FGG.0B.307.CLAZ
www.lemo.com
SUMMARY
# Wires
Low
7
High
Coax
Triax
Quad
Fiber
Fluidic
Series
0B
Termination type
Male solder
IP rating
50
Cable Ø
0.00 - 0.00 mm
Status
active
Image is for illustrative purpose only
Download
Request a quote
Catalog
See video assembly instructions
Alternative part
Matching parts
EGG.0B.307.CLL
PHG.0B.307.CLLZ
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FG*: Straight plug, cable collet
Keying
1 key (alpha=0, plug: male contacts, receptacle: female contacts)
Housing Material
Brass (chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces
Variant
Weight
7.87 g
Performance
Configuration
0B.307 : 7 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/3.2, depends on material thickness)
Rated Current
2.5 Amps
Specifications
Contact Type: Solder
Contact Dia.: 0.5 mm (0.02in)
Bucket Dia.: 0.45 mm (0.018in)
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Max. Solid Conductor: 0.09 mm^2 (AWG 28)
Max. Stranded Conductor: 0.09 mm^2 (AWG 28)
R (max): 8.7 mOhm
Vtest (contact-shell): 700 V (AC), 990 V (DC)
Vtest (contact-contact): 800 V (AC), 1130 V (DC)
Others
Endurance (Shell): 5000
Temp (min / max): -55°C / +250°C
Humidity (max): 1000 hr
IP Rating: 50
DRAWINGS
Draws
Dimensions
A
L
M
S1
S2
mm.
9.5
36
26
8
7
in.
0,37
1,42
1,02
0,31
0,28
2/3
RECOMMENDED BY LEMO
Tools
Spanner wrench: DCD.0B.005.PA070
Caps: BFG.0B.100.PCSG
Cables
3/3
很抱歉,暂时无法提供与“FGG.0B.307.CLAZ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+275.162931+34.14107
- 10+265.5059810+32.94287
- 25+248.0956925+30.78268
- 50+232.8315050+28.88876
- 国内价格 香港价格
- 1+313.865801+38.94316
- 10+274.8591910+34.10338
- 25+262.9799425+32.62945
- 50+254.4958050+31.57677
- 100+246.01341100+30.52432
- 250+232.43992250+28.84017
