EGG.3B.304.CLL
EGG.3B.304.CLL
    LEMO(雷莫)
    EGG.3B.304.CLL
EGG.3B.304.CLL 数据手册
EGG.3B.304.CLL www.lemo.com SUMMARY # Wires Low voltage 4 Image is for illustrative purpose only Series 3B Termination type Female solder IP rating 50 AWG wire size 22.00 - 14.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts FGG.3B.304.CLAD92 Download Request a quote Eplan Catalog TECHNICAL DETAILS Mechanics Shell Style/Model EG*: Fixed receptacle, nut fixing Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 26.43 g Performance Configuration 3B.304 : 4 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 19 Amps Specifications Contact Type: Solder Contact Dia.: 2 mm (0.079in) Bucket Dia.: 1.8 mm (0.071in) Max. Solid Conductor: 1.5 mm^2 (AWG 14) Max. Stranded Conductor: 1.5 mm^2 (AWG 16) R (max): 3.3 mOhm Vtest (contact-shell): 1250 V (AC), 1770 V (DC) Vtest (contact-contact): 1450 V (AC), 2050 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A B E L M N S1 S3 e mm. 22 25 11.5 30.7 2 28.1 16.5 22 M18x1.0 in. 0,87 0,98 0,45 1,21 0,08 1,11 0,65 0,87 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables CMN.04.T14.083PGZE Grey CMN.04.T14.083PNZE CMN.04.T20.053PGZE Grey CMN.04.T20.053PNZE CMN.04.T20.053QGZE TPR (medical) Grey CMN.04.T22.047QGC TPR Grey CMN.04.T22.048QGZE TPR (medical) Grey CMN.04.T28.031PGCE PVC GREY CMN.04.T28.031PGZE CMN.04.T28.031PNCE Grey PVC Black CMN.04.T28.031QGC TPR Grey 140240 PVC Black 140250 PVC Grey 240500 PVC Grey 240750 PVC Grey 340 150 PVC Grey 40080 PVC Black 40086 PVC Blue 40140 PVC Black 40240 PTFE White 40260 PVC Black 4041 PVC Grey 4050 PVC Black 4080 PVC Grey 417920 PVC Grey 4220 PVC Black 4221 PVC Black 4260 PTFE White 4280 PVC Black 80080 PVC Grey 80082 PVC Red 80084 PVC Black CTR.75.030.121870G PVC Grey CMN.04.T28.031PNZE LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
EGG.3B.304.CLL
物料型号: LEMO EGG.3B.304.CLL
器件简介: - 系列: 3B - 端接类型: 女性焊锡 - IP等级: 50 - 线规: AWG 22.00 - 14.00 - 状态: 活跃 - 匹配部件: FGG.3B.304.CLAD92
引脚分配: - 3B.304: 4个低压引脚
参数特性: - 壳体样式/型号: EG: 固定式插座,螺母固定 - 键槽: 1个键槽(alpha=0,插头:男性接触件,插座:女性接触件) - 壳体材料: 黄铜(铬镀[SAE AMS 2460])壳体和螺母,镍镀[SAE AMS QQ N 290]黄铜拉杆套和中间件 - 重量: 26.43克 - 额定电流: 19安培 - 接触类型: 焊锡 - 接触直径: 2毫米(0.079英寸) - 桶直径: 1.8毫米(0.071英寸) - 最大实心导体: 1.5 mm²(AWG 14) - 最大绞合导体: 1.5 mm²(AWG 16) - 最大电阻: 3.3毫欧姆 - 接触-壳体电压测试: 1250 V(交流),1770 V(直流) - 接触-接触电压测试: 1450 V(交流),2050 V(直流)
功能详解: - 耐久性(壳体): 5000次 - 温度范围(最小/最大): -55°C / +250°C - 湿度(最大): <=95% [在60°C/140°F时] - 振动: 15 g [10 Hz - 2000 Hz] - 抗冲击性: 100 g [6 ms] - 气候类别: 50/175/21 - 屏蔽(最小): 75 dB(10 MHz),40 dB(1 GHz) - 盐雾腐蚀: >1000小时
应用信息: - 推荐工具和电缆型号列表,包括不同颜色和材料的电缆。
封装信息: - 提供了详细的尺寸图和推荐的工具。
EGG.3B.304.CLL 价格&库存
很抱歉,暂时无法提供与“EGG.3B.304.CLL”相匹配的价格&库存,您可以联系我们找货
