JDXER2T003FSN
JDXER2T003FSN
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    CONN RCPT FMALE 9P GOLD SLDR CUP
JDXER2T003FSN 数据手册
JDX Hybrid Mixed Power & Signal Mixed PowerBackshell and SignalFire Waterproof Connector Integrated proof Connector The JDX mixed power and signal connector offers the ability to integrate 2 or 3 power contacts with 6 to 8 signal contacts in one connector housing Mixed power & signal layout Secure for Outdoor applications Quick Release Breakaway Coupler Single Connector Solution for simplified cabling Waterproof, IP68 (Mated and Unmated) Disengages at specified pull force levels for safe quick disconnects Rugged Robust to withstand Harshest Environments Flexible 3 Layouts Available for multiple applications Confirmed Mating Space Savings Shielding Audible, Tactile, Visual Small footprint, allows access in tight applications 360° EMI Shielding JDX Hybrid Mixed Power & Signal Description • Mixed power & signal rugged sealed connector for high vibration and shock environments for both indoor and outdoor applications • Waterproof, IP68 (Mated and Unmated) • Shell available in Brass and Lightweight Aluminum • Available in Shell Size 2 • 3 layouts for multiple applications - 2P + 6S (2 Power + 6 Signal) - 2P + 8S (2 Power + 8 Signal) - 3P + 6S (3 Power + 6 Signal) Applications • SOURIAU Sealed connectors can be used in a variety of markets including Industrial, Instrumentation, Medical, Mil-Aero, Broadcast Entertainment and Telecommunications. Technical Information Materials Electrical Environmental • Shell: Brass or Aluminum • Current Rating: see chart on Page 3 & 4 • Operating Temperature: -40°C to +125°C • Shell Plating: Black Chrome over Nickel • Contact Resistance: see chart on Page 4 • Salt Spray Resistance: 96 hours • Insulator: PEEK with15% Glass filled • Insulation Resistance: 500 MΩ • Sealing: IP68 (Mated & Unmated) • Contacts: Brass • Dielectric Withstanding Voltage: see chart on Page 4 • RoHS Compliant • Operating Voltage: see chart on Page 4 Mechanical • Contacts Plating: Gold over Nickel • Potting Seal: Epoxy Potting Compound • Endurance: Shell: 2500 mating/unmating Contacts: 1000 mating/unmating • Vibration: 10 - 2000 HZ (per EIA 364) • Shock: 50g duration 6ms (per MIL STD 1344A) • Autoclavable 2 JDX Hybrid Mixed Power & Signal Technical Information 2P + 6S Power Derating curve - Signal Contact Fixed at 2A Connector rating: Connector layout: (temperature °C) • Power Contact: 26A at 30˚C T-Rise • Signal Contact: 2A 140 Max temp use 120 Recommended use 100 80 60 40 20 0 0 5 10 15 20 25 30 35 40 45 Current for Power contact (A) Signal Contact (cable awg 26) is powered at 2A Power Contact (cable awg 16): 0 to 35 A 2P + 8S Power Derating curve - Signal Contact Fixed at 2A 140 Max temp use • Power Contact: 26A at 30˚C T-Rise • Signal Contact: 2A 120 Recommended use Connector layout: (temperature °C) Connector rating: 100 80 60 40 20 0 0 5 10 15 20 25 30 35 40 45 Current for Power Contact (A) Signal Contact (cable awg 26) is powered at 2A, Power Contact (cable awg 18): 0 to 40 A 3P + 6S Power Derating curve - Signal Contact Fixed at 2A 140 Max temp use • Power Contact: 17A at 30˚C T-Rise • Signal Contact: 2A 120 Recommended use Connector layout: (temperature °C) Connector rating: 100 80 60 40 20 0 0 5 10 15 20 25 30 Current for Power Contact (A) Signal Contact (cable awg 26) is powered at 2A, Power Contact (cable awg 20): 0 to 25 A 3 35 40 45 JDX Hybrid Mixed Power & Signal Contact Layouts & Technical Information Shell size 2 2P+6S 2P+8S 3P+6S Solder S S S PCB Straight Tails P P P Power contact diameter (mm) 2.0 1.6 1.3 Signal contact diameter (mm) 0.7 0.7 0.7 Power Solder wire Max. AWG 16 18 20 Signal Solder wire Max. AWG 26 26 26 Male Insulator Wire Side Contact Diameter (mm) Solder Wire Max. AWG Current Rating Power current rating See Derating Curve on page 3 Signal current rating See Derating Curve on page 3 Contact Resistance (mΩ) Power contact resistance (mΩ) 2.5 2.5 3 Signal contact resistance (mΩ) 5 5 5 1500 1500 1500 700/500 700/500 700/500 Dielectric Withstanding Voltage Operating Voltage (Vdc/Vrms) Contacts Solder contacts Contacts ØC