FGG.0B.306.CLAD52
www.lemo.com
SUMMARY
# Wires
Low voltage
6
Image is for illustrative purpose only
Series
0B
Termination type
Male solder
IP rating
50
AWG wire size
34.00 - 28.00
Catalog
Cable Ø
4.30 - 5.20 mm
See video assembly instructions
Status
active
Matching parts
EGG.0B.306.CLL
Download
Request a quote
Eplan
PHG.0B.306.CLLD52
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FG*: Straight plug, cable collet
Keying
1 key (alpha=0, plug: male contacts, receptacle: female contacts)
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
8.38 g
Performance
Configuration
0B.306 : 6 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
2.5 Amps
Specifications
Contact Type: Solder
Contact Dia.: 0.5 mm (0.02in)
Bucket Dia.: 0.45 mm (0.018in)
Max. Solid Conductor: 0.09 mm^2 (AWG 28)
Max. Stranded Conductor: 0.09 mm^2 (AWG 28)
R (max): 8.7 mOhm
Vtest (contact-shell): 650 V (AC), 920 V (DC)
Vtest (contact-contact): 850 V (AC), 1200 V (DC)
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Others
Endurance (Shell): 5000
Temp (min / max): -55°C / +250°C
Humidity (max): 1000 hr
DRAWINGS
Dimensions
A
L
M
S1
S2
mm.
9.5
36
26
8
7
in.
0,37
1,42
1,02
0,31
0,28
RECOMMENDED BY LEMO
Tools
Spanner wrench:
DCD.0B.005.PA070
Caps:
BFG.0B.100.PCSG
2/3
Cables
CMN.06.T28.044PGZE
Grey
CMN.06.T28.044PNZE
6280
PVC
Black
3/3
很抱歉,暂时无法提供与“FGG.0B.306.CLAD52”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+270.449191+34.66424
