PR20C03HBDN
PR20C03HBDN
    METZCONNECT
    弯插,P=2mm
    排针 间距:2mm 2x3P 弯插
PR20C03HBDN 数据手册
Page 1/4 Data sheet P/N PR20CXXHBDN xx=number of poles PR20CxxHBDN 2021/09/15 Version: S Illustrations Dimensional drawing Drill pattern See enlarged drawings at the end of document Product specification • pin header, THR solderable • centerline 2.00 mm, direction of connection 90° • color black • Tape & Reel packaging possible • dual rows Data sheet Page 2/4 PR20CxxHBDN P/N PR20CXXHBDN xx=number of poles 2021/09/15 Version: S Technical Data General Data min. number of poles max. number of poles 2 Insulating material class CTI 450 clearance/creepage dist. 1.5 mm Protection category IP00 Rated current 1A 40 Material insulating material PE-HT contact pin material CuZnPb contact pin surface Ni + Au Flash Glow-Wire Flammability GWFI - Glow-Wire Flammability GWIT - Climatic Data upper limit temperature 105 °C lower limit temperature -55 °C general Tolerance ISO 2768 -mH Solderability Acc. to IPC/JEDEC J-STD-020D-MSL 1 Data sheet PR20CxxHBDN Page 3/4 P/N PR20CXXHBDN xx=number of poles 2021/09/15 Version: S Illustrations Dimensional drawing L=(pole size - 1) x centerline + 2 mm [0.079] Data sheet PR20CxxHBDN Page 4/4 P/N PR20CXXHBDN xx=number of poles 2021/09/15 Version: S Illustrations Drill pattern Powered by TCPDF (www.tcpdf.org)
PR20C03HBDN 价格&库存
很抱歉,暂时无法提供与“PR20C03HBDN”相匹配的价格&库存,您可以联系我们找货
PR20C03HBDN
  • 1+2.301501+0.29776
  • 10+1.9568110+0.25317
  • 100+1.66511100+0.21543
  • 500+1.48598500+0.19225
  • 1000+1.414891000+0.18306
  • 5000+1.262935000+0.16340
  • 10000+1.2026410000+0.15560
库存:2333
