a
Switchcraft
Made in USA
co.
INTRODUCING THE SHIELDED MINI-CON-X® CONNECTOR
Features and Benefits
Complete replacement for MINI-CON-X®
Panels are factory assembled and sealed
Scoop-proof connector design
Anti-slip machined nut standard on panel connectors
Precision machined housings
Two shell sizes & multiple keying arrangements
Mated Cable End
and Panel Mount
Product Specifications
Materials
Panel Shell, Cable Housing & Coupling Nuts:
Nickel plated copper alloy
All Connector Inserts: Engineered Polyester Resin
Contacts: Gold plated copper alloy with nickel underplate
Backshell & Strap: G.F. Nylon
O-Rings: Neoprene
Screws: Stainless Steel
Mechanical
Shock: Method 213, Mil-Std 202
Vibration: Method 201, Mil-Std 202
Life: 400 insertion/withdrawl cycles
Electrical
Voltage Rating: Tested at 600 VRMS
Insulation Resistance: Method 302, Mil-Std 202
Contact Resistance: Method 307, Mil-Std 202
Current Ratings:
13A: 4 maximum #16 contact with 16 AWG
7.5A: 3 maximum #20 contacts with 20 AWG
5.6A: 12 maximum #20 contacts with 20 AWG
Environmental
Temperature Rating: -40°C (-40°F) to +120°C (+248°F)
Temperature Rise: UL 1054
Thermal Shock: Method 107, Mil-Std 202
Moisture/Salt Spray: Method 106F / 101 Mil-Std 202
Cable End
Epoxy Sealed
Panel Mount
Product Ratings
IP66 / IP68 (when mated)
RoHS Compliant
www.conxall.com
601 E. Wildwood Avenue - Villa Park, IL 60181
Phone (630) 834-7504 / Fax (630) 834-8540
Product Bulletin C703
2
C703
Shielded MINI-CON-X® Connector
&DEOH(QG
>PP@
>PP@
>PP@
3DQHO0RXQW
>PP@
>PP@
>PP@
>PP@
>PP@
>PP@
&XWRXW
>PP@
)URQW9LHZ
WR3$1(/
>PPPP@
3DQHO0RXQW
3&WDLOFRQWDFWV
3DQHO0RXQW
6ROGHUFXSFRQWDFWV
5(&200(1'('
3$1(/&87287
>PP@
&RQWDFW$UUDQJHPHQWV :LULQJ9LHZRI&DEOH(QG
DOWHUQDWH
DOWHUQDWH
&RQVXOW)DFWRU\
&RGH/RJLF
6) ; ; ;;
%DFNVKHOODQG3DQHOV
(63DQHOZ(SR[\
%DFNVKHOOZ*URPPHW,'
%DFNVKHOOZ*URPPHW,'
6KLHOG ) LHOG
,QVWDOODEOH
&RQQHFWRU7\SH
&DEOH(QG
3DQHO0RXQW
&RQWDFW3ODWLQJ
* *ROG
&RQWDFW7\SH
33LQ
6 6RFNHW
&RQWDFW6L]H
&RQWDFW6W\OH
3&7DLO3DQHO2QO\
6ROGHU&XS
RI&RQWDFWV
IRU$:*
IRU$:*
1RWH&RQVXOW)DFWRU\IRUFRQQHFWRUV
ZLWKDOWHUQDWH$:*DQG$:*
FRQWDFWDUUDQJHPHQWV
www.conxall.com
很抱歉,暂时无法提供与“SF6382-5SG-520”相匹配的价格&库存,您可以联系我们找货
