ECG.1B.303.CLL
ECG.1B.303.CLL
    LEMO(雷莫)
    CONN RCPT FMALE 3P GOLD SLDR CUP
ECG.1B.303.CLL 数据手册
ECG.1B.303.CLL www.lemo.com SUMMARY # Wires Low voltage 3 Image is for illustrative purpose only Series 1B Termination type Female solder IP rating 50 AWG wire size 28.00 - 20.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts FGG.1B.303.CLAD62 Download Request a quote Eplan Catalog TECHNICAL DETAILS Mechanics Shell Style/Model EC*: Fixed receptacle with two nuts (back panel mounting) Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 10.57 g Performance Configuration 1B.303 : 3 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 12 Amps Specifications Contact Type: Solder Contact Dia.: 1.3 mm (0.051in) Bucket Dia.: 1 mm (0.039in) Max. Solid Conductor: 0.5 mm^2 (AWG 20) Max. Stranded Conductor: 0.5 mm^2 (AWG 20) R (max): 3.6 mOhm Vtest (contact-shell): 1550 V (AC), 2200 V (DC) Vtest (contact-contact): 1300 V (AC), 1840 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A B E L M N S1 S3 e mm. 16 15.8 6 23 3.5 21.1 10.5 14 M12x1.0 in. 0,63 0,62 0,24 0,91 0,14 0,83 0,41 0,55 RECOMMENDED BY LEMO Tools Spanner 2: DCH.91.161.PA LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables CMN.03.T20.049PGZE Grey CMN.03.T20.049PNZE CMN.03.T28.031PGCE PVC CMN.03.T28.031PGZE CMN.03.T28.031PNCE GREY Grey PVC Black 130240 PVC Black 130250 PVC Grey 230500 PVC Grey 230750 PVC Grey 30110 PVC Grey 30141 PVC Grey 30260 PVC Black 3041 PVC Grey 3050 PVC Black 3081 PVC Black 3220 PVC Black 3280 PVC Black 60080 PVC Grey CMN.03.T28.031PNZE LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
ECG.1B.303.CLL 价格&库存
很抱歉,暂时无法提供与“ECG.1B.303.CLL”相匹配的价格&库存,您可以联系我们找货
ECG.1B.303.CLL
  • 1+325.408811+41.95148
ECG.1B.303.CLL
    库存:20
