UTGX614E5S
UTGX614E5S
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    CONN PLUG FMALE 5POS SOLDER CUP
UTGX614E5S 数据手册
UTGX6--E--- MATERIAL : - E A Solder cup 8 SHELL : PA UL94 V0, UL746C F1 Black color COUPLING RING: PA + Nickel-plated brass INSERT (UTGX0-----) : PA UL94 V0, UL746C F1 INSERT (UTGX0--E---) : Polychloroprene O'RING : NITRIL MATING SEAL : SILICON CONTACTS: brass + coated depending on P/N 7 PERFORMANCE CHARACTERISTICS : F 7 UTGX6-----P B SHELL PLUG A B C D E F G H UTGX6----- COMMON QUOTES FOR ALL VERSION 8 Operating temperature: -40 C up to 105C Insulation resistance: 5000 min M under 500V Corrosion salt spray: 500 hours Durability: 500 matings and unmatings MATING SEAL Insert 6 THREAD Sealing conditions: SEE TABLE O'RING 6 NOTA: 5 C 1- Contact to be ordered separately for version UTGX0----- : refer to corresponding catalogue. 2- Insert arrangement refer to: UTO-CONTACT-L-C02 (Female insulator) UTO-DHP-003-C01 (Female insulator #20) UTO-DHP-002-C01 (Female insulator #16) UTO-CONTACT-L-C01 (Male insulator) UTO-DHP-003-C01 (Male insulator #20) UTO-DHP-001-C01 (Male insulator #16) C144-UTS1-A (HiSeal Version) D 4 UTGX6-----S G Solder cup CountryJurisdiction& Control List FR NOT LISTED 5 4 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) P/N : CROSS REF TABLE INSERT 3 SEALING CONDITIONS A.6; Validé SIDE VIEW FOR EACH VERSION Sealing in MATED conditions with COUNTERPART Sealing in MATED conditions with COUNTERPART: and UNMATED conditions: -IP68 1 bar during 1 week: immersion under -IP68 1 bar during 1 10 m of water. (IEC 60529) 10 m of water. (IEC -IP69K : exposure to high pressure water of -IP69K : exposure to cleaning equipement(DIN 40050) cleaning equipement week: immersion under 60529) high pressure water of (DIN 40050) SHELL TYPE 6 Plug SHELL SIZE 10 12 14 TYPE OF LAYOUT Standard layout (No digit) E : HISEAL Handsolder contacts ORIENTATIONS Normal (no digit) W,X,Y,Z INSERT ARRANGEMENT See NOTA 2 TYPE OF CONTACTS P: MALE S: FEMALE 2 A 12/02/2020 ISS MAX SHELL SIZE A B min C D E 10 1 12 33.3 24 25.5 24 23.5 14 0.2 F MAX G THREAD CLASS 2A TITLE MASS 26.2 9/16-24 UNEF 20 23.5 29.7 11/16-24 UNEF 25 26.7 34.6 13/16-20 UNEF 35 Scale 2/1 G F * P/N for example New drawing -- E D C A2 3 25253J Latest modification - by: -- J.FEURPRIERDate:12/02/2020 CUSTOMER DRAWING MOD N 2 PLUG T6 WITHOUT BACKSHELL - SIZE 10 12 & 14, Standard and Hiseal version UTGX CONNECTOR Dimensions in mm General linear Tolerances: 0.2 www.souriau.com FORMAT H DATE Designed by: 10% (g.) 20.3 UTGX 6 14 E 19 P - BASIC SERIES SOURIAU DRG N° UTGX-0004A-C B NPRDS / PROJECT GBB This document is the property of SOURIAU It must not be reproduced or communicated without permission SHEET 1 / 1 A 1
UTGX614E5S
1. 物料型号:文档中提到了多种型号,例如UTGX6-----P和UTGX6--E--,以及不同尺寸的壳体,如10、12、14。
2. 器件简介:UTGX系列连接器具有多种材料选项,包括PA UL94 V0塑料外壳、镀镍黄铜耦合环、聚氯丁橡胶插入件等。
3. 引脚分配:文档中提到了不同的插入件配置,如UTO-CONTACT-L-C02(女性绝缘体)、UTO-DHP-003-C01(#20女性绝缘体)等,但未提供具体的引脚分配图。
4. 参数特性:包括工作温度范围(-40°C至105°C)、绝缘电阻(500V下至少5000MΩ)、耐盐雾腐蚀(500小时)、耐久性(500次插拔)和密封条件。
5. 功能详解:文档详细描述了连接器的密封性能,包括IP68和IP69K等级,以及在不同条件下的密封性能。
6. 应用信息:文档提到了连接器的尺寸、重量和一些特定的应用标准,但没有提供具体的应用场景。
7. 封装信息:提供了连接器的尺寸和重量信息,以及螺纹规格和类别。
UTGX614E5S 价格&库存
很抱歉,暂时无法提供与“UTGX614E5S”相匹配的价格&库存,您可以联系我们找货