ØF 0.7 Usable Cables Core section (mm²) Current Rating* (A) Contact Resistance (mΩ) AWG Power Contact Signal Contact Power Contact Signal Contact Endurance (Cycles) Min. Max. 0.7 - 0.3 26 - 2 - 5 1000 1.3 1.1 - 0.6 20 17 - 3.0 - 1000 1.6 1.5 - 0.93 18 26 - 2.5 - 1000 2.0 1.9 - 1.34 16 26 - 2.5 - 1000 *see chart on page 3 4 JDX Hybrid Mixed Power & Signal Keying Keying angles Key T U A B Plug & Receptacle Keying shells availability Shell Styles for Plugs & Receptacles (see page 8) Shell size 2 Key ED EP EE ER EZ IL FA FB FD T ● ● ● ● ● ● ● ● ● U ● ● ● ● ● ● ○ ● ● A ○ ○ ○ ○ ○ ○ ○ ○ ○ B ○ ○ ○ ○ ○ ○ ○ ○ ○ ● Available for JDX Series Keying color codes Keying Contacts Standard Gender Contacts Reverse Gender T Red Purple U White Yellow A Green Orange B Blue Light Brown 5 JDX Hybrid Mixed Power & Signal Part Numbers ² Existing Shell Style Part Numbers ER: Rear Panel Mount FD: Straight Cable Plug Please note: FD Straight Plug is supplied as overmolded cable assembly or as stand alone connector (strain relief boot not available for this product) For other shell styles & part numbers see shell styles on page 8 and part number configurator on page 9. Part Number Description Shell Style Shell Size Shell Type JDXFD2T001MSN 2 Power / 6 Signal (2P + 6S) FD 2 Plug JDXFD2T002MSN 2 Power / 8 Signal (2P + 8S) FD 2 Plug JDXFD2T003MSN 3 Power / 6 Signal (3P + 6S) FD 2 Plug JDXER2T001FSN 2 Power / 6 Signal (2P + 6S) ER 2 Receptacle JDXER2T002FSN 2 Power / 8 Signal (2P + 8S) ER 2 Receptacle JDXER2T003FSN 3 Power / 6 Signal (3P + 6S) ER 2 Receptacle 6 JDX Hybrid Mixed Power & Signal Dimensions ² 2P + 6S Plug Receptacle ² 2P + 8S Plug Receptacle 3P + 6S ² Receptacle Plug Panel cut-out Note: All dimensions are in millimeters (mm) 7 JDX Hybrid Mixed Power & Signal JDX Hybrid Shell Styles – Size 2 ² ² Receptacles EZ: Rear Panel Mount PCB Capable Protruding Front (With Grounding Pins) ER: Rear Panel Mount Plugs FD: Straight Cable Plug Mounting Plane Please Note: FD Straight Plug is supplied as overmolded cable assembly or as stand alone connector (strain relief boot not available for this product) ED: Rear Panel Mount PCB Capable EP: Front Panel Mount FA: Front Panel Mount Plug IL: In-Line Cable Receptacle FB: Rear Panel Mount Plug Please note: IL In-Line Cable Receptacle is supplied as overmolded cable assembly or as stand alone connector (strain relief boot not available for this product) Note: All dimensions are in millimeters (mm) (With Grounding Pins) EE: Rear Panel Mount PCB Capable Protruding Back (With Grounding Pins) Mounting Plane 8 (With Grounding Pins) JDX Hybrid Ordering Information BASIC SERIES JDX FD 2 T 001 Shells Type - Receptacle EP – Front Panel Mount ER – Rear Panel Mount EZ – Rear Panel Mount PCB Capable, Protruding Front (With Grounding Pins) ED – Rear Panel Mount PCB Capable (With Grounding Pins) EE – Rear Panel Mount PCB Capable, Protruding Back (With Grounding Pins) *IL – In-Line Cable Receptacle Shells Type - Plug *FD – Straight Cable Plug FA – Front Panel Mount Plug FB – Rear Panel Mount Plug (With Grounding Pins) Shell Size 2 Keying T - U - A - B (see page 5 for more keying details) Contact Layouts 001 - 2P + 6S (2 Power + 6 Signal) 002 - 2P + 8S (2 Power + 8 Signal) 003 - 3P + 6S (3 Power + 6 Signal) Contact Type M: Male F: Female Contact Termination S - Solder P - PCB Straight Surface Plating N: Non Reflective Black Chrome over Nickel S: Chrome over Nickel Shell Material (Brass is standard material) A: Add A for Aluminum Shell *Please note: FD and IL shell styles are supplied as overmolded cable assemblies or as stand alone connectors (strain relief boot not available for this product) Custom cable assemblies available upon request. Custom grommets and overmolds can be designed for any application. 9 M  S N A © Copyright SOURIAU 05/2013 - All information in this document presents only general particulars and shall not form part of any contract. All rights reserved to SOURIAU for changes without prior notification or public announcement. Any duplication is prohibited, unless approved in writing. Mixed Power & Signal
JDXER2T003FSN 价格&库存
很抱歉,暂时无法提供与“JDXER2T003FSN”相匹配的价格&库存,您可以联系我们找货
