0.3 mm Pitch, 1.5 mm Mated Height, Board- to-Fine Coaxial Cable Connectors
DF38 Series
High contact reliability –
Effective mating length of 0.4 mm
1.5 ±0.15 (Mated height)
Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
3.7±0.15
(0.4) Effective mating length
■Features
1. Small mated height and board occupied
space
Enhanced shielding
Small pitch (0.3mm) and mated height (1.5mm)
allows use in space-restricted areas.
Plug’s height of 1.3mm and width of 2.38mm allow
its passage through narrow openings in smalldiameter hinge applications.
2. Enhanced shielding and ground connections
Metal shells on the plug and receptacle connect to
each other with a reliable multi-point ground
contacts, assuring reliable ground connection and
EMC protection.
3. Reliable lock
Fully mated condition is assured with reliable locks at
4 locations, confirming it with a distinct tactile click.
4. Reliable electrical and mechanical
connection
Despite its small mated height, unique contact
configuration assures highly reliable connection,
with effective mating length of 0.4mm.
Multi-point ground contacts
4-point lock:
2 points at each end
5. Solder wicking prevention
Nickel barriers prevent solder wicking in the critical
contact areas.
6. Durable plug construction
Formed metal shells on the top and side surfaces
form a strong and rigid assembly.
7. RoHS, Halogen-free*
*As defined by IEC61249-2-21
Br-900 ppm maximum,Cl-900 ppm maximum, Cl+Br
combined-1,500 ppm maximum
Distinct tactile click
■Connector for conductivity tests
We have a line-up of connectors for inspection,
usable for electrical testing of both plug and
receptacle connectors.
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2014.3w
1
DF38 Series●0.3 mm Pitch, 1.5 mm Mated Height, Board- to-Fine Coaxial Cable Connectors
■Specifications
Ratings
AWG #42: 0.15 A
Current rating Wire size AWG #44: 0.1 A (Note.3)
AWG #46: 0.1 A
Operating temperature range
Operating humidity range
-35 to +85°C (Note 1)
RH 20% to 80%
Voltage rating
Storage temperature range
Storage humidity range
-10 to +60°C (Note 2)
RH 40% to 70% (Note 2)
30 V AC
Item
1.Insulation resistance
50Mø min
Specification
100V DC
Conditions
2.Withstanding voltage
No flashover or insulation breakdown
100 V AC / 1 minute
3.Contact resistance
Signal: 80mø max., Ground: 80mø max.
100mA (DC or 1,000Hz)
4.Vibration
No electrical discontinuity of 1 µs or longer
Frequency: 10 to 55 Hz, single amplitude of
0.75 mm, 3 directions, 2 hours
5.Humidity
Contact resistance (change from initial value)
50 mø max.
Insulation resistance: 25 Mø min.
96 hours at of 40 ±2°C, and humidity of 90 to
95%
6.Temperature cycle
50 mø max.
Insulation resistance: 50 Mø min.
-55°C ➝ 5 to 35°C ➝ 85°C ➝ 5 to 35°C
Time: 30 min. ➝ 2 to 3 min. ➝ 30 min. ➝ 2 to
3 min.
5 cycles
7.Durability
50 mø max.
30 cycles
8.Resistance to
soldering heat
No deformation of affecting performance
Reflow: At the recommended temperature
profile
Manual soldering: 350°C for 3 seconds
Note 1: Includes temperature rise caused by current flow.
Note 2: The term "storage" refers to products stored for a long period prior to mounting and use.
The operating temperature and humidity range covers the non-conducting condition of connectors after board mounting
and the temporary storage conditions of transportation, etc.
Note 3: With only the connector portion at an elevated temperature level, the rated current value is set.
■Material
Product
Receptacle
Plug
2
Part
Insulator
Contacts
Metal cover
Vacuum cap
Insulator
Contacts
Metal cover
Material
LCP
Phosphor bronze
Polyamide
LCP
Phosphor bronze
Finish
Color: Black
Gold plating
Tin plating
Color: Black
Color: Natural, Black
Gold plating
Tin plating
Remarks
UL94-V0
----------------------------UL94-HB
UL94-V0
■Ordering information
●Connector
DF 38 A J – * S – 0.3 V (**)
1
2
3
4
5
6
7
8
9
DF 38 J – * P – SHL
1
2
4
5
6
10
1 Series name : DF
2 Series No.
6 Connector type
: 38
S : Receptacle
3 Insulator typestyle
P : Plug
Receptacle A : Standard
7 Contact pitch : 0.3mm
Plug Blank : Standard
8 Termination type
4 Connector style
V : Straight SMT
Receptacle/Shell
SD : Fine coaxial cable plug
9 Packaging
J : Receptacle for conductivity tests
(51) : Embossed tape packaging
Blank : Standard
5 Number of positions : 30, 32, 40
10 Installation item (separate)
SHL : Metal cover
■Combinations
●Standard use
DF38A-*S-0.3V(**)
+ DF38-*P-ASSY
DF38-*P-0.3SD(**)
DF38-*P-SHL
Note: The product specification of the above combination is shown on page 2.
