8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
C
1062
D
1062
F
E
2078
F
2442
G
2743
DESCRIPTION
UPDATE DWG. AND TABLES, MOVED RA
TERMINATION TO PAGE 2
UPDATE DWG.
DATE
BY
06/19/2006
HT
3/15/2007
SB
UPDATE TEMPERATURE TO 150 C FOR 'G' MTL,
CORRECT NOTE 6 & 7, ADD NEW TERMINATION
TYPE AI, AJ, AK, FF, FG,FH, FI, FJ, ZB, ZI, ZJ,
ZO, ZQ, ZR, COMBINED 'P' MTL IN P/N CODING
(DWG 10726, 10167 OBSOLETED)
11/12/2009
JH
9/8/2011
JH
1/24/2014
JHSU
UPDATE PROCESSING TIME FOR 'G' MTL,
VOLTAGE RATING, REMOVE MOISTURE NOTE,
PROCESSING TEMP FOR 'P' MTL
ADD PLATING OPTIONS, UPDATE BODY SHAPE, ADD
HIGH TEMP MATERIALS
F
E
E
D
D
.200 5.08
.100 2.54 , TYP.
B
A
C
.050 1.27
C
A
HEAD
.100 2.54
TAIL
B
A
__C__D__N
_ _ C _ _ D _ _ N-M500
.100 2.54
ROW SPACING
STRAIGHT
A
SECTION A-A
CUSTOMER COPY
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING
2. CONTACT MATERIAL: SEE PART NUMBER CODING
3. PLATING: SEE PART NUMBER CODING
4. UL FLAMMABILITY RATING: 94V-0
5. DIELECTRIC WITHSTANDING VOLTAGE: 1800 VAC
6. CURRENT RATING: 3 AMPS
7. CONTACT RESISTANCE: 30 MILLIOHMS MAX.
8. INSULATION RESISTANCE: 5000 MEGOHMS MIN.
8
7
B
.025 0.64
FITS
.040 MIN. HOLE
Pb
RoHS COMPLIANT
6
5
4
UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME
DIMENSIONS ARE IN INCHES [MM]
9/8/2011 JH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
PART NUMBER
SIZE
C
2
_ _C_ _D_ _N - (M500)
CAGE CODE
54453
SCALE: 4:1
3
A
.100" MALE HEADER, STRAIGHT
DWG. NO.
C10419
SHEET 1 OF 1
1
REV
G
FILE NAME: C10419, _ _C_ _D_ _N-OMIT, M500, STRAIGHT
很抱歉,暂时无法提供与“YMC36DAAN”相匹配的价格&库存,您可以联系我们找货
