RKC 40/16
RKC 40/16
    BELDEN
    CONN PLUG FMALE 4POS GOLD SCREW
RKC 40/16 数据手册
Mini, 7/8" Field Attachable Connectors Male, 3-, 4-, and 5-Pole Field attachable connector, Mini, 7/8" male connector 3-, 4-, and 5-pole with threaded joint, assembling with screw terminals. RSC 30-RSC 50 | RKC 30-RKC 50 RSC 30-RSC 50 Female, 3-, 4-, and 5-Pole Field attachable connector, Mini, 7/8" female connector 3-, 4-, and 5-pole with threaded joint, assembling with screw terminals. RKC 30-RKC 50 Pin Assignments Mini, 7/8" - Male / Female 3 poles Data sheet | 08/19/16 4 poles 5 poles 1.800.Belden1 www.lumberg-automationusa.com Technical| Support: 1-717-217-2289 www.lumberg-automationusa.com Be Certain with Belden Mini, 7/8" Field Attachable Connectors RSC 30-RSC 50 | RKC 30-RKC 50 Technical Data Environmental Degree of protection Operating temperature range IP 67 / NEMA 6P -40°C (-40°F) / +90°C (+194°F) Mechanical Housing / Molded body Insert Contact Coupling nut O-ring Mode of connection Connectable conductor PA TPU, self-extinguishing CuZn, gold over nickel plated Al anodized NBR screw terminals max. 1.5 mm2 Electrical Contact resistance ≤ 5 mΩ Nominal current at 40°C 3 poles 12 A 4–5 poles 9 A Nominal voltage 240 V Rated voltage 250 V Test voltage 3 poles 2.5 kV eff. / 60 s 4–5 poles 1.5 kV eff. / 60 s Insulation resistance > 109 Ω Pollution degree 3 Part Number Pins Cable Diameter Range Male Female RSC 30/9 RKC 30/9 RSC 30/11 RKC 30/11 Ø 8.0 - 10.0 mm RSC 30/13.5 RKC 30/13.5 Ø 10 - 12.0 mm RSC 30/16 RKC 30/16 Ø 12 - 14.0 mm RSC 40/9 RKC 40/9 RSC 40/11 RKC 40/11 Ø 8.0 - 10.0 mm RSC 40/13.5 RKC 40/13.5 Ø 10 - 12.0 mm RSC 40/16 RKC 40/16 Ø 12 - 14.0 mm RSC 50/9 RKC 50/9 RSC 50/11 RKC 50/11 Ø 8.0 - 10.0 mm RSC 50/13.5 RKC 50/13.5 Ø 10.0 - 12.0 mm RSC 50/16 RKC 50/16 Ø 12.0 - 14.0 mm www.lumberg-automationusa.com 3 4 5 Characteristics Ø 6.0 - 8.0 mm Ø 6.0 - 8.0 mm Ø 6.0 - 8.0 mm 1.800.Belden1Technical | www.lumberg-automationusa.com Support: 1-717-217-2289 Data sheet | 08/19/16
RKC 40/16 价格&库存
很抱歉,暂时无法提供与“RKC 40/16”相匹配的价格&库存,您可以联系我们找货