●Receptacle conductivity test
DF38A-*S-0.3V(**)
+ DF38J-*P-ASSY ··· (Note)
DF38-*P-0.3SD(**)
DF38J-*P-SHL
Note: This harness item is only usable for the receptacle test.
For the product specification of the above combination, please contact our sales department.
●Plug conductivity test
DF38AJ-*S-0.3V(**) ··· (Note)
+ DF38-*P-ASSY
DF38-*P-0.3SD(**)
DF38-*P-SHL
Note: This harness item is only usable for the plug test.
* : ASSY means a harness item.
3
■Receptacles
B±0.2
A±0.15
P=0.3±0.1
0.1±0.05
3.7±0.15
Contact No.2
1.5±0.15
Contact No.1
■Recommended PCB mounting pattern
D±0.05
C±0.05
A±0.02
P=0.3±0.02
0.58±0.05
1.2±0.05
1.75±0.05
2.35±0.05
(0.46 )
0.92±0.05
1.94±0.05
G±0.05
F±0.05
1.8±0.05
J±0.05
H±0.05
1.28±0.05
Contact No.2
1
Contact No.1
F±0.05
G±0.05
H±0.05
J±0.05
0.3±0.02
Ground areas
C±0.05
Refer to User Recommendation page
(Para. 3) for the recommended metal
mask dimensions and open area ratios.
E±0.05
Note 1 :
Area indicated must be free of conductive
traces or the conductive traces must be covered by resist film.
[Specifications number] - * *, (* *)
(5,000 pieces per reel)
All dimensions: mm
Part Number
CL No.
Number of Contacts
A
B
DF38A-30S-0.3V(**)
662-4505-4-**
DF38A-32S-0.3V(**)
662-4028-7-**
30
8.7
32
9.3
DF38A-40S-0.3V(**)
662-4501-3-**
40
11.7
Note 1: Tape and reel packaging (5,000 pieces/reel).
Order by number of reels.
4
C
D
E
F
G
H
J
13.1
9.6
12.8
13.7
0.95
1.25
2.95
3.25
13.7
10.2
13.4
14.3
1.25
0.95
3.25
2.95
16.1
12.6
15.8
16.7
1.25
0.95
3.85
3.55
■Plug - separate metal cover required
A±0.15
B±0.15
2.38±0.15
P=0.3±0.1
All dimensions: mm
Part Number
CL No.
Number of Contacts
A
B
C
DF38B-30P-0.3SD(**)
662-4515-8-**
30
14.0
8.7
9.55
DF38-32P-0.3SD(**)
662-4027-4-**
32
14.6
9.3
10.15
DF38-40P-0.3SD(**)
662-4502-6-**
40
17.0
11.7
12.55
Note 2: The metal cover is required for fine coaxial cable termination.
■Recommended Fine Coaxial Cable Preparation
C±0.1
P=0.3±0.07
Inner conductor
(Pre-soldering
required)
0.2 MAX (Insulator)
Outer shield
(NO protrusion)
0.2±0.05
1.3±0.05
B±0.15
Ø0.3 MAX (Jacket)
0.45 +0.08
Contact No.1
0.46 MAX
(Ground bar)
Laminated tape
Note 1: Contact Hirose for Termination Procedures.
5
■Metal cover - Required for assembly of the Plug
1.22±0.15
2.28±0.1
A±0.15
All dimensions: mm
Part Number
CL No.
Number of Contacts
A
DF38-30P-SHL
662-4507-0
30
12.15
DF38-32P-SHL
662-4029-0
32
12.75
DF38-40P-SHL
662-4503-9
40
15.15
Note 1: Reel packaging (10,000 pieces/reel).
