H
2.54
2.54
2.54
G
Recommended PCB Layout
Minimum
Insertion Depth
1.45 Ref.
Maximum
Insertion Depth
4.40 ref.
Specifications
2.54
Material
Insulator:
Standard: Polyamide, Nylon 6T, UL94V-0
Options: Polymer, LCP, UL94V-0
Polyester, PBT, UL94V-0
Contact: Phosphor Bronze
5.00
F
3.00
E
2.54
D
0.70 x 0.25 Pin
A±0.25
Ordering Grid
BG095
XX
X
X
X
No. of Contacts
02 to 40
B
A
Request Samples
and Quotation
Packing Options
D = Tube (Standard)
E = Tube with Cap
F = Tube with Film
G = Plastic Box
Contact Plating
A = Gold Flash All Over (Standard)
B = Selective Gold Flash Contact
Area/Tin On Tail
C = Tin All Over
G = 10µ" Gold Contact Area/Tin On Tail
I = 30µ" Gold Contact Area/Tin On Tail
Insulator Material
N = Nylon 6T (Standard)
P = PBT
L = LCP
1
2
3
4
5.08
8.12
4
7.62
10.66
5
10.16
13.20
6
12.70
15.74
7
15.24
18.28
8
17.78
20.82
9
20.32
23.36
10
22.86
25.90
11
25.40
28.44
12
27.94
30.98
13
30.48
33.52
36.06
38.60
16
38.10
41.14
17
40.64
43.68
18
43.18
46.22
Plating
See Ordering Grid
19
45.72
48.76
51.30
Electrical
Current Rating: 3 Amp Per Pin
Contact Resistance: 20 mΩ max.
Insulation Resistance: 1000 MΩ min.
Dielectric Withstand Voltage: 600 V AC
21
50.80
53.84
22
53.34
56.38
23
55.88
58.92
24
58.42
61.46
25
60.96
64.00
26
63.50
66.54
27
66.04
69.08
28
68.58
71.62
Product Description
BG095
2.54mm Pitch Socket, Single Row,
Through-Hole, Vertical, Dual Beam Folded Contact
Drawing Date
28th December 2007
5
3
33.02
Part Number
Revision
Date
5.58
35.56
Mates with (Subject to Pin Length)
BG020 BG030
BG031 BG035
BG055 BG060
BG075 BG080
By
B
2.54
15
(Not suitable for hi-temp process)
Detail
A
2
14
Mechanical & Environmental
Operating Temperature: -40°C to +105°C
Soldering Process
Nylon 6T (Standard)
IR Reflow: 260°C for 10 sec.
Wave: 230°C for 5-10 sec.
Manual Solder: 350°C for 3-5sec
LCP (Option)
Wave: 250°C for 5-10 sec
Manual Solder: 350°C for 3-5 sec
PBT (Option)
Manual Solder: 330°C for 3-5 sec.
B±0.38
C
Dimensions
Number of
Contacts
Ø1.02
CC
Tolerances (Except as Noted)
BG095
E PCN
E3
16/11/17
X.° ± 5°
X. ± 0.30
X.X° ± 2°
X.X ± 0.20
X.XX ± 0.15 X.XX° ± 1°
X.XXX ± 0.10 X.XXX° ± 0.5°
Length
Angle
6
Units:
Metric (mm)
C
3rd Angle Projection
7
29
71.12
74.16
30
73.66
76.70
31
76.20
79.24
32
78.74
81.78
33
81.28
84.32
34
83.82
86.86
35
86.36
89.40
36
88.90
91.94
37
91.44
94.48
38
93.98
97.02
39
96.52
99.56
40
99.06
102.10
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
ASS
8
Sheet No.
1/1
很抱歉,暂时无法提供与“BG095-04-A-N-D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+6.442761+0.83395
