DF20F-20DP-1V(59)
DF20F-20DP-1V(59)
    HRS(广濑)
    SMD
    CONN HEADER SMD 20POS 1MM
DF20F-20DP-1V(59) 数据手册
NEW 1 mm Pitch Double Rows Low Profile Board-to-Cable Connectors DF20 series Cable 5.4 Socket DF20A**DS-1C DF20F(G)**DP-1V 5.8 Pin Header PCB Cable 6.2 DF20F **DP-1H Pin Header 5.5 DF20A**DS-1C Socket PCB ■Features Narrower external width and length 1. Contact Pitch 1 mm contact pitch allows reliable solder and cable termination. 2. Low profile Total mating height above the board is 5.8 mm for the straight type and 5.5 mm for the right angle type. 3. Reliable electrical connection wipe Effective electrical connection is assured with a 1mm wipe of mating contacts. 4. Narrower external width and length Redesigned metal fittings decreased the overall length of the board- mount receptacle and permit end-to-end mounting of several connectors. Metal fitting 5. Automatic equipment board placement Straight type pin headers are supplied with a 5.4 mm X 4.6mm flat platform to allow vacuum pick-up and placement on the board. 6. Product variations (1) Available with 10, 20, 30, 40, and 50 contacts. (2) Pin headers are available in two types: with or without board positioning bosses. (3) Depending on specific application pin headers can be ordered in straight or right angle types. DF20F-****SCFA Contact ■Applications DF20F(G)-**DP-1V Pin Header 1 Notebook PC, small office automation equipment, small consumer devices, portable devices. Any application requiring low profile reliable board-to-cable connection with a AWG #28, AWG#30, AWG#32 conductors. DF20A-**DS-1C Socket 1mm Pitch, Double Rows 2002.5 1 ■Product Specifications AWG#28 : 1A Operating temperature range -35°C to 85°C (Note 1,2) Storage temperature range -10°C to 60°C (Note 2) AWG#30 : 0.9A AWG#32 : 0.7A Storage humidity range -40% to 70% Rated voltage Operating humidity range -20% to 80% 100V AC Rated current Rating Item Specifications 1.Insulation resistance Conditions Measured at 100V DC 500Mø min. 2.Withstanding voltage No flashover or insulation breakdown Conduction of 300V AC applied for 1 minute 3.Contact resistance Measure at 100mA. 30mø max. 4.Insertion-Extraction force Min. 0.2 N (20 gf), Max. 2 N (200 gf) 4.(per contact) Measured with a steel pin of 0.2 ±0.005 thickness 5.Vibration No electrical discontinuity of 1µs min. Frequency of 10 to 55 Hz, single amplitude of 0.75 mm, in 3 directions for 2hours 6.Humidity Contact resistance of 30mø max., insulation resistance of 100Mø min. Temperature of 40±2ç, humidity of 90% to 95%, left standing for 96 hours 7.Temperature cycle Contact resistance of 30mø max,insulation resistance of 500Mø min. (-55ç:30min / 5ç to 35ç: 2 to 3min / 85ç:30min / 5ç to 35ç:2 to 3min ) for 5 cycles 8.Mechanical operation Contact resistance of 30mø max. 50 cycles 9.Resistance to Soldering heat Reflow: At the recommended temperature profile, manual solder: Soldering iron temperature of 300°C for 3 seconds No deformation of the insulator parts that will affect performance Note1: Includes temperature rise caused by current flow. Note2: The term “storage” refers to products stored for long periods of time prior to mounting and use. Note2: Operating temperature range and Humidity range covers non-conducting conditions of installed connectors in storage, Note2: shipment or transportation. ■Materials Item Part Socket Socket contact Pin header Material Finish Remarks Insulator Polyamide Color : Beige UL94V-0 Contact Phosphor bronze Gold plating ---------- Insulator Polyamide Color : Beige UL94V-0 Contact Phosphor bronze Gold plating ---------- Metal Fitting Brass V type: Solder plating H type: Tin-Copper plating (Pb free) ■Ordering Information ●Connectors DF 20 # - * DS - 1 C 1 2 3 4 5 1 Series name : DF 2 Series No. : 20 3 Boss Type ■Pin header ■F: Without boss ■G: With boss ■Crimp socket: A 4 Number of contacts: 10, 20, 30, 40, 50 ●Contacts 7 5 Connector type DS: Double-row socket DP: Double-row pin header 6 Contact pitch: 1 mm 7 Type of housing, header 7 C: Crimp housing V: Straight SMT header H: Right angle SMT header DF20 F - 2830 SCF A 1 1 F 2 Applicable wire size 2830: AWG #28 to 30 3032: AWG #30 to 32 2 6 2 3 4 3 Contact & packaging type SCF: Socket contact reel 4 Plating type A: Gold plating (* *) 5 5 Packaging Specifications Blank: 1 reel = 10,000 pieces 41: 1 reel = 20,000 pieces ■Double Row Socket Contact No. * Contact No. 2 Contact No. *-1 Contact No. 1 5th contact marking Contact No. 1 mark Shown with terminated and installed contacts Unit: mm B Product No. CL No. Number of Contacts A DF20A-10DS-1C 686-0020-3 10 17.2 14.0 DF20A-20DS-1C 686-0021-6 20 12.2 19.0 DF20A-30DS-1C 686-0022-9 30 17.2 14.0 DF20A-40DS-1C 686-0023-1 40 22.2 19.0 DF20A-50DS-1C 686-0024-4 50 27.2 24.0 [Specifications number]-*, (**) (59): Gold plating, embossed tape packaging Note: Sales quantities are by the package unit (containing 100 pieces). Please order by package unit. ■Socket Crimp Contacts Product No. DF20F-2830SCFA(**) DF20F-3032SCFA(**) CL No. 686-0042-6-** 686-0043-9-** Type of contacts Quantity Plating type Reel contacts See specifications number column Gold plating [Specifications number] -*, (**) Blank 1 reel : 10,000 pieces 41 1 reel : 20,000 pieces 1.45 0.7 ●Applicable Wire (Tin plated solid soft conductor) Applicable Wire Size (Stranded wire conductor) Jacket diameter 0.5mm to 0.6 mm AWG #30 (7/0.1 mm) 2 AWG #32 (7/0.08 mm) 0.9 3.3 AWG #28 (7/0.127 mm) ●Strip length ●1.2 to 1.9 mm 0.5 ●Recommended wire ●UL1571 Note: When using other than the recommended wire, contact your nearest Hirose representative. ●Applicable Crimping Tools Type CL No. Product No. Applicator 901-4572-6 AP105-DF20-2830S Press 901-0005-4 CM-105 Manual crimping tool 901-4540-6 HT302/DF20B-2830S Note 1: Hirose Electric will not be responsible for any problems caused by use of tools other than specified. Note 2: The manual crimping tool can be also used for cutting-off individual contacts from the reel. Note 3: Customers that already have DF13 Series Hirose’s press units and applicators will be able to use them for DF20 Series crimp terminations by replacing of only crimper and anvil. Note4: The crimping tool for the DF20F-3032SCFA can also be used with the DF20F-2830SCFA. ■Replacement Parts List for Applicator Type Product No. CL No. Insulation crimper AP105-DF20-2830S(61) 901-4572-6-61 Wire crimper AP105-DF20-2830S(62) 901-4572-6-62 Insulation anvil and wire anvil AP105-DF20-2830S(63) 901-4572-6-63 3 ■ Double Row Straight Pin header B A Contact No.3 P=1 Contact No.1 Contact No. **-1 ** Indication of number of contacts Contact No. ** 6.4 Contact No.2 0.2 0.7 4.6 5.4 Ø0.5 1.9 C D A 0.2 BPCB Footprints A ±0.05 P=1±0.03 Contact No. 1 marking 0.9±0.05 0.85±0.1 4±0.1 D±0.05 .1 +0 0 .7 Ø0 1.9±0.05 7.2 ±0.1 1.8 ±0.1 0.5±0.05 0.6±0.05 Note 1:Shaded area must be free of any electrically conductive traces to avoid contact with soldered pin header terminations. Note 2: Required only for pin headers supplied with the positioning boss. Unit: mm Product No. CL No. Number of contacts A B C D DF20F-10DP-1V ( * * ) CL686-0032-2- * * 10 14.0 17.3 ----- 15.7 DF20F-20DP-1V ( * * ) CL686-0033-5- * * 20 19.0 12.3 ----- 10.7 DF20F-30DP-1V ( * * ) CL686-0034-8- * * 30 14.0 17.3 ----- 15.7 DF20F-40DP-1V ( * * ) CL686-0035-0- * * 40 19.0 22.3 ----- 20.7 DF20F-50DP-1V ( * * ) CL686-0036-3- * * 50 24.0 27.3 ----- 25.7 DF20G-10DP-1V ( * * ) CL686-0037-6- * * 10 14.0 17.3 16.6 15.7 DF20G-20DP-1V ( * * ) CL686-0038-9- * * 20 19.0 12.3 11.6 10.7 DF20G-30DP-1V ( * * ) CL686-0039-1- * * 30 14.0 17.3 16.6 15.7 DF20G-40DP-1V ( * * ) CL686-0040-0- * * 40 19.0 22.3 21.6 20.7 DF20G-50DP-1V ( * * ) CL686-0041-3- * * 50 24.0 27.3 26.6 Note1: Order embossed tape packaging items by the reel. (1 reel contains 1,000 pieces) Note2: Vacuum pick-up platforms are included with embossed tape packaged connectors. 