6
■Embossed Carrier Tape Dimensions (JIS C 0806)
(1.7)
(Vacuum pick-up area center)
8±0.1
4±0.1
2±0.1
F
F-F
(2.1)
(1.8)
(1)
+0.1
0.2±0.05
G
R0.7
F
G
Unreeling direction
G-G
(4)
●Reel Dimensions
Part Number Label
Unreeling direction
Ø21±0.8
2
(Ø79)
Ø382 MAX
±0.
Ø13
2±
0.5
B±0.1
A±0.3
C±0.1
Ø
1
0.
+ 0
5
1.
1.75±0.1
●Receptacle
D+20
E MAX
All dimensions: mm
Part Number
CL No.
Number of Contacts
A
B
C
D
E
DF38A-30S-0.3V(51)
662-4505-4-51
30
32
28.4
14.2
32.4
38.4
DF38A-32S-0.3V(51)
662-4028-7-51
32
32
28.4
14.2
32.4
38.4
DF38A-40S-0.3V(51)
662-4501-3-51
40
32
28.4
14.2
32.4
38.4
7
(1.7)
8±0.1
4±0.1
(1.8)
F-F
(1.5)
B±0.1
A±0.3
C±0.1
Ø1.
5
+0
0 1
2±0.1
F
1.75±0.1
●Plug
G
R0
F
.1
+00
.75
0.2±0.05
G
Unreeling direction
G-G
(2.7)
●Reel Dimensions
Part Number Label
Ø21±0.8
2
(Ø79)
2±
0.5
Ø382 MAX
±0.
Ø13
D+20
E MAX
All dimensions: mm
8
Part Number
CL No.
Number of Contacts
A
B
C
D
E
DF38-30P-0.3SD(51)
662-4506-7-51
30
32
28.4
14.2
32.4
38.4
DF38-32P-0.3SD(51)
662-4027-4-51
32
32
28.4
14.2
32.4
38.4
DF38-40P-0.3SD(51)
662-4502-6-51
40
32
28.4
14.2
32.4
38.4
■Extraction tool
For details about the extraction tool, please contact your Hirose sales representative.
■Usage Recommendations
1. Recommended temperature
profile
Temperature (ç)
250
250ç
220ç
200
60sec.
180ç
max.
150
150ç
90 to 120sec.
100
50
Room
temperature
50
100
150
200
250
300
Time (sec.)
Solder composition: Paste, 96.5%Sn/3.0%Ag/0.5%Cu
Note 1: Up to 2 cycles of Reflow soldering are possible under the
same conditions, provided that there is a return
to normal temperature between the first and second cycle.
Note 2: The temperature profile indicates the board surface temperature
at the point of contacts with the connector terminals.
2.Recommended manual soldering
Manual soldering: 350ç for 3 seconds
Do NOT use flux compound when manual soldering.
3.Recommended screen thickness
and open area ratio (Pattern area
ratio)
4.Board warpage
Thickness: 0.1 mm
Open area ratio: Lead terminal: 80%
Ground terminal: 100%
5.Cleaning conditions
6.Precautions
Refer to “Nylon Connector Use Handbook”.
Maximum of 0.02mm at the connector center, with both ends of the
connector as reference points.
* Mating and un-mating of the connectors when not soldered on the
boards is not recommended as this may cause deformation of the
terminals, damage to the contacts or insulators.
* When mating/un-mating do not twist or lift by the corners. Apply the
forces evenly across the entire length and width of the connectors
taking care NOT to damage or deform soldered terminations.
* Slight discoloration on the insulating materials will not affect form,
fit or function of the connectors.
9
■Precautions
Precautions
■Mating
Mate the plug with the receptacle by pressing straight against the entire plug surface.
Do NOT un-mate the plug while holding by the terminated cable.
Plug
Lock areas
Lock areas
Receptacle
■Un-mating
Use a dedicated extraction tool to un-mate the plug. Insert the tool under either end of the plug (clearance) and pull straight up as
illustrated.
Extraction tool
End side (clearance)
■Routing of the fine coaxial cable after termination
Allow sufficient clearance between the plug and the fine coaxial cable to avoid sharp bend, excessive twist or pull forces applied to
the connector.
No pulling
■Other
· Do NOT mate / un-mate the connectors when receptacle is not mounted on the board.
· Different production lots may exhibit different shades of the insulator materials. No affect on form, fit or function of the connectors.
· Rework of the soldered terminations on the board-mounted receptacles is not possible.
· Sides of the metal cover protrude over the termination areas.
· Do not mate / un-mate the connectors when receptacle is not mounted on the board.
