.70 8 20.32 17.78 (Other plating options available on request) 0500 L X Request Samples and Quotation Mates with: A: BG306 B: Direct solder to PCB Part Number Product Description BG304 2.54mm Pitch Pin Header, Single Row,U-Shaped, Thru-Hole, Single Insulator, Natural LCP Drawing Date 7th December 2011 2 Soldering Process: Wave: 250°C for 5-10 secs Manual Solder: 350°C for 3-5 secs Insulator Material L = LCP (Natural) Dimension D (Footprint width) 0500 = 5.00mm (Standard) Or Specify Dimension D e.g. 1000 = 10.00mm (Maximum 2500=25.00mm) (Minimum 0320=3.20mm) A 1 Mechanical & Environmental Operating Temperature: -40°C to +105°C Packing Options G = Plastic Box (Standard) D = Tube 3 4 By CC Detail Drawing Release A3 24/04/18 Revision Date 5 Tolerances (Except as Noted) Length Angle X.X ± 0.30 X.XX ± 0.20 Units: Metric (mm) C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By CM 8 Sheet No. 1/1
BG304-02-A-0500-L-G 价格&库存
很抱歉,暂时无法提供与“BG304-02-A-0500-L-G”相匹配的价格&库存,您可以联系我们找货
BG304-02-A-0500-L-G
  • 3000+1.206423000+0.15591