4 Remarks Without boss With boss 25.7 [Specifications number]-*, (**) (59): Gold plating, embossed tape packaging ■Double Row Right angle Pin header Contact No.1 Contact No.**-1 Contact No.3 Contact No.1 marking Contact No.** Contact No.2 B ** A 5 5.5 Indication of number of contacts P= 1 0.2 A 0.2 6.2 C 1.4 +0.1 0 +0.1 0 2.45 2.75 ±0.05 3.8 ±0.05 1.4 +0.1 0 BPCB Footprints 0.6 ±0.05 P= 1 ±0.03 A ±0.05 0.75 ±0.1 C ±0.1 Note : Shaded area must be free of any electrically conductive traces to avoid contact with soldered pin header terminations. Unit: mm Product No. HRS No. Number of contacts A B C DF20F -10DP-1H ( * * ) 686-0027-2 ( * * ) 10 24.0 27.5 26.2 DF20F -20DP-1H ( * * ) 686-0028-5 ( * * ) 20 29.0 12.5 11.2 DF20F -30DP-1H ( * * ) 686-0029-8 ( * * ) 30 14.0 17.5 16.2 DF20F -40DP-1H ( * * ) Reserved for product expansion 40 19.0 22.5 21.2 DF20F -50DP-1H ( * * ) Reserved for product expansion 50 24.0 27.5 26.2 Remarks Without boss [Specifications number]-*, (**) (59): Gold plating, embossed tape packaging Note:Order embossed tape packaging items by the reel. (1 reel contains 1,000 pieces) 5 BEmbossed Carrier Tape Dimensions ●Straight pin header Ø1 12 ±0.1 +0 0 .1 0.2±0.05 A ±0.3 R0. 7 5 1.7 +0.15 0 B ±0.1 C ±0.1 .5 1.75±0.1 2 ±0.1 4 ±0.1 1.5 0.4 +0.1 0 Unreeling direction 7.9 2±0.1 12±0.1 4±0.1 0.2±0.05 A ±0.3 R0 .75 1.7 +0.15 0 B ±0.1 C ±0.1 .1 +0 0 .5 Ø1 1.75 ±0.1 ●Right angle pin header 0.4 1.5 +0.1 0 (7.4) Unreeling direction ●Reel dimensions D ------ 17.5 16.4 DF20F(G)-20DP-1V 20 24 ------ 11.5 24.4 DF20F(G)-30DP-1V 30 32 28.4 14.2 32.4 DF20F(G)-40DP-1V 40 44 40.4 20.2 44.4 DF20F(G)-50DP-1V 50 44 40.4 20.2 44.4 DF20F-10DP-1H 10 16 ------ 17.5 16.4 DF20F-20DP-1H 20 24 ------ 11.5 24.4 DF20F-30DP-1H 30 32 28.4 14.2 32.4 * DF20F-40DP-1H 40 44 40.4 20.2 44.4 * DF20F-50DP-1H 50 44 40.4 20.2 44.4 * Reserved for product expansion 6 2 ±0.5 Product name label Ø1.5 mm diameter feed hole depth Ø21 ± 0.8 Ø380 ±2 C 16 (Ø80) B 10 .2 A DF20F(G)-10DP-1V ±0 Number of Contacts Ø1 3 Product No. 2 ±0.5 D +2 0 BUsage recommendation 1. Recommended Soldering Temperature Profile for IR Reflow. Temperature IR Reflow Preheating: 150°C for 60 sec. to 120 sec. Soldering: 235°C±5°C for 10 sec. max. ... Maximum 240°C 220°C min. 10s to 30s ... 220°C Preheating Maximum 240°C 220°C Soldering Note 1: Up to 2 cycles of reflow soldering are possible under the same conditions, provided that there is a return to normal temperature between the first and second cycle. Note 2: The temperature indicates the board surface temperature at the points of contacts with the connector terminals. 2.Recommended Manual Soldering Conditions Soldering temperature: 290°C ±10°C, Soldering time: within 3 sec. 3. Recommended Solder Screen Thickness 0.15mm 4. Board Warping Maximum of 0.03 mm at the connector center section, with both ends of the connector as reference points. 5. Cleaning Conditions Refer to "Nylon Connector Use Handbook." 6. Wiring Termination Conditions Refer to "Nylon Connector Use Handbook." Crimp contacts should be handled with care as not to cause any deformation or damage affecting the performance or termination. 7. Mating / un-mating precautions Excessive twisting and pulling on wires during mating/un-mating should be avoided as it may cause damage to connectors. 7
DF20F-20DP-1V(59) 价格&库存
很抱歉,暂时无法提供与“DF20F-20DP-1V(59)”相匹配的价格&库存,您可以联系我们找货