10
MEMO :
11
USA:
HIROSE ELECTRIC (U.S.A.), INC. Headquarters
2688 Westhills Court, Simi Valley, CA 93065-6235
Phone : +1-805-522-7958
Fax : +1-805-522-3217
http://www.hiroseusa.com
USA:
HIROSE ELECTRIC (U.S.A.), INC. San Jose Office
3255 Scott Boulevard, Building 7, Suite 101
Santa Clara, CA 95054
Phone : +1-408-253-9640
Fax : +1-408-253-9641
USA:
HIROSE ELECTRIC (U.S.A.), INC. Detroit Office (Automotive)
37677 Professional Center Drive, Suite #100C
Livonia, MI 48154
Phone : +1-734-542-9963
Fax : +1-734-542-9964
THE NETHERLANDS:
HIROSE ELECTRIC EUROPE B.V.
Hogehillweg #8 1101 CC Amsterdam Z-O
Phone : +31-20-6557460
Fax : +31-20-6557469
http://www.hiroseeurope.com
GERMANY:
HIROSE ELECTRIC EUROPE B.V. German Branch
Herzog-Carl-Strasse 4 D-73760 Ostfildern
(Scharnhauser Park)
Phone : +49-711-4560-02-1
Fax : +49-711-4560-02-299
http://www.hirose.de
UNITED KINGDOM:
HIROSE ELECTRIC EUROPE B.V. UK Branch
22 Vincent Avenue, Crownhill Business
Centre, Crownhill, Milton Keynes, MK8 0AB
Phone : +44-1908-305750
Fax : +44-1908-305768
http://www.hirose.co.uk
CHINA:
HIROSE ELECTRIC TRADING (SHANGHAI) CO., LTD.
1601,Henderson Metropolitan,NO.300 ,East Nanjing
Road,Huangpu District, Shanghai,China 200001
Phone : +86-21-6391-3355
Fax : +86-21-6391-3335
http://www.hirose-china.com.cn
CHINA:
HIROSE ELECTRIC TRADING (SHANGHAI) CO., LTD. Beijing Branch
A1001, Ocean International Center, Building 56# East 4th
Ring Middle Road, Chao Yang District, Beijing, 100025
Phone : +86-10-5165-9332
Fax : +86-10-5908-1381
CHINA:
HIROSE ELECTRIC TECHNOLOGIES (SHENZHEN) CO., LTD.
Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre
5002, ShenNanDong Road, ShenZhen City, Guangdong Province, 518008
Phone : +86-755-8207-0851
Fax : +86-755-8207-0873
HONG KONG:
HIROSE ELECTRIC HONGKONG TRADING CO., LTD.
Room 1001, West Wing, Tsim Sha Tsui Centre, 66
Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong
Phone : +852-2803-5338
Fax : +852-2591-6560
http://www.hirose-hongkong.com.hk
TAIWAN:
HIROSE ELECTRIC TAIWAN CO., LTD.
103 8F, No.87, Zhengzhou Rd., Taipei
Phone : +886-2-2555-7377
Fax : +886-2-2555-7350
http://www.hirose-taiwan.com.tw
KOREA:
HIROSE KOREA CO., LTD.
1261-10, Jeoungwhang-Dong, Shihung-City,
Kyunggi-Do 429-450
Phone : +82-31-496-7000,7124
Fax : +82-31-496-7100
http://www.hirose.co.kr
SINGAPORE:
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. Bangalore Liaison office
10 Anson Road #26-1 International Plaza Unit No.03, Ground Floor, Explorer Building International Tech
Park Whitefield Road, Bangalore 560066 Karnataka, India
079903
Phone : +65-6324-6113
Fax : +65-6324-6123
Fax : +65-6324-6123
http://www.hirose-singapore.com.sg
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD Delhi Liaison Office
Suite No. 606 5th Floor SB Tower 1A/1 Sector
16 A Filmcity Noida 201301 Uttar Pradesh-India
Phone : +91-120-4804917
Fax : +91-120-4804949
http://www.hirose.com/sg/
MALAYSIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD (Representative office)
1-10-07, Suntech @ Penang Cybercity (1164),Lintang
Mayang Pasir 3,11950, Bayan Baru, Penang, Malaysia.
Phone : +604-619-2564
Fax : +604-619-2574
12
6-3,Nakagawa Chuoh-2-Chome,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 3/2014. Contents are subject to change without notice for the purpose of improvements.
