FGG.1B.306.CLAZ
www.lemo.com
SUMMARY
# Wires
Low
6
High
Coax
Triax
Quad
Fiber
Fluidic
Series
1B
Termination type
Male solder
IP rating
50
Cable Ø
0.00 - 0.00 mm
Status
active
Image is for illustrative purpose only
Download
Request a quote
Catalog
See video assembly instructions
Alternative part
Matching parts
EGG.1B.306.CLL
PHG.1B.306.CLLZ
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FG*: Straight plug, cable collet
Keying
1 key (alpha=0, plug: male contacts, receptacle: female contacts)
Housing Material
Brass (chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces
Variant
Weight
13.85 g
Performance
Configuration
1B.306 : 6 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/3.2, depends on material thickness)
Rated Current
7 Amps
Specifications
Contact Type: Solder
Contact Dia.: 0.7 mm (0.028in)
Bucket Dia.: 0.8 mm (0.031in)
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Max. Stranded Conductor: 0.34 mm^2 (AWG 22)
Max. Conductor: 0.34 mm^2 (AWG 22)
R (max): 6.1 mOhm
Vtest (contact-shell): 1200 V (AC), 1700 V (DC)
Vtest (contact-contact): 1050 V (AC), 1490 V (DC)
Others
Endurance (Shell): 5000
Temp (min / max): -55°C / +250°C
Humidity (max): 1000 hr
IP Rating: 50
DRAWINGS
Draws
Dimensions
A
L
M
S1
S2
mm.
12
43
32
10
9
in.
0,47
1,69
1,26
0,39
0,35
2/3
RECOMMENDED BY LEMO
Tools
Spanner wrench: DCD.1B.015.PA090
Caps: BFG.1B.100.PCSG
Cables
3/3
很抱歉,暂时无法提供与“FGG.1B.306.CLAZ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+332.861691+41.30009
- 10+291.4898810+36.16685
- 25+278.8993225+34.60466
- 50+269.9010550+33.48819
- 100+260.90433100+32.37192
- 250+246.50959250+30.58588
- 国内价格 香港价格
- 1+291.854901+36.21214
- 10+281.6095110+34.94093
- 25+263.1436625+32.64977
- 50+246.9534950+30.64096
- 100+232.63248100+28.86407